Underbody Diffuser Theory explanation please
Kiril Varbanov
147
Re: Underbody Diffuser Theory explanation please
Ogami musashi wrote: The diffuser area has higher pressure than the undertray area..in addition, "negative pressure" is not a correct term, the static pressure is always positive. It can be lower than a pressure above or below it but it is positive.
Correct, pressures are always positive, except for some strange cases (attractive forces, Casimir effect, etc), which do not apply here, I'll have to re-word it, thanks for that.
soumyakd
soumyakd
That is completely experimental. No insight currently. :/
KeithYoung
There are many things going on down there. It would take a long time to write that all up in a detailed manner. I do have an old article that covers a clean derivation of Navier-Stokes relating to the under floor of a car based on many simplifying assumptions.
Not sure if this is near the correct difficulty level for you, but the article is about Couette Poiseuille Flow Using Aerodynamic Navier Stokes Equations.
If it isn't explained well enough let me know. Happy to help.
KeithYoung
The article I posted above appears to be helping some people so I'll make a more detailed follow up about the Navier-Stokes related to the under floor. It will probably be a few days, I'm finishing up a project for a client followed by a busy weekend. It will also take a bit longer to write since I'm a bit rusty on Differential Equations, and I'll probably need to give a brief overview of DiffE for the next article to be a little more understandable and thorough.
I know this helped several people, but did it help the OP?
KeithYoung
Please let me know if this was helpful guys. It took a few hours to validate, then format with all the equations etc.
Not sure if the OP is around, but if this isn't helpful what can I do to make it better for you?
Couette Poiseuille Flow Using Aerodynamic Navier Stokes Equations for Race Car Underfloors, Validation using Boundary Conditions and the Continuity Equation.
olefud
olefud
79
I would have thought gauge pressure would be a useful concept when discussing diffusers in that it would be indicative of downforce.
shamyakovic
shamyakovic
-2
the diffusor cannot produce downforce by itself, it needs to be nearer to the ground to produce downforce, isnt it?
MadMatt
MadMatt
125
shamyakovic wrote:the diffusor cannot produce downforce by itself, it needs to be nearer to the ground to produce downforce, isnt it?
I don't really like the "diffuser" and "downforce" together. Imo, the diffuser doesn't create downforce in the same sense as a wing produces downforce, it just allows the air to expand. This diffuser has got a certain pressure recovery value from the base pressure (which can be found behind the car). This gives you a lowest pressure peak (located exactly where the diffuser starts) which is lower than the atmospheric pressure, therefore creating suction. If this suction is located between the ground and the car, it will suck the car down (obviously). The diffuser angle, shape and as you said its distance to the ground are important parameters that will define the pressure recovery.
See this picture for example:
You'll find lots of documents on diffusers on the internet and published papers!
shelly
shelly
136
Nice display of the suction peak at the diffuser kink line
twitter: @armchair_aero
riff_raff
riff_raff
I would disagree. The "diffuser" section should have a lower dynamic pressure than the underbody section ahead of it. If this were not the case, then the natural airflow would be in the reverse direction. A fluid usually tends to flow from a region of higher pressure to a region of lower pressure, right?. Diffuser is probably not the best term to describe the divergent aft section of an F1 undertray. A better term might be "extractor".
A: Start with a large one!"
henra
henra
riff_raff wrote: I would disagree. The "diffuser" section should have a lower dynamic pressure than the underbody section ahead of it.
In an incompressible fluid at the same altitude (geodetic pressure) the static pressure will decrease when dynamic pressure increases. (Bernoulli's principle). Static pressure + dynamic pressure (+geodetic pressue) = constant.
Since the static pressure is the one acting on the surface, you would want to have a higher dynamic pressure (accelerated airflow) since it would cause downforce. The flow will go from low dynamic pressure (=high static pressure) towards high dynamic pressure (low static pressure).
In the diffuser you have an increase in static pressure and a decrease in dynamic pressure from the throat to the exit. Highest overall dynamic pressure and therefore lowest static pressure will occur in the throat of the diffuser. This pressure difference (read 'suction') will cause acceleration of the air under the whole floor in front of the throat and thereby creating downforce due to static pressure underneath the floor being lower than on the upper side of the car.
shelly
shelly
136
In a 1-dimensional explaination you lose the reason why the static pressure is lower at the throat i.e. flow cornering around the kink line
IQ 240
07 Jun 2013, 02:06
There two conservation principle involved there:
Conservation of mass
Conservation of energy
The complete assembly of undertray+diffuser form a tube of section S1 and S2 respectively.
The quantity of air that enters S1 per second must be the same that exits S2 per sec.
Since we're dealing with particle moving we can also say that the speed at which the quantity flows through S1 must be proportional to the speed that flows through S2 i.e S1V1=S2V2.
Since S2 is larger that S1, V1 is greater than V2 so the speed in the undertray is the greater than in the diffuser.
Now why does the diffuser accelerates the flows in the undertray? This is because the air is slowed down in S2...but the density stays the same (at the speed a car travels); the word "expand" is misleading, the air is not stretching is actually just slows down...and thus a "vacuum" is created and since nature doesn't like it it will be filled...by air coming from the undertray...in other words the diffuser will pump air from the undertray to fill the whole S2 section and the S1V1=S2V2 principle will be verified, only that V1 will be even greater than if the diffuser wasn't there and S2 will be slower.
The peak acceleration at the location where the gradient of section is the greatest, since the difference of section will dictate the speed, the quickest and most abrupt change of section will lead the to steepest change in speed and this is where the diffuser starts.
Now, speed are defined, and they're changing, but energy's not. So basically the three (negating the internal energy of the system) forms of energies (derived from static pressure, height and speed) will varying to conserve the total energy of the system.
If speed increase, either potential energy (from height) or static pressure derived energy will need to compensate.
If we take one particle (in fluids dynamics a particle is not one molecule but a bunch of molecules, that is a small volume of air), its potential energy will not change (the particle will stay at the same height) so only the static pressure will decrease.
The static pressure will decrease and thus hopefully the pressure above the car will be higher thus creating a pressure differential and thus downforce.
Hope this helps.
Wouldn be better to put wing low pressure side on the end of floor,so low pressure from wing will "suck/accelarate air under floor,so in this case we dont have adverse pressure gradient-situation?
Ogami musashi
Ogami musashi
32
Hello IQ 240 :)
I think there are much more knowledgeable people on this forum to answer your questions :)
IQ 240
23 Jul 2020, 14:49
Hello IQ 240 :)
Yes but i find this forum very inactive.
