hurril
Re: 2014-2020 Formula One 1.6l V6 turbo engine formula
What I don't understand is what the point is with being this detailed in what is and is not to be permitted. What is lost if Ferrari, for instance, were to find some extra juice by doing something very creative here? I don't buy the cost argument here because why would that be that much more expensive than it will be to find the juice with more limitations?
It means that it's a political move to preserve an advantage of a certain team. They don't want others to outdo them with higher than 18:1 or bigger prechambers.
roon
412
roon wrote:
25 Jan 2018, 21:30
1.30 may imply an unusual combustion chamber design. Why else define what is common knowledge?
Guesses:
  • A combustion chamber was used which did not use poppet valves as the, or as the main form of, control.
  • Combustion was occurring elsewhere.
Wazari wrote:
04 Jan 2017, 09:27
FW17 wrote:Hi Wazari
Are there any methods of flame quenching away from piston crown and cylinder walls currently being used in F1
What are the likely ways of achieving this?
1. I think I would assume so.
2. Various methods. CC design or lack of CC as we conventionally know it 8), piston groves, diagonal piston ports, slots, etc.
etusch
131
Lean burn
‘The dream of an engine engineer working in this area of lean burn today, is to be able to burn as a diesel, and do that more or less automatically – a sort of auto combustion,’says Engelric. ‘To do that right, firstly you needto have direct injection, then you need to use spark plugs with pre-chamber and you need knowledge of the right set-up. But there are no fixed rules that guarantee you the best result with one attempt. Why do you think F1 teams spend so much money on engine testing? They know what they want, they know the rough direction to go in, but they have to experiment with a trial and error approach. ‘The talent of the engineer is to extract the knowledge from the results of each test, and build understanding,’Engelric adds. ‘We know that swirl, tumble and pre-chamber all
help with the combustion, but it is still an area that requires a lot of experimentation to gain that last five per cent of efficiency, and that is where you can easily explode your budget. For us, it makes no sense to spend all our money
in this area, it is a constant fight between the technology we want to develop, the budget of a privateer team, the racing we want to create and the profitable business we want to be.’ Another factor that required careful
consideration when redesigning the combustion chamber was controlling the area where knock is most likely to occur. This can be done through ensuring smoother geometries, Mecachrome used to manufacture 300 Formula 1 engines per
season. Today it supplies both Formula 2 and GP3 with its V6, as well as making the new LMP1 version available to privateers higher squish (the sudden turbulence of the air and fuel mixture as the piston approaches TDC), and instigating turbulence in the knock-prone regions to create conditions that minimise the likelihood of such an effect. The electronic control systems have to be capable of not only detecting the beginning of knock, but also have the correct mapping to react and prevent any development of knock.
‘The key is to push this limitation as far as possible, whilst using electronics to control the moment that you start to see this phenomenon because you know that it can destroy your engine,’ says Engelric. ‘We have eliminated 90 per cent of the risks of the first order of knock in our current LMP1 engine, whilst achieving the level of power possible
from the fuel limitations by managing the introduction of direct injection.’
Structural role
A further consequence of switching to direct injection was that the cam cover required modification as the high-pressure pump was now driven by the camshaft. Furthermore, the engine plays a much more structural role in a
prototype racecar as opposed to a single seater. ‘This means we have to achieve much higher stiffness with our LMP1 engine compared to F2.
In F2 we have four points to fix the engine to the chassis, however for LMP1 we have a total
of six attachment points, two of which are by the cam cover,’ explains Engelric. ‘We have used FEA to analyse the stiffness as well as the fatigue stress of the parts to guarantee that our new components never fail under the stresses we see during the life cycle of the engine. With this new design we have improved the stiffness of the engine by 40 per cent, which is essential for such a car and why we redesigned the cam cover.’ Aside from the direct injection-related redesigns, the LMP1 and F2 engines are very similar; sharing approximately 90 per cent of the same components including the block, head castings, crank and conrod. ‘The total distance raced in a full season of F2 is around 8000kms, Le Mans is around 7000kms. Our engine has already done a full season of F2 on the dynamometer, so we are not far away from completing Le Mans,’ Engelric says. ‘Of course it is somewhat different because at Le Mans, you start and never stop, but the majority of the larger parts will all work the same way for Le Mans as they do in GP3 and F2. The more critical parts, such as the pistons, valves and other valve-train components need to be
re-evaluated to guarantee they can survive Le Mans and the WEC season. But if we had started designing this LMP1 engine from scratch, I am pretty sure we would have arrived very close to the design we have today. The V6 is a good
compromise and the single turbocharger in the centre fits well with the installation of the car.’
