2018 French Grand Prix, Le Castellet, June 22-24
Locked
Tire Choices
Re: 2018 French Grand Prix, Le Castellet, June 22-24
Circuit length? Laps for the race? I'm guessing 52 or 53?
Some things that are apparent, a one stop is going to be difficult to pull off. The tire wear is much more severe than in Canada. The first and final sectors are particularly hard on the tires with traction limited long radius corners. Second, fuel consumption will be an issue.
This circuit has 4 long flat out sections so too much drag can hurt, at the same time you need good aero because all the non flat out corners require lots of downforce.
Sadly I don't see many overtaking opportunities, realistically turn 11 is the only place to overtake. Otherwise it's essentially impossible as the other straights end with chicanes. Tire wear will be the only saving grace for any overtaking.
djones
All them blue stripes look headache inducing.
Vasconia
Straights don´t look that long and as it has been already mentioned I see only one decent place to overtake. So, I hope tha this part works well alongside a higher tyre degradation. I hope we can see a two-stop race.
Moreover, I am interested to see how much Mercedes will improve with the updated PU.
cplchanb
Did they set up any temp grandstands along the course? From the photo the track looks very barren of any real spectator viewing areas in almost all the corners
FrukostScones
162
Is this Paul Rick's yard?
Juzh
161
godlameroso wrote:
18 Jun 2018, 13:42
5,842 km/lap
53 laps
309,626 km race distance
astracrazy
31
If you thought Canada was bad this will be worse.
Watching that video I can't see where overtakes are going to come from? The straights are kinda long but the corners leading to them are all quick so the drivers will be to far back. The straights all seem to lead into quick corners too so the breaking opportunity won't be there.
The corners are bumpy and some off camber so I guess hopefully the drivers struggle.
muramasa
58
The pit exit lane joins the racing line? That's bit of flawed design, how could they still hold races here, or even testing sessions for that matter.
F1NAC
163
that chicane entry is confusing
falonso81
Unless this turns into a chaotic race mainly because of accidents/sc, this is going to be a borefest grand slam. Awful track design for modern F1. Let's hope for some entertainment.
Looks like front grip will be at a premium, Red Bull could be the car to beat.
roon
412
Locked
