Fuel cooling
Scuderia_Russ
Fuel cooling
Patrick Head stated recently in Autosport that Ferrari use a device that extracts the fuel from the car when on the grid,cools it and then retuns it to the fuel cell prior to a race.Wether the same amount goes back in (a question posed to Charlie Whiting by Head) and cost implications aside,just how does this benefit combustion exactly?
"Whether you think you can or can't, either way you are right."
-Henry Ford-
Racer-X
It is reported that each 10 degC represents 0.5% in power.
By the regulations the teams are allowed to cool the fuel up to 10degC below the ambient temperature.
For 2004 only the fuel in the pitstop tanks can be cooled and not the car tank anymore.
The big discussion in Ferrari's cooling on the grid was if there was some fuel inside the cooler before connecting it to the car.
The FIA probably found something wrong. Now it is forbiden!!!!
Italians!!!!!!
Guest
Guest
Could anyone explain the cooling effects in more detail? I know that colder air is more dense, thus contains more oxygen so it can burn more.. with fuel, what does it do? I would imagine that if the fuel is colder then it will cool the air around it, thus doing the same thing? Anything else? Do the properties of the fuel change as well?
rodlamas
rodlamas
As the fuel becomes colder, it gets more dense, the same thing that happens with air. So if with a more denser air, the engines gets better power, it´s expected that with more desinty, the fuel would burn more efficiently and consequently will generate more power.
"I only race to finisht first, because the second is the first looser" Ayrton Senna
Steven
Owner
exactly, the same amount of particles takes less volume, which finally leads to more particles to burn at a time in the cylinder ;)
NickT
Also cooler fuel has a greater capacity to absorb heat from the inlet charge so increasing the amount of air heading for the cylinder.
NickT
wowf1
wowf1
Yes that's about the gist of it. To back this up i carried out an experiment for my own enjoyment as much as anything else: I race radio controlled cars, and as part of a power increase program i was doing :D on a 0.15cu engine, I put the Nitromethane fuel in the fridge until it was just above 0 degrees C. When i tested the engine on the dyno, here are the relative performance figures:
[u]RTemperature fuel[/u] [u]Cold Fuel[/u]
Max. BHP : 1.16 1.29
Max. RPM : 33, 760 35, 115
Evolve time : 0.92s 0.86s
Quite conclusive proof i think you would agree (nb. room temperature was constant at 24 degrees C) and other conditions were as fair as possible.
rob
Beostar
Beostar
nice one :)
Always nice to see some flashy numbers :) and theory put into practice :)
"The track is mine you may have it when I'm done"
"First law of computer programming : The user is a complete idiot"
"Don't confuse luck with skill."
rudo7
rudo7
cool fuel
are you talking about cooling fuel to temperatures just above 0, or could it also be cooled below 0???
just wondering... :roll:
Beostar
Beostar
Aslong as its fluid you can use it.
SuperZ
SuperZ
Fuel COoling
If you look in this edition of FOrza the Imola 360 uses a fuel cooling system that works off of the air conditioning unit. Does anyone know who the supplier of this unit is?
rollo
rollo
fuel cooling
once knew someone who ran his fuel line along the cold a/c pipe which returned the gas back to the a/c compressor from the evaporator and wrapped it up with insulation. he experienced some improvement in engine power although not much.
Hannah06
Hannah06
Re:
Racer-X wrote:It is reported that each 10 degC represents 0.5% in power.
Italians!!!!!!
Really? Each 10 degC represents 0.5% in power? Where did you hear this news?
By the way, I just want to say thank you for the information that you have been shared. Godspeed+
_________________
Aprilaire
archebald23
archebald23
Re: Fuel cooling
rollo wrote:once knew someone who ran his fuel line along the cold a/c pipe which returned the gas back to the A/C Compressor from the evaporator and wrapped it up with insulation. he experienced some improvement in engine power although not much.
fuel becomes more dense after cooling thus giving more fuel to enter combustion chamber, computer reconizes this and adjusts fuel trims, back to programmed trims, what was accomplished?
Edis
Edis
Re: Fuel cooling
The fuel circulate from the tank, through several fuel pumps, to the engine and most of it then back to the tank again. This can heat the fuel quite significantly, especially if a small amount of fuel is used or if no refueling is allowed. When the fuel gets warm, the cooling effect on the incoming charge decrease and there is a small loss in power. Not a big loss, a half to one percent probably if we go from say 80 degC to 40 degC but then again, there is probably also a small gain in fuel efficiency.
