Here is a quote by Jenson Button from the McLaren-Honda race report at the 2015 GP at silverstone, "The impact lifted the car up and turned it off. With the engine not running, I had no option but to retire."
It appears from this that there must be a sensor of some sorts that shuts off the engine in the event of a large shunt or if the wheels are lifted off of the ground. This is a very important safety device. Why though, can the 2014 and onwards power units not self start? If they had been able to then maybe jenson would have been able to simply start back up and re-join the race.
Before this generation of power units I can understand the problems with the extra weight of starters etc. Now however, it shouldn't take much more than a software update/new software mode. There could be two ways to start the engine.
1. The clutch is disengaged and since the MGU-K is connected to the crank all it has to do is rotate to a set speed and the engine will start just as if they used the starter mother from the back (hence where some teams have flaps in the back of their diffusers). The clutch is then engaged and the car pulls away and rejoins.
2. Same as number 1 but the clutch stays engaged the car getting up to speed also helps to roll start the car. 120kw should easily be enough for this.
Either I am missing something very obvious or Mclaren-Honda shot themselves in the foot by not including this. Or is there some reg that says once a car shuts off that it is out.
