Rear wing flex and FIA regulatory test 2021
OO7
OO7
171
Re: Rear wing flex and FIA regulatory test 2021
Red Bull rear wing wobbling while launching off the line at the start, from 0 to 5 - 15 mph.
Chene_Mostert
-2
OO7 wrote:
18 Nov 2021, 11:11
https://i.imgur.com/QJhbqf1.gif
jesus, RB is getting the whole pit complex to wobble. Adrian, as always, thinking outside the box.
"Science at its best is an open-minded method of inquiry, not a belief system." - Rupert Sheldrake
Big Tea
99
Chene_Mostert wrote:
18 Nov 2021, 14:45
OO7 wrote:
18 Nov 2021, 11:11
:mrgreen:
OO7
OO7
171
18 Nov 2021, 14:45
OO7 wrote:
18 Nov 2021, 11:11
The Red Bull of Perez (behind Max) serves as a reference that shows the rear wing does bend sideways quite significantly.
El Scorchio
Are there any comparisons available for other cars? I've never really noticed how the rear wings behave on race start.
RZS10
359
AT practice start from this year:
https://streamja.com/aXX1z
OO7
OO7
171
RZS10 wrote:
18 Nov 2021, 15:56
The whole rear wing vibrates in that AT practice start gif. With the Red Bull it just angles to one side then straightens up, no vibration.
RZS10
359
Well it's hard to judge from a gif that has two frames, isn't it?
El Scorchio
RZS10 wrote:
18 Nov 2021, 15:56
Thanks! I'd imagine they probably all behave quite similarly, but who knows! As you say the gif of the RBR could be a little misleading.
OO7
OO7
171
RZS10 wrote:
18 Nov 2021, 17:28
I created the gif from the original footage and there's very a very minor constant vibration throughout the rear wing, then it just leans to one side and straightens out again. The footage was from the replays shown during the Safety Car period on lap 8.
LM10
120
OO7 wrote:
18 Nov 2021, 17:57
RZS10 wrote:
18 Nov 2021, 17:28
What kind of benefit do you expect from a sideways wobbling rear wing?
JordanMugen
82
LM10 wrote:
18 Nov 2021, 18:10
OO7 wrote:
18 Nov 2021, 17:57
RZS10 wrote:
18 Nov 2021, 17:28
Perhaps it causes the flow to become unstable, separate, stall and thus shed drag?
Though the downforce and drag created by the rear wing at under 25 mph is negligible (under 40 kg?), and you'd want to have the downforce anyway for the extra rear traction.
Big Tea
99
LM10 wrote:
18 Nov 2021, 18:10
OO7 wrote:
18 Nov 2021, 17:57
RZS10 wrote:
18 Nov 2021, 17:28
just a 'passing thought' but what effect would the disrupted air from that have on a following (or passing) car?
Stu
Big Tea wrote:
20 Nov 2021, 03:49
LM10 wrote:
18 Nov 2021, 18:10
OO7 wrote:
18 Nov 2021, 17:57
Not as much as the outwash from the front wing/barge-board combo (the air from the wing is moving upwards as it is). At these super low speeds (where the cars do not run on-track) the effect would be zero. It does suggest that the structure of the wing is designed to operate in the loaded state, rather than unloaded (this phenomenon is largely unnoticeable during running - except for in super-slow-mo shots over kerbs - a lateral force rather than longitudinal).
Much noise has been made about the RB upper element flapping during practice in Brazil, this looks to have been caused by a DRS mechanical failure, during scrutineering checks if this caused the flap to exceed the 85mm permitted gap it would have lead to a DSQ (as suffered by Mercedes).
When the DRS is open the top flap still generates downforce, the pivot locations are closely controlled (at the rear edge of the flap), making it physically impossible for the airflow to over-open the slot gap from that mechanically allowed by the mechanism.
What is interesting this weekend is that we are seeing what Red Bull were going to the stewards about last week. They actually believe that Mercedes are flexing the rear of the lower element (this is not a tested item during the load tests as far as can find). If (potentially a big if!) this is what Mercedes are doing, then hats off to them, a great play and obviously something that Red Bull have also looked at but not dare race!!
According to AMuS this year's TD will be extended:
The word in the paddock is that the rules makers have already given the ten teams a heads-up. The technical directive, which was only introduced in the summer as a reaction to allegedly too flexible rear wings - pushed by Mercedes against Red Bull - is to be extended to include a new passage with a special test. Specifically tailored to Red Bull's complaint.
Also says this will come into effect starting in Saudi Arabia
https://www.auto-motor-und-sport.de/for ... egel-test/
Post Reply
