What Do you guys think about a KERS system where stored electricity is used to generate ozone to boost engine power?
The advantage is that the ozone generating system is pretty light. Mostly composed of wires.
Maybe they can even use supercapacitors instead of batteries?
The downside if efficiency. The could only generate 6% ozone with corona discharge methods.
Although trophosphere (ground level) ozone is considered a pollutant. Virtually no ozone will be left after exiting the engine combustion chambers.
