Funnily enough, re: T-C's mention of the still interesting Napier Lion design of nearly a century ago..
..featuring such current standard tech as DOHC 4V.. tapered ports.. hollow valve stems.. slipper pistons..
.. 'billet' cylinder liner, that at the top, also formed the combustion-chamber, through which the valves seated..
.. & on to which - the liquid-cooled.. enclosed lube.. gear-driven.. DOHC 4V.. Al head - was fixed.
See here: http://collections.museumvictoria.com.au/items/1720829
& drawings here: http://archives.imeche.org/archive/engi ... tyPhoto10/
The Lion was successfully developed from an N/A ~400hp bomber mill turning ~1,500rpm.. for ~100mph..
..to a supercharged race engine reliably pumping out an additional ~1,000hp @ ~3,500rpm.. for ~400mph..
..& good enough to hold the piston engine/wheel driven/outright LSR up 'til the 60's.. so, not too shabby..
