2021 AMG Mercedes F1 Team
dans79
215
Re: 2021 AMG Mercedes F1 Team
214270 wrote:
Fri Oct 22, 2021 6:54 pm
If they’re testing, don’t they need to declare the specifics to justify a change on reliability grounds though? ie. RB would know and announce with glee to the world Merc’s engine troubles.
Not if they are messing with mappings, boost etc.
The other teams don't get told anything unless you are physically modified a component. Even then the details other teams get are vague and generalized.
182 103 103 7
dans79 wrote:
Fri Oct 22, 2021 7:01 pm
Wouldn’t that be done on a dyno? In this way done live on track surely if they were actually testing, you’d test ‘new’ elements?
dans79
215
214270 wrote:
Fri Oct 22, 2021 7:16 pm
you won't get real world g loads, air flow, cooling etc. on a test bench.
182 103 103 7
dans79 wrote:
Fri Oct 22, 2021 7:21 pm
Fair enough 👍
zibby43
zibby43
560
Huge news, if true.
Thanks for finding this, b2bL.
darkpino
darkpino
I thought that once you go over your engine allocation (so when using fourth, fifth and sixth engine) you can only use the sixth. But conversation with my friends caught me a bit unsure about this. Can anyone shine some light on this?
Gillian
Gillian
darkpino wrote:
Fri Oct 22, 2021 8:41 pm
That rule is about stacking PU in a single weekend. So if a driver gets 2 new PU in a weekend, only the PU used in the race will be added to the pool.
In this case it's a new weekend and a new PU so this new PU will be added to the pool and the oldest will be removed.
darkpino
darkpino
So basically Bottas has 3 new PU’s right now? Nice…
darkpino wrote:
Fri Oct 22, 2021 8:45 pm
doesnt really matter though, he just opens the door for Max anyway,
all that's missing is putting his arm out and making a bow.
Essentially, it's Hamilton vs the RedBull Army consisting of Max, Bottas, Perez, Gasly and Tsunoda. Next season that includes Albon.
This device was always present but it wasn't able to be used until recently. Remeber the issues they had with floor stability? Yeah., was porbably too risky to have that drop activate back then.
✊If we break that fundamental principle of sporting fairness and authenticity of the sport, then suddenly the stopwatch doesn’t become relevant anymore because we are exposed to random decision making, and you fall out of love with it.✊
🕸️ Web weaver Vs Spider 2022🕷️
search
no, there were problems wih the one introduced in Monza, and it's not usable anymore
Gillian
Gillian
Manoah2u wrote:
Fri Oct 22, 2021 11:52 pm
But it does matter as you could see in Turkey. Its not like Bottas will pull over to let Verstappen by if he has more pace. Maybe that's a reason to give Bottas another fresh PU. It could be Mercedes thinks it will give enough performance to keep Bottas in front of Verstappen.
Hammerfist
Hammerfist
If bottas can get to the top 4 rather efficiently he should be in verstappens pit window before the first stops. But that is a big if and realistically he will struggle to get by the Mclarens and Ferraris.
InsaneX_Badger
InsaneX_Badger
Hammerfist wrote:
Sun Oct 24, 2021 9:11 am
Let's hope that they have pushed the set up to be more responsive in dirty air.
