Capharol
21
Contact:
gandharva wrote:
15 Jan 2019, 14:06
Autobild
That's where I stopped reading.
:lol: :lol: :lol: :lol:
Autobild is where the Mercedes 12hp rumor came from? So better drivability out of slow corners, and better fuel/lube from Shell. The low speed cornering was the SF71's weakness relative to Mercedes.
rgava
Incidentally, last week I had the opportunity to get first hand confirmation of a long lasting rumour discussed several times here:
Ferrari engine does have steel pistons, and it's not the only one.
Honda is also using steel pistons from the same source.
They are not 3D printed, but steel is the material used since some time now.
hurril
rgava wrote:
11 Feb 2019, 12:22
But what about the talk here about that not being an allowed material to use? (As in: I don't doubt what you claim, I'm more interested in that counterclaim.)
rgava
hurril wrote:
11 Feb 2019, 12:40
Well, if it were not an allowed material then Ferrari would have been disqualified last year as they were racing their engine with steel pistons
trinidefender
317
hurril wrote:
11 Feb 2019, 12:40
rgava wrote:
11 Feb 2019, 12:22
Who said steel wasn't allowed?
hurril
trinidefender wrote:
11 Feb 2019, 14:25
hurril wrote:
11 Feb 2019, 12:40
rgava wrote:
11 Feb 2019, 12:22
It has been up a number of times. Doesn't matter.
Nonserviam85
rgava wrote:
11 Feb 2019, 12:22
Interesting, is the whole piston made from steel though or only the crown?
rgava
Nonserviam85 wrote:
11 Feb 2019, 16:50
rgava wrote:
11 Feb 2019, 12:22
The whole piston is what I've been told. Forged and post-machined
subcritical71
90
The 2019 rules have no such restriction on the use of steel for the piston;
5.16 Materials and construction – General :
5.16.1 Unless explicitly permitted for a specific application, the following materials may not be used anywhere on the power unit :
a) Magnesium based alloys.
b) Metal Matrix Composites (MMC’s).
c) Intermetallic materials.
d) Alloys containing more than 5% by weight of Platinum, Ruthenium, Iridium or Rhenium.
e) Copper based alloys containing more than 2.75% Beryllium.
f) Any other alloy class containing more than 0.25% Beryllium.
g) Tungsten base alloys.
h) Ceramics and ceramic matrix composites.
5.16.2 The restrictions in Article 5.16.1 do not apply to coatings provided the total coating thickness does not exceed 25% of the section thickness of the underlying base material in all axes. In all cases, other than under Article 5.16.3(b), the relevant coating must not exceed 0.8mm. Where the coating is based on Gold, Platinum, Ruthenium, Iridium or Rhenium, the coating thickness must not exceed 0.035mm.
5.16.3 The restrictions in Article 5.16.1(h) do not apply to the following applications :
a) Any component whose primary purpose is for electrical or thermal insulation.
b) Any coating whose primary purpose is for thermal insulation of the outside of the exhaust system.
5.16.4 Magnesium based alloys, where permitted, must be available on a non-exclusive basis and under normal commercial terms to all competitors. Only those alloys covered by ISO16220 or ISO3116 and approved by the FIA may be used.
5.17 Materials and construction – Components :
5.17.1 Pistons must respect Article 5.16. Titanium alloys are not permitted.
Now that that's out of the bag, how the hell do you keep the ringlands from coking? Are there oil passageways in the piston crown for additional cooling? How do they keep the weight down? I'm always amazed by human engineering.
Maritimer
19
Constant weep of oil to the rings, keep the surfaces immersed and cooled? Would also lend itself to oil burning if that's still something they want to maximise.
subcritical71
90
I don't really understand the pros/cons of steel vs Al, so I googled it. I came across this article (https://www.autosteel.org/-/media/files ... itter.ashx), which looks like it is from a steel symposium of some sort so take that for what its worth.
Anyway, interesting that Mahle is mentioned and used as source. As well, here are the listed Pros/Cons to steel pistons;
PROS (compared to cast aluminum pistons)
 Higher cylinder pressure limit
 Higher piston temperature limit
 Reduced top land height possible (reduced crevice volume)
 May offer friction advantages particularly in iron block/liner engines
CONS (compared to cast aluminum pistons)
 Higher cost
 Weight (current)
 Cooling oil flow requirement due to higher piston temperature
 Potential to increase detonation sensitivity in gasoline applications
So I'm not sure the first two cons are really relevant as I cannot imagine it adds significant weight, but last two would be interesting to see how they get around that.
620
subcritical71 wrote:
11 Feb 2019, 20:15
....I cannot imagine it adds significant weight ....
steel is 3 times the density of aluminium alloy
(and a steel piston 33% as thick as an alloy piston won't be stiff enough to behave properly)
but 'fortunately' for the steel piston the engines are limited to about 12000 rpm - so they can stand steel's extra weight
563
Tommy Cookers wrote:
11 Feb 2019, 22:55
11 Feb 2019, 20:15
. . . (and a steel piston 33% as thick as an alloy piston won't be stiff enough to behave properly). . . .
I imagine the piston crown underside must have extensive "ribbing" or perhaps a honeycomb structure to give it "thickness" without weight. This would also increase surface area for heat transfer to the cooling oil.
Post Reply
