godlameroso wrote: ↑Thu Nov 29, 2018 3:46 pm
Efficiency is best ~lambda 1.2-1.4, and max power is near stoich for these engines. Power comes from heating the compressed air crammed in the CC, the most expansion of that compressed air comes from a high temperature delta...
no
imagine a turbo engine at stoichiometric AFR and 100 kg/hr fuel rate
about 30% of the fuel's heat must be taken and dumped by the coolant and some of the remainder is converted to work
now imagine doubling the MAP to give a 2 lambda AFR at the same 100 kg/hr fuel rate
the fuel heat released is the same but this heat is spread over twice the mass of air - so the temperature is lower
because the temperature is lower the amount of cooling needed is disproportionately lower
(guessing - maybe if we burned hydrogen at a 10 lambda AFR we might need no cooling)
this is the heat dilution engine
it's more efficient because more of the fuel's heat is available for conversion to work
it's more efficient as long as the increase in air mass is free of work cost (by turbocharging)
the practical limit to HD is how lean a mixture can be combusted properly - this depends on the main and prechamber fuels
HD is much less good with NA
the questions here are what MAP and what AFR are used
quite easy to answer the AFR question if we know the MAP and can assume they use conventional valve timings
the existence of prechambers may have answered the AFR question
