Renault F1 R.S. 19
ScrewCaptain27
577
Re: Renault F1 R.S. 19
Albert Fábrega: “The Renault’s bargeboard area is crazy!”
- Serj Tankian
Not crazier than the others, but the multiple vanes behind the big bb + the small bb are unique to the RS.19 AFAIK
gosswilliams75
LA RENAULT A MELBOURNE
The Renault DRS system is still fluttering up and down on the straights - doesn't look good, if nothing else it must be going past the limits for opening.
rayden
rayden
that was just the shadows from the fencing near that braking zone.
Via AMuS
PowerandtheGlory
PowerandtheGlory
Neno wrote:
16 Mar 2019, 13:36
Heavy garbage this car is. That's my technical expertise.
Certainly a disappointing quali. The possibility that the mclaren is faster with the same engine, will start to put pressure on the hierarchy at Renault. Hope they figure out the car.. MERC domination in the engine department...
“I don't believe in luck, luck is preparation and taking your opportunity” Ross Brawn
via motorsport.com
carisi2k
Disappointing but considering the trouble Renault had with both cars on Friday it isn't surprising. I was surprised that neither Renault improved on their second run in Q2. It looks like they can't turn the tyre on for a single lap. Maybe the race will be better.
227
I'm not worried. The car looks good on the track. It may be a matter of tweaking the setup to get more out of it. I don't think Mclaren is a league ahead.
The bigger challenge is the Haas, that is strewn with Ferrari 2019 parts. They seem to be out of reach for Renault.
carisi2k
The Renault twitter feed also mentioned that both guys got traffic on their final runs which they both seemed to have suffered from the whole weekend.
Just noticed this new vane
Edit: Thanks for that pic MtthsMlw
carisi2k
ringo wrote:
17 Mar 2019, 04:32
Except it didn't look good on the track. Martin brundle said as much on friday saying that probably only mclaren, racing point and williams were worse through the quick s bends. Atleast the cars were quick off the line.
SmallSoldier
SmallSoldier
473
carisi2k wrote:
ringo wrote:
17 Mar 2019, 04:32
I would take whatever Brundle says with a grain of salt... On boards from the teams show the likes of Mclaren on the faster side when it came down to turns 11 - 12.
Brundle also said that the Ferrari was more composed, planted and seemed faster than the Mercedes and that turned out to be off the mark too.
The onboards for the cars actually show that the Renault looks very solid and planted through the lap.
aral
aral
26
Once again, I would remind you that the topic of this thread is specifically the RS 19. I have removed some posts that were comparing Merc, Ferrari and RB as these were off topic. If you want to compare performances in the race, could you please use the race thread, and keep this thread for purely technical matters pertaining to the Renault.
