It is a shame if the only fix for the ride height was a modification to the floor. If they had been able to get it back to the lower ride height you'd imagine making up the 3/4 tenths to Mcl would have been feasible.atanatizante wrote: ↑Tue Apr 15, 2025 1:11 pmSome other comments from the Italian media:
The talk is about LEC's choice of a softer front suspension setup than HAM due to his driving style, which requires a pointy front end:
"Thus, he has a more elastic torsion and anti-roll bars to have a more focused and precise front end. The shock absorbers are much softer and have more progressive travel due to the greater air-to-oil ratio calibration than HAM`s standard shock absorbers. This way, the shock absorber has a longer travel, which in turn needs new rocker arms that cope with lower forces induced by this increased elasticity. In addition, the third shock absorber must be also more softer set up in order to compesate for this increased in elasticity ... Also they said that the floor now has the same level of downforce with the car`s ride height rised as the level when the car was running lower and thought it was the optimal after their results in CFD & WT. The increased in downforce level was done by altering the Venturi channel and moving the CoP more toward the rear of the car, which stabilize the rear axel in mid and high speed corner but in turn this is inducing a more understeery car, something that LEC can cope better due to this softer front suspension setup and those micro-wheel correction that he is doing in all the corner phases ... "
I was under the impression the plank issue only really came to the fore after FP2 in Australia, while the floor introduced in Bahrain was planned since before testing. Would make the timelines impossible. Also could a team turn around a floor design and manufacture in 3/4 weeks, seems unlikely.
Seems more likely the floor was an iteration of the launch spec floor which helped the ride height issue but wasn't designed purposefully for it as they weren't aware of the issue during design and fabrication. All guesswork on my part. Happy for someone to give an alternative read on it.
