63l8qrrfy6
368
Re: 2014-2020 Formula One 1.6l V6 turbo engine formula
johnny comelately wrote:
12 Mar 2018, 02:12
Mudflap wrote:
12 Mar 2018, 02:02
12 Mar 2018, 01:56
Somewhere along the line there would have been knock and with sensor data that would show. Once the cause conditions were normalised there would be the ability to predict knock under conditions X.
So the mapping would take all the predictive indicators and when algorithm Y was arrived at it would start ignition control.
The use of the predictive indicators would have to have the trial and error safety margin applied to them.
Thats my idea of it.
There is the issue- such an algorithm would require a good safety margin to work in all conditions. High safety margin in this case is low performance.
Therein would be one of the factors for the successful engines, the determination and management of that safety margin. Lots of trial and lots of errors ($) hopefully mitigated by simulations with that data.
Maybe one of the factors is who can run with a bit of knock for longer.
63l8qrrfy6
368
12 Mar 2018, 02:20
Another approach for power estimation is the start times.
From what I can see there are not many tracks with a 1/4 mile before the first braking, but Albert Park just squeezes it in I think.
Using you tube and several maps for corroboration it looks like about 8 seconds for the 1/4. I know this is inaccurate but....
With weight of 895 kg it gives a horsepower of 762.
Corroboration please.
EDIT: By the way if it was 7.5 seconds it would be 924 hp so this method is fraught with danger
How did you calculate this?
johnny comelately
110
Mudflap wrote:
12 Mar 2018, 02:38
12 Mar 2018, 02:20
Hp = weight divided by (ET/5.825)cubed
That is why i said its just another method
trinidefender
317
Mudflap wrote:
12 Mar 2018, 02:38
12 Mar 2018, 02:20
Probably one of the generic quarter mile hp calculators like this.
https://robrobinette.com/et.htm
They are notoriously inaccurate and make many assumptions including drag...probably wasting your time honestly
563
Yep, the drag/weight ratio of an F1 car is ridiculously high.
johnny comelately
110
trinidefender wrote:
12 Mar 2018, 03:32
Mudflap wrote:
12 Mar 2018, 02:38
12 Mar 2018, 02:20
Well, I dont know if that is correct because it is usually and amazingly accurate in practice (not qualifying).
It's important not to get too distracted by the trees (frontal area, weather, slippage, track condition etc etc) as through experience they have allowed for that in a hollus bollus way (I can see you cringe :) ) with the constant.
johnny comelately
110
So, who has an accurate 1/4 mile ET for any of the current leading cars.
I do know that some F1 engineers that spent some time with one of the top fuel outfits in Florida to learn about launch and clutch setup etc; circa 2001
henry
324
12 Mar 2018, 02:13
re Power:
How much is harvested on the warm up lap to assist the ICE at launch?
It depends what you mean by launch.
Off the line, from 0 kph, they can’t use the MGU-K, its use is not allowed until they reach 100 kph. After that they are traction limited to around 160 kph.
They might use some energy from the ES to drive the compressor right at the start, but probably not.
So from that perspective they harvest zero energy specifically to assist launch.
However I would expect them to come to the line with a fully charged ES since maximising first lap power is vital.
johnny comelately
110
henry wrote:
12 Mar 2018, 10:23
12 Mar 2018, 02:13
re Power:
Thanks for that Henry.
So, for my purposes, launch is all by ICE (i understand what you are saying re the turbo) BUT at say 1/8th mile (100kph) they can use electric ?? or, after that, is the traction limited by rule not actual tyre slippage?
hurril
henry wrote:
12 Mar 2018, 10:23
12 Mar 2018, 02:13
re Power:
Are they forbidden to have the MGU-k active in any fashion or just as a motor?
henry
324
12 Mar 2018, 10:30
henry wrote:
12 Mar 2018, 10:23
12 Mar 2018, 02:13
re Power:
The traction limit is tyre slippage.
You are some way off the distance at which they hit 100 kph. It’s probably in the range 30 to 40 m. The car starting 4th may well hit that speed at the start finish line. At 1/8 mile they’ll be well north of 200 kph.
12 Mar 2018, 07:05
~8.5 seconds for the 400m
PS Sochi has a very nice run up to turn 2, way over 400m.
In Bahrain the run from the starting line to the speed trap is exactly 400 m Bottas did a 8.6 @ 155 mph or 250kph, but his 60' is terrible almost 2 seconds.
AJI
AJI
27
hurril wrote:
12 Mar 2018, 10:56
My understanding is that they are forbidden to use it at all up to 100kmh (at the start) primarily so it can't be used as traction control.
johnny comelately
110
godlameroso wrote:
12 Mar 2018, 22:27
12 Mar 2018, 07:05
Thank you for that, it verifies the times
when did Miami go metric ? :)
The 60 foot time is a shocker.
13 Mar 2018, 00:06
godlameroso wrote:
12 Mar 2018, 22:27
12 Mar 2018, 07:05
South American people are very familiar with metric, but there's also nothing wrong with Sumerian 12.
Post Reply
