2017-2020 Aerodynamic Regulations Thread
jjn9128
769
Re: 2017-2020 Aerodynamic Technical Regulations
bjpower wrote:
02 Feb 2019, 15:25
I think shorten the cars would solve a few issues all round.
1. It would reduce the dependence on rake and make it more difficult to set up vortexes to seal the defuser. While amazing they can do it. The aero is so complex the fun has gone out of trying to figure out what each part does.
2. It's easier to get a shorter car around and other short car. So should help overtaking.
3. It will make the cars bulkier. Without the length it will make it more difficult to package everything in such a sleek fashion. While this should make the cars a bit draggier I think they would find it difficult to steer vortexes and the like around the bulk and rely on more simple aero that would not be as badly impacted by wake of the car in front.
Not a silver bullet but I really think it would help
They could certainly do with being shorter and more agile!! I reckon they would save a few kg from the minimum weight as well.
When TurboF1 illustrated this for our feature on how weight affects performance and I initially thought he'd made a scaling mistake. (Top is 2017 car, bottom is 2005)
The cars will look even longer this year because the RWEP is 100mm longer and the front overlap is 25mm longer.
#aerogandalf
Dipesh1995
104
Another image showing the extent of change in the past 10 years or so. Pretty crazy I think :shock:
jumpingfish
Dipesh1995 wrote:
02 Feb 2019, 18:28
IMO different scale. I tried to measure the size and McLaren is smaller. If W08's wheelbase is 3.726m then MP4-22 must be near 3.12m. Image
mzso
henry wrote:
01 Feb 2019, 01:56
Oh and more drag/longer lap times would lead to higher fuel usage and more lift and coast. Nobody likes that.
You speak as if it's impossible to change the fuel quantity or the fuel flow limit. Of course whatever they come up with they'll calculate fuel usage changes.
Zynerji wrote:
01 Feb 2019, 02:21
You do understand regulations doing this very thing is why things are so expensive now, correct?
Make them share their designs and data at every race and see how quickly they stop burning millions for hundreths of a second.
Dysfunctional, inadequate regulation does.
Of course what you suggest would quickly lead to near identical cars. No way something like that will happen.
Shakeman wrote:
01 Feb 2019, 12:32
I think it's more that the regulations allow teams to go in search of laptime deep into the diminishing returns areas of aero development.
We don't have to see a 2019 car to know that the barge board area is going to be mahoosively complex yet it does nothing for me as a spectator. The designs are far too complex for even the most expert of armchair aerodynamicist to analyse beyond sweeping brush strokes.
They'll keep burning the money because the teams know their solutions only work on their own aero concept so I only see regulations as the answer. Regulate all the aero noise generators off the car and regulate body work onto the car which tidies up the wake for the following car.
Exactly! We just need competent regulation. Although that would be a first for several decades... But maybe with Brawn and the contracts running out it will happen.
ENGINE TUNER
25
There is only 1 way to solve this dirty air problem in F1, set a maximum downforce level and that will force the teams to develop only towards to reduced drag. This is the only solution that worked for the engines by setting a maximum fuel flow rate. The is the only sensible way forward.
mzso
jjn9128 wrote:
02 Feb 2019, 15:39
https://f1tcdn.net/images/news/2018/int ... s-2005.png
Dipesh1995 wrote:
02 Feb 2019, 18:28
Ouch. Makes me think bjpower is spot on.
mzso
ENGINE TUNER wrote:
02 Feb 2019, 21:55
I'm certain it wouldn't work. In fact they wouldn't be working for more downforce but less drag AND more turbulence for the following car. It would be a big motivator to filthy up the air behind.
jjn9128
769
mzso wrote:
02 Feb 2019, 22:03
ENGINE TUNER wrote:
02 Feb 2019, 21:55
I'm not sure less drag and more dirty air equates... Obviously there are nuances but broadly speaking the lower the total drag the smaller the effect of the wake will be (Cpo deficit in the wake reduces with lower drag).
WEC are introducing a minimum frontal area, maximum downforce, maximum efficiency, and minimum drag in their 2020 rules. A similar rule in F1 could be quite effective.
#aerogandalf
Should the knowledge of turbulent wake increase, we might actually just be able to create a maximum area wake regulation?
jjn9128
769
I think it would be possible now to specify minimum/maximum and mean values of certain wake quantities in boxes at key positions behind the car.
I'm pretty sure the FOM aero group have been investigating that possibility when they got wake data from teams last year.
He talks about the wake for about 5 minutes. You can go back ~5 minutes if you want to see everything he says on F1 aero.
#aerogandalf
FPV GTHO
jjn9128 wrote:
03 Feb 2019, 15:55
mzso wrote:
02 Feb 2019, 22:03
ENGINE TUNER wrote:
02 Feb 2019, 21:55
Problem is WEC are effectively freezing the bodywork aren't they? F1 could do similar but you would be looking in car advantages for 12 months. Then WEC are also going to basically BoP the cars as well which clearly you can't do in F1.
jjn9128
769
FPV GTHO wrote:
04 Feb 2019, 10:55
I did say similar rather than identical :wink:
WEC aero homologating bodywork for 5 years, but teams can homologate a 2nd car in that period if they get it wrong or for a new manufacturer car/facelift. I don't think F1 needs to lock in a bodywork package for a year for teams to prove they are under a maximum downforce as they produce full aero maps for every car configuration anyway. As with the new pre-race scrutineering rules, where teams will self police but are also randomly selected for FIA checks or will be checked if a rival highlights an issue as with Haas and Renault in Monza, it could be more relaxed - but with strict penalties for non-compliance which make the possibility of being caught cheating financially risky.
#aerogandalf
jjn9128 wrote:
03 Feb 2019, 16:52
https://www.youtube.com/watch?v=Zkqr8oit-Os#t=30m18s
At 15 minutes - 21 minutes he also discusses downforce/drag for lap times. Very interesting and agood refresher that even dropping huge amounts of drag does very little for lap time compared to sticking on lots of downforce.
jjn9128
769
Just_a_fan wrote:
04 Feb 2019, 12:03
I found the bit of the video relevant to the discussion - Willem is always incredibly insightful and entertaining but it is a 2hr lecture (I'd recommend the whole thing if you have 2hrs spare on top of a number of his other online lectures) and I didn't think people would want to sit through it to get to the point in question.
Drag may not impact laptime as much as downforce but the effect on fuel consumption cannot be ignored, especially at a time when fuel use is limited. Limiting drag could be a major variable if we want flat out racing rather than fuel saving races, on top of what I think would be a huge impact for following in races.
#aerogandalf
Zynerji
110
mzso wrote:
02 Feb 2019, 21:48
henry wrote:
01 Feb 2019, 01:56
Zynerji wrote:
01 Feb 2019, 02:21
Shakeman wrote:
01 Feb 2019, 12:32
Every regulation made adds cost by forcing the teams to "study" the regulation, and find its limits. Thus, no matter how "competent" the regulators, their package is always the most expensive part of F1.
Post Reply
