Hi guys, sorry about the caps.
I am unsure about the level this forum is at. Either way this read is a decent one about the current generation of motors.
https://drivetribe.com/p/f1-burning-lea ... ce=network
Lets talk engine combustion.
The last mercedes pre chamber diesel is the famous OM606. In stock the engine easily can be tuned to well above 400 hp https://www.youtube.com/watch?v=YlwTxw-027oMatsNorway wrote: ↑19 Sep 2017, 21:40I did not know anything about civics but i do know Mercedes had Pre chamber Diesels back in the day and probably still use the techicue to this day.
What i really hope for F1 is for them to free up the rules regarding these engines. Say open up the Bore and stroke ratios and flatten the fuel curve. That way you get a better shot at making more efficient engines and they might sound better in the process which is something many fans would enjoy. It is a win win if true.
I did own a 1975 Civic CVCC (Orange, we called it the pumpkin) and it consistently got 35 MPG while scooting along at traffic speeds. "Compound Vortex Controlled Combustion". I was impressed with it.MrPotatoHead wrote: ↑19 Sep 2017, 19:53A very dumbed down description of a very complex process sadly.
The part saying Honda Civics used the same technology in the 70s made me shake my head.
That explains it.
The most impressive aspect of the Honda CVCC engine was that they got it to work fairly reliably using a carburetor.
Those things were a vacuum hose nightmare! Impressive none the less.
Very important subject in it contribution to the "new" F1 efficiencies.MatsNorway wrote: ↑19 Sep 2017, 16:21Hi guys, sorry about the caps.
More than likely improved ICE efficiency of the pre-chamber jet ignition is a key reason Mercedes have been dominant for so long. Nobody else knew and they have spent years chasing marginal gains from ERS and split turbo.Tommy Cookers wrote: ↑21 Jan 2018, 13:49but it's a pity we don't also know more about the creditable performance of the erstwhile non-prechamber competition
I don't see this happening because of the short time between primary and pre-chamber injection trough the same injector and the short volume of the pre-chamber injection compared to the main one.godlameroso wrote: ↑29 Mar 2018, 03:18Different fuel temperatures change the properties of the fuel, perhaps the primary injection is at a different temperature than the pre-chamber injection.
