2019 Aston Martin Red Bull Racing - Honda F1 Team
dren
226
Re: 2019 Aston Martin Red Bull Racing - Honda F1 Team
HPD wrote:
21 May 2019, 13:25
It would be a good result to divide mercedes
Verstappen has split them in FP1. He's in the mix, Gasly looks a bit off so far.
Honda!
HPD
198
Yes, something disappointed with Gasly. But it's fast... in TR it was (or so it seemed).
A good driver adapts to any car..
Edit: it seems that the first sector is now our problem.
lio007
312
Any information what PU-spec Max is running? Is Spec-1 still in the pool or too much damaged?
HPD
198
Skyf1: Max has been in the garage for a while, with some change currently taking place on his car. Red Bull mechanics are working rather feverishly around the RB15's front end.
dxpetrov
-7
HPD wrote:
23 May 2019, 14:36
Firstly, Galsy is not an animal, so it's "he". Secondly, he was fast compared to whom? Hartley?!
dren
226
Yeah, it's hard to say if Gasly is having issues adapting to the RB or if that's just his normal pace. Albon is looking good in the STR.
Honda!
Stef
Max back on track
GhostF1
110
Debris caught and damaged one of the coolers is the latest I heard on Sky. While they fixed that, they made a setup adjustment, Max just said car is handling much worse now
Sieper
73
After that he did a long run I think. He wasn’t passing leclerc who was doing a long run for sure. The balance on high fuel was bad apparently.
Marti_EF3
56
I think RBR are 2nd fastest here. Shame with that water leak, because the true pace on one lap is an unknown right now. But given Gasly time, I think we are closer to Merc, but not enough to challenge pole... Maybe split the Mercs at best. Did they any long runs to know pace?? What is surprising is how Albon is doing with the STR, he is almost on pace with Gasly and the Ferraris :shock:
Can't tell anything from long runs, they do 2 or 3 fast laps at most then charge batteries and try again.
Capharol
21
Contact:
godlameroso wrote:
23 May 2019, 18:27
Gasly had the same pace as Vettel ..... should say enough imo
etusch
131
Gasly still uses spec 1 for first two FP sessions doesn't he?
loner
16
hopefully RBR will shift their focus more on their fragile driveshaft and improving their suspension which obviously Mercs outsmarted them with... car looks mighty they need to find new ideas about the suspension
how professional Mercs exploiting every thing by every which way.
para bellum.
McMika98
-24
Gasly seems pretty happy with setup and how he did today but he was less than a tenth quicker than Albon who went a lot early. Come quali he could be relegated by Alfa and Haas boys if he does not step up.
