Wheel frequencies VS track surface
Rustem 1988
Re: Wheel frequencies VS track surface
Post by Rustem 1988 » Sat Apr 07, 2018 1:19 am
It is believed that stiff springs should have more stiff shock absorbers. To what extent does this theory work in practice?
DaveW
242
Post by DaveW » Sat Apr 07, 2018 10:01 am
The theory is good so model results should match the vehicle. Otherwise question the model.
p.s. Some of the publications you have been looking at use inadequate models (hub masses, tyre stiffness, insulation stiffness, etc.)…
Rustem 1988
Post by Rustem 1988 » Sat Apr 07, 2018 2:30 pm
If the car travels on a flat road, then in this case, the shock absorbers do not bring any benefit? Is there any benefit from shock absorbers when accelerating and braking the car?
gambler
Post by gambler » Sun May 13, 2018 10:01 pm
I have test driven a few track cars with way too stiff springs on the front , (presumably to plant the nose on heavish caveman braking.) They follow the tracks in the road that trucks mash in, or even the irregular pavment at the track almost like there are bias-ply tires on the car, ...very darty. I can see the need for "tuned" shocks that take up that slack when needed, but still be able use a softer spring....as you can imagine it is extremely complicated before you even whip out the pocket calculator.
Rustem 1988
Post by Rustem 1988 » Thu Sep 06, 2018 6:48 pm
DaveW wrote:
Mon Mar 05, 2018 3:31 pm
Rustem 1988 wrote:
Mon Mar 05, 2018 12:20 pm
...the load on the wheel W=Wst+ks(Xs-Xu)+Cs*(dXs/dt-dXu/dt)+kt(Xu-Xr)+Ct*(dXu/dt-dXr/dt)
I believe you have forgotten the inertia force acting on the wheel. If I simply rewrite your equation:
Load on the wheel = Wst+(Ks+ Cs*D)*(Xs-Xu) + (Kt+Ct*D)*(Xu-Xr), where D is the operator d/dt.
Then dyamically, Mu*D*D(Xu) = (Ks+Cs*D)*(Xs-Xu) + (Kt+Ct*D)*(Xu-Xr). Here D*D(Xu) is the acceleration of the wheel, and Mu is the wheel (unsprung) mass. Wst disappears because it is balanced by static offsets of the springs. A similar equation can be written for the acceleration of the sprung mass, and the two can be solved together to compute the various responses of the vehicle per unit road input.
It is a little more than that, because the sprung mass connects the front & rear suspensions (so the sprung mass has "heave" & "pitch" inertias).
I hope this helps...
Now I think that the load on the wheel is determined by the force with which the tire presses on the road. Changing the load at a given time: (Kt+Ct*D)*(Xu-Xr). And we must find the maximum value of this expression.
(Kt+Ct*D)*(Xu-Xr)=Mu*D*D (Xu) - (Ks+Cs*D)*(Xs-Xu) .
Rustem 1988
Post by Rustem 1988 » Thu Sep 06, 2018 7:01 pm
It turns out we need to either reduce the acceleration, or increase the force in the spring, to reduce the change in the load.
gambler
Post by gambler » Thu Sep 13, 2018 5:00 pm
The last I heard was that they are Dyno testing some of the shocks together with the springs? Talk about a massive machine....
Rustem 1988
Post by Rustem 1988 » Mon Aug 12, 2019 10:04 am
The greatest change in vertical load occurs at the moment of maximum wheel movement? If the damping ratio is greater than unity, then how does this affect the change in vertical load?
