If they will have to run the engine detuned when they go to OZ, they should as well not go to all the trouble and go.
I don't see it as issue, it may be a "feature"...
Agree with Just_a_fan here. You are projecting your biases izzy.Just_a_fan wrote: ↑27 Feb 2020, 21:52No it isn't. Or is it only sexist because she's a woman? If a driver "bitches" is that still sexist?
logically, it has to be something that didn't happen on the dyno, which has the engine in a chassis, so that means vibration or g? In dynos these days they have the gearbox on and drive simulated tracks and everything, so... something to do with the circulation? If it was the bores or coating kind of thing that would've shown up before it went in a car. They went too thin with the oil in 2016 didn't they, that only showed up in a race
it must help that according to AMuS they made the sensor more sensitive, so it shut down while it was all in one piece. So now they've got an engine that exploded, one that had the fault but is intact, and at least one that's run but not had an oil pressure failure. So one way or another, you'd think they'll be able to find the problemDe Jokke wrote: ↑28 Feb 2020, 13:37here we go: https://www.autosport.com/f1/news/14847 ... of-testing
Might be slightly off topic here, as it's about the Ferrari PU, but, given FIA statement at the close of testing, that might be doubly inaccurate - seems Ferrari had to restart PU development from earlier, less powerful, but still legal, point so likely less powerful than last year's, and it wasn't just sour grapes from Mercedes (plus extra grunt likely related to Leclerc's extra fuel in Abu Dhabi, and the sensor stuff).Bill wrote: ↑28 Feb 2020, 15:40They didn't fix it last year.i wonder how that pu will perform in the sweltering heat of Bahrain.There power deficit to Ferrari haven't been closed in the last two years infact Ferrari had to carry a lot sensors and measuring tools because Mercedes couldn't stomach that someone did a better jop than them, quite frankly it must have be humiliating for Ferrari.
