2022 Tyres Thread
Jolle
132
Re: 18-inch wheels to be introduced in 2021.
Blackout wrote:
21 Apr 2021, 11:38
jjn9128 wrote:
20 Apr 2021, 15:26
More shots of the Mercedes testing. IMO the rims don't look too bad but the tyre look oversized, especially in the side profile. I find the same thing with the F2.
@AlbertFabrega
https://pbs.twimg.com/media/EzasYzdUYAU ... ame=medium
https://pbs.twimg.com/media/EzasZLmVEAM ... ame=medium
Did Mercedes and the others build specific, bigger diameter, wheel drums for these wheels or do they simply close the gap between the hub and the rim (on the inside face)?
Probably a combination of both. Modifying the 13” design to fit the 18” rims.
jjn9128
769
Blackout wrote:
21 Apr 2021, 11:38
To be honest I'm not entirely certain what they're allowed to change. Got to be some suspension/upright adjustments for the different loading. Beyond that I don't know if they're running 2022 sized brakes to accurately simulate the warmup?
#aerogandalf
Bottas testing for Mercedes today
mzso
59
They kept the tires so fat, it barely looks different.
jjn9128 wrote:
21 Apr 2021, 11:47
Blackout wrote:
21 Apr 2021, 11:38
Alfa tested these big drums, but they seem to have current discs
jjn9128
769
Blackout wrote:
13 May 2021, 19:27
https://www.racefans.net/wp-content/upl ... 5-19-3.jpg
I don't think they're allowed to run the 2022 brakes because it's ostensibly a 2019 car.
#aerogandalf
Haas testing the 18-inch wheels
JordanMugen
82
Vyssion wrote:
22 May 2017, 12:00
Before that, the 1979 Alfa Romeo Tipo 17 used 635mm x 241mm R15 for the front and 737mm x 330mm R13 at the rear.
It seems Alan Jones and Neal Oatley are also talking about a choice 15" rear tyres in the 1981 film "Gentleman lift you skirts", so there were both 15" fronts and rears available up to the point that FIA mandated 13" tyres, so I don't understand where the notion of devotion to 13" tyres & high profile rubber came from, from some F1 fan quarters? :?:
Just_a_fan wrote:
01 Mar 2021, 14:59
Tyres are provided by the nominated supplier. The tyre supplier doesn't want to make 13 inch tyres because they can't market them to boy/girl racers in their 2.0 litre hatchbacks.
1979: 635mm x 241mm R15
vs 2022: 725mm x 270mm(IIRC) R18
By any measure ( 635 mm - 15" ) / 2 = 127 mm sidewall in '79 and ( 725 mm - 18" ) / 2 = 134 mm sidewall in '22 are very similar sidewalls. :?:
Why a devotion to 13" tyres, when F1 cars historically used 15" low profile front tyres in the 1970's up to the point 13" was mandated?
For reference, the 1979 Alfa Romeo Alfasud Ti 1.5L hot hatchback was available with optional 16" wheels for maximum boy/girl racer bling! The Ti shod in 195/40 R16 would've been positively jaunty at the time, and had a similar 40% profile to the 225/40 R18 found on a modern 1.75L Alfa Romeo Giulietta Veloce. :lol:
jjn9128
769
JordanMugen wrote:
02 Dec 2021, 15:46
Vyssion wrote:
22 May 2017, 12:00
Just_a_fan wrote:
01 Mar 2021, 14:59
IIRC 13" were mandated at the rear before they were at the front. From the rulebooks I have by '77 the rears had to be 13" but the fronts were free. I'm not sure why 13" is so beloved, what I object to is the tyres getting taller with the shift to 18" rims.
#aerogandalf
Stu
jjn9128 wrote:
02 Dec 2021, 15:54
JordanMugen wrote:
02 Dec 2021, 15:46
Vyssion wrote:
22 May 2017, 12:00
Just_a_fan wrote:
01 Mar 2021, 14:59
Same here, not that I am a fan of the low-profile look, but the shift to larger rims should have been done in conjunction with maintaining the OD of the existing tyres. The new solution is being pushed as a low-profile, but really isn’t much different to that currently fitted. In the current safety-conscious age, surely someone has pointed out that drivers will be able to see less because of the extra tyre height?
jjn9128
769
Stu wrote:
02 Dec 2021, 20:15
Plus with the covers, just use a 15" or 16" and slap the cover on to make pretend it's an 18" wheel underneath. Most punters wouldn't know the difference.
#aerogandalf
With aero covers
Stu wrote:
02 Dec 2021, 20:15
It is a much lower profile sidewall, i would say it's now comparable to what LMPs and GT cars have run for the last decade at least.
It is still taller than what "extreme" road cars use, i'll give you that.
Not much problem with taller tires for the driver i think, when they look into a turn they watch their inside wheel over the curb/apex, and on wheel to wheel action it literally gives them a bigger object to see.
djos
113
Contact:
I do like them, but I'd have prefered they didnt make the tires so tall in the process.
"In downforce we trust"
The front tyres should've been 16"...
