3jawchuck
3jawchuck
37
Re: Mercedes Power Unit
Why would they be using multigrade oil?
Craigy
84
3jawchuck wrote:
17 May 2017, 22:18
Cold starts in winter while they scrape the ice off the windscreen?
The posts on this thread are weird.
3jawchuck wrote:
17 May 2017, 22:18
The high quality of the base-stocks and selection used at that level means they're multigrade even without VI's or similar.
MrPotatoHead
53
Craigy wrote:
17 May 2017, 23:05
3jawchuck wrote:
17 May 2017, 22:18
I chuckled.
And yes. Some strange posts here for sure.
Mutligrade oil is still used in hot climates. It has it benefits.
621
what people are calling an oil or multigrade oil is a synthetic lubricant with a substantial proportion of esters ......
its viscosity varies less with temperature than does the viscosity of the natural ('straight') reference oils that form the SAE grading system
so it is impossible to characterise the (F1 'oil's) viscosity as anything other than multigrade
nobody is using a lubricant whose viscosity varies with temperature as much as a straight-grade oil's does
hardingfv32
hardingfv32
32
Use of the word 'oil' seems inappropriate.
The most advanced 'lubricants' have very high viscosity indexes. The viscosity changes very little with changes in temperature.
Brian
Ester or Polyalphaolefin based, or is it something even more exotic?
hardingfv32
hardingfv32
32
Something like 1-butyl-3-methylimidazolium bis(trifluoromethylsulfonyl)amide. It does not decompose until above 472 C. In a race engine it will never loose any of its properties so it is lasts forever. I overstated the Viscosity index: 159 for the stuff verses 128 for 0W-10 engine oil. This is an ionic liquid… a new type of chemical (about a decade old). Solids made into liquids. Lubricants are just a very small part of the possible uses of this family of chemicals.
COST is an issue at $1000-2000 per qt or L but not anything for those involved with F1. Currently generally only made at the lab level. So there is a small cost associated with the current 5L lubricant burn per race!
Brian
What is the source for off the shelf synthetic oils?
And two... That second ionic liquid thingy where does that come from?
hardingfv32
hardingfv32
32
I am a engine builder and club racer looking for an advantage…. NOT a chemist.
Base stocks for synthetic oils come from oil. natural gas. coal. plants. animals etc.
Ionic liquids probably similar sources but also chemicals that you normally think of as solids at room temperatures. Things like phosphonium. phosphate. sodium etc. The main theme of ionic liquids is the capability of using solids in a liquid….AT room temperature. I have noticed that the IL's used for lubricants are often many of the same chemical families used as additives in std oil. That is a non-chemist observation.
The IL quoted is a 'neat' lubricant… used 100%. I could not source it anywhere in the world for purchase. Interestingly this IL cannot be used as an additive. I use a different IL that will mix with synthetic oil that I found from a source in Germany. 7-8 grams per 1 qt/L of oil…. at a cost of $30-40. That is the per qt application cost. Liquid gold???
A lot of trial and error developing IL's. There seems to be two parts to every formulation but how they might enter act cannot be know for certain.
Brian
Hmm. There are anionic and cationic polymers used in water treatment. Extremely slippery substances if i do say so myself. Dropped a few beakers because of said sliperyness. Billions of polymer chains in each drop of goo. They are pretty much solids in neat form and you mix them out in water. I wonder if they are related. Acrylimide or something like that.
hardingfv32
hardingfv32
32
It would be my opinion that 'slippery' is not the main driver of lubrication formulation in these days. Very low viscosities are what reduce friction but this creates problems for the cylinders. The bearings have completely different lubrication requirements than the cylinders. These new formulations have anti-wear properties to deal with this.
As an example the IL mentioned as a 10W oil has the same wear properties/rate as a 30W Mobil 1 oil.
Brian
hurril
hurril
hardingfv32 wrote:
24 May 2017, 17:49
Brian
Asking as a n00b, would you mind elaborating on why, or in what way, the cylinders and the bearings have different lubrication requirements?
Bearings rely on a hydrodynamic film, in other words as long as there's oil pressure and flow past the bearings, the journals don't touch the bearing. Except of course during the small amount of shear during the power stroke. A cylinder relies on splash lubrication, and the oil on the thrust surface of the cylinder skirt deals with far more shear forces than the crank bearing ever will.
Low viscosity is good for reducing pumping losses, but higher viscosity sometimes but not always has higher oil film strength, which is good for lubricating things without oil pressure(ie pistons,gears,chains etc).