From Race Car Engineering mag.
Santozini
How FIA will clamp down on F1 engine tricks:
https://www.motorsport.com/f1/news/fia- ... s-1002647/
Interesting..I was surprised to see the scrutiny regarding the minimum air intake temperature :roll:
hurril
Santozini wrote:
07 Feb 2018, 14:44
The minimum air temperature clause is intriguing. I wonder if there's more to that than just using dry ice to make qualifying really good though.
roon
412
Some say it may be to limit development costs for intercooler tech. Perhaps the same reason why they limit a minimum diameter for crankshaft journals: the teams have identified certain components as high-development-cost with low-performance-gain. I'm not sure though--the development money will always end up somewhere. If it's true that it's about cost-savings, then no team should pursue further development of said components regardless of legality. Another way to read rules additions may be as: an ingredients list of the leading manufacturer(s) superior components. Another way to read it would be as: exotic technologies deemed potentially unsafe or not within the spirit of an intended development path (currently being road-relevance and efficiency, contentious as those terms may be).
dren
226
My guess would be Ferrari complaining to the FIA about Mercedes tech and thus rule modifications.
Honda!
63l8qrrfy6
368
Ferrari should mind their own business - for example they could focus more on designing charge pipes that don't break.
444
dren wrote:
08 Feb 2018, 19:25
Doubtful, since Ferrari also use a combination of air and water to air intercoolers.
J.A.W.
109
Interestingly, the advent of direct fuel injection,
& even the concept of a "concentric duplex nozzle",
- to enable a twin injection sequence from a single injector,
goes back some ~80 years or so..
( inc' split injection events on both induction & compression strokes).
http://www.calum-douglas.com/current-bo ... ower-race/
( To see it as noted, click on the - 'current book the secret horsepower race' - heading,
then click on - 'preservation of formerly secret aviation history',
scroll to bottom of page, then click page '10' - of the listed documents).
When the fuel flow measurements are enforced does it assume that max flow rate of the injectors is ~135lph, or around 1,400cc injectors?
roon
412
What do you mean by enforce? The rules state that all fuel destined for use in the engine must flow through the sensor first without exceeding a flow rate of 100kg/hr. A rule added for '18 was that no fuel can be looped/recycled post sensor. Per-cylinder apportionment is not regulated. You could inject at a 100kg/hr rate into a single cylinder, plus the volume from any post-sensor accumulation methods devisable, if there was any benefit.
Brenton
My initial impression was always that it looked like a heavy unit and was oddly located on the top of the engine. But I had not fully considered the design.
Makes me wonder. In designing an F1 car, I wonder how compromises are communicated. Do the engine people and aero people have some sort of quantified value rating when communicating importance of features?
For example: "if the engine is 3cm taller, that is legal but will cost us *insert value* in aero performance." Implying that making the engine 3cm taller should only be done if it makes it *insert performance value* more powerful.
It's an economic question relating to the allocation of resources. If the communication is as poor as "don't do this engine height because it will make aero worse, but we can't say how much worse"... It would be like the problem of pricing goods in a command economy. If different needs in design aren't properly quantified and communicated, there's presumably no way to make the most beneficial choices.
I have no engineering background. I'd be happy to be directed to the appropriate engineering subject that deals with this design decisions problem, to learn how it's done.
563
Good question Brenton. No question that all those variables can be modelled and the precise effect on lap-time, cost, fuel used, etc is predicted.
I look forward to hearing more details from someone with inside knowledge.
Post Reply
