F-duct was so cool. Watch the left hand in that video. Unlimited DRS. I can't recall; were any crashes caused by drivers altering downforce on the RW to early, or too late? There were no 'zones' limiting when they could use it, of course.
I don't believe there actually were any crashes. Ironically driving around with one hand on the steering wheel was more reliable than DRS is, because DRS has more moving parts that could put the wing stuck in open mode.
Do you have any data to support that claim? I can only think of a couple of scenarios where the DRS has physically failed, and then a couple of scenarios where there has been a crashed caused by aerodynamic failure of the DRS (ie air has not reattached to the wing after DRS switched off). I have not searched for the data myself because it's you making the claim.
The data is rather simple: There never were issues with the F-duct. Alonso's DRS in 2013 for instance failed: https://www.jamesallenonf1.com/2013/05/ ... n-bahrain/zac510 wrote: ↑31 May 2018, 10:55Do you have any data to support that claim? I can only think of a couple of scenarios where the DRS has physically failed, and then a couple of scenarios where there has been a crashed caused by aerodynamic failure of the DRS (ie air has not reattached to the wing after DRS switched off). I have not searched for the data myself because it's you making the claim.
I think if we'd had F-duct for another year or two of evolution we'd soon have drivers using the F-duct through a few corners on the track to optimise the downforce level by location on the track. Then it is getting potentially dangerous.
Agree with that! I think I'd choose mechanical failure over human failure, I must have a too low faith in humankindturbof1 wrote: ↑31 May 2018, 11:04The data is rather simple: There never were issues with the F-duct. Alonso's DRS in 2013 for instance failed: https://www.jamesallenonf1.com/2013/05/ ... n-bahrain/zac510 wrote: ↑31 May 2018, 10:55Do you have any data to support that claim? I can only think of a couple of scenarios where the DRS has physically failed, and then a couple of scenarios where there has been a crashed caused by aerodynamic failure of the DRS (ie air has not reattached to the wing after DRS switched off). I have not searched for the data myself because it's you making the claim.
I did choose my words carefully here, using the words "more reliable". There is less chance of a mechanical failure of the system, so it will react correctly to the driver input. I can't say that the driver input would always be correct however . I'd generally say that driving with one hand on the steering wheel would be more dangerous than the DRS because that driver input can go wrong.
But then it becomes pointless. Everyone will be using it at more or less the same places and no one will get an advantage from it.TankMarvin wrote: ↑31 May 2018, 15:53Didn't Mcl operate their F-Duct with the drivers left knee, keeping both hands on the wheel ?
I also agree with the point above - if it reacts predictably to the drivers input and it's used at the drivers discretion then that is racing... the ability to use the accelerator pedal is not reduced through tight corners just in case the driver tries to use too much of it.
I'd rather see a driver using an F-Duct at their discretion than a driver being articifically restricted to when and where they can use DRS.
So why don't all cars lap at the same speed today ? They all have the same pedals and a steering wheel ?DiogoBrand wrote: ↑31 May 2018, 17:57But then it becomes pointless. Everyone will be using it at more or less the same places and no one will get an advantage from it.TankMarvin wrote: ↑31 May 2018, 15:53Didn't Mcl operate their F-Duct with the drivers left knee, keeping both hands on the wheel ?
Do you remember when we first had DRS and during qualifying you could use it all over the track? That was really good because some teams had to make a compromise between a big DRS flap or small DRS flap, the former favouring qualifying and the latter favouring the race. A race is always good when the fastest cars in the race are different to the fastest cars in qualifying. Unfortunately when they introduced fixed gear ratios they limited the qualifying use of DRS.DiogoBrand wrote: ↑01 Jun 2018, 19:05When did I say "if you give everyone the F-Duct every car will lap at the same speeds"?
I said that if everyone has it, every driver will use it on the same places, and the difference of performance of all cars with F-Duct versus all cars with no F-Duct will be pretty much zero, so it doesn't add anything to the show. Not so hard to understand.
