PhillipM wrote: ↑Sat May 28, 2022 9:59 pm
Feliks wrote: ↑Sat May 28, 2022 2:36 pm
Well, why would someone need an outdated gasoline engine?
Andrew
'Cause the rest of the world has an IQ above the temperature of the ice.
Peltiers are horribly inefficient devices.
I've been fighting them for 20 years and I know it's not as bad as you think about them ..
Here you have photos from my show, how the 21 Watt car lamp shines from a temperature difference of 25 degrees Celsius .. You can see that touching the "engine" with your hand is not a threat, except for the experience of "cold - warm" ..
And also on how much you can see that the amount of electricity from this ice is much greater than from the heat from a finger .. semiconductors like cold .. and Ice has an exceptionally large "hidden heat", so it takes moments to melt with it ..
It's only the first "" my experience "showing that the cold can also be an electric current ..
There is so much cold that we do not care much about efficiency.
Andrew
