Googling one's symptoms will always result in a conclusion that near death is imminentBrian Coat wrote:I now understand why doctors roll their eyes when patients say they "Googled" their symptoms on the internet.
Well said indeed! We should all get a degree now. =D>pgfpro wrote:Very well said!!!
gruntguru wrote:I have been trying very hard not to jump into this thread - there is so much BS flying its hard to know where to start. A quick summary of some facts (I know most of them have appeared in earlier posts but I thought I might put them together in one place). The main outcome (looking at points 3 and 4 below) is that torque and work are totally different quantities. They are only remotely related to one another and then only by introducing a third property (rotation).
1. A "scalar" is a physical quantity that has magnitude but no direction.
2. A "vector" is a physical quantity that has magnitude and direction.
3. Torque = force x lever arm (perpendicular displacement from axis to force). Note this is a "cross" product of two vectors so torque is also a vector, pointing along an axis perpendicular to both the force and the lever arm. Note also that only the component of the lever arm which is perpendicular to the force contributes to the cross product. (eg if you push along a spanner you do not generate any torque)
4. Linear work (energy) = force . displacement parallel to the force. This a "dot" product of two vectors so work is a scalar (it has no direction).
5. Rotational work (energy) = torque . rotational displacement parallel to the torque. Once again the two vectors are multiplied using a dot product, so the work is again a scalar. No rotation -> no work.
6. Power is the rate at which energy is released or transferred. Since rotational energy is torque . displacement, rotational power is "rotational energy rate" which is torque . rotational displacement rate (also know as angular velocity). Whether this is expressed as radians per second or rpm doesn't really matter - that is just a "units" issue which is easily fixed with conversion factors.
Just read this post. If you cannot understand it after reading this then you'll need to pick up a physics textbook if you want to try and understand it.FoxHound wrote:rjsa wrote:No. Power is the rate at which energy is delivered, not force. And torque is force times distance from rotation center, not energy. It's the root of this silly argument.FoxHound wrote:Then would it be incorrect to say that Horsepower is the rate at which Torque is delivered?
Sorry to bang on, but I'm trying to simplify this to explain it accurately, with as much brevity as possible, without being incorrect.
Horsepower can be defined as how fast the engine can deliver torque to a load. Correct?
And torque is the measure of how much twisting force an engine can produce. Correct?
One is related to the other, but both are influenced either by time(HP), or by distance(torque)?
Ok so in one sentence, can you give me a definition of the differentiation of Torque to Horsepower that is accurate?
Because there is a ton of misinformation on this on the internetz.
And we can also finally put this to bed(arguably, perhaps).
I've read this post. I've upvoted this post.Cold Fussion wrote:Just read this post.[/url] If you cannot understand it after reading this then you'll need to pick up a physics textbook if you want to try and understand it.
Condensing into one sentence is just arbitrary 'simplification'. The explanation Grunt Guru provides is about as simple as you can realistically make it.FoxHound wrote:I've read this post. I've upvoted this post.Cold Fussion wrote:Just read this post.[/url] If you cannot understand it after reading this then you'll need to pick up a physics textbook if you want to try and understand it.
I'm was attempting to condense this post into a sentence, so that it would be explicable to most. Rjsa helped out.
THE END.
that's the funny bit.hollus wrote:How much extra power do those extra 15-20 ft lbs of torque represent?
IF my calculations are correct,hollus wrote:I know. So how much extra power comes together with the extra torque... at those rpm where torque is being increased?
Sounds like really big midrange gain and small top end loss.godlameroso wrote:Between 4,500 to ~7,900 there's an across the board improvement 15-20ft lbs of tq, but there's a 7hp deficit at 8,400 rpm. Compared to the same car with another "tune" and different mods, granted we're talking about 167 ft lbs vs 148 ft lbs peak difference, and on average about 15 ft lbs over 3,000 rpm. I don't know what that equates to power wise probably 10 hp average increase everywhere in that range but a little bit less peak.
