1:8 McLaren Honda MP4/4
1158
47
Re: 1:8 McLaren Honda MP4/4
Post by 1158 » Fri Apr 26, 2019 10:21 pm
Happy to help. I'm following this with great interest. I love the details in the model and it's such an iconic car.
ajdavison2
Post by ajdavison2 » Sun May 05, 2019 2:30 pm
Thanks for the info Smirkoff, when I end up getting the oil radiator I might look into buying yours. As for the temperature sensors I think I'll just dot them around in sensible places based on peoples' suggestions. (Brake calipers, exhausts, radiators etc).
Anyway time for an update. I'll be posting the updates from Issue 2 and 3 today as there isn't really much to post. I'll also be starting to refer to them by the stage numbers that are in the magazine rather than Issue X part Y. It'll just be stage Z.
So, stage 7. Assembly of the engine. Parts supplied with this stage, starting from the top left are the plug caps, alternator belt, the alternator front and rear, pressure regulator top, air chamber end, Honda logo plate and right cam cover.
Assembly of this stage was pretty straight forward, not really much to show. Just involved gluing the logo plate to the cam cover, and screwing said cover to the engine block. The pressure regulator and air chamber end were glued to the plenum chamber, and the alternator front and rear were glued together. The photos of the front and rear of the engine block, as well as the assembled sup-components are below:
Front:
Rear:
Stage 8:
Assembly of the front left upright. Parts supplied with this stage are, from the top left, left front brake duct, left front upright lower, left front upper arm end, axle shaft, front axle inner, front axle outer, left front upright upper:
Assembled front left upright:
Stage 9:
Assembly of the front left brake. Parts supplied with this stage are, (weirdly) the left monocoque side panel (middle), left radiator housing base (left), and left radiator housing (right). These aren't used in this stage but oh well.
This stage of the magazine also covered the inking process mentioned previously, the parts that were inked were the brake calipers and disks of the front left, the area holding the clutch plates on (which had to be disassembled), the end of the axle shaft, and the alternator. I forgot to take before and after comparison shots side by side so you can refer back to previous posts to compare. My bad.
Inked disks:
Inked calipers:
Inked engine front:
Inked axle shaft:
Inked alternator:
Assembly of the front left brake, the assembly for this was quite interesting as it enables the brakes to be spun. The disk was slotted onto the axle shaft, and the calipers were set onto the side of the disk, aligning with pins on the left front upright, these were glued in place with a combination of masking tape and paper strips keeping the parts from contacting while the glue dried, with the paper strips cut with a knife and slid out with tweezers afterwards:
Stage 10, assembly of the left intercooler. Parts supplied with this issue are the intercooler outer (top), intercooler inner (bottom), and heat exchanger (middle). The intercooler outer was inked and then the inner and outer parts were glued together (not pictured).
That's it for this stage.
Thanks guys.
Alex
ajdavison2
Post by ajdavison2 » Sun May 19, 2019 2:42 pm
Hi everyone, update time again.
This week I'll be covering issue 4. Which is stages 11-14. Enjoy.
Stage 11: Assembly of the front right upright. Part's supplied with this stage are very much the same as the part's supplied for the front left upright, so I won't post another photo of those. But I realise I didn't post many interim assembly photos last time so here you go.
Assembled front right upright, minus the axle shaft.
Stage 12: Assembly of the front right brake. Again the parts supplied were the same as the front left so I won't bore you with the details. However again, I'll post some more interim details.
Inner and outer brake discs prior to inking.
Interim assembly of a brake caliper and pad.
Interim assembly of all the calipers and pads, the black patches are where the paint has been scraped away prior to gluing.
Assembled front right brake and upright, showing the inked details. The strip of paper is a temporary measure to enable rotation of the disk once the glue is dried, it basically stops the glue catching the disk by accident. This strip of paper will be cut and pulled out with tweezers.
Stage 13: Assembly of the solenoid valve unit. Parts supplied with this stage:
Top left - floor support left
Next down - floor support right
Next down - intercooler balance pipe left
Next down - intercooler balance pipe right
Bottom left - sticker sheet
Top right - radiator inlet left
Next one down - radiator inlet right
Next one down - radiator outlet left
Next one down - radiator outlet right
Plastic sprue top left - battery
Plastic sprue bottom left - solenoid valve mount
Plastic sprue top middle - pop off valve sensor
Plastic sprue top right - control solenoid valve outer
Plastic sprue bottom right - Control solenoid valve inner
Firstly, the parts were removed from the sprue carefully, and any flash left on was trimmed with a scalpel and sanded off where possible without damaging the finish or paint. Then the solenoid valve outer, and solenoid valve inner were both glued onto the solenoid valve mount.
Next the pop off valve sensor was glued onto the projection at the bottom of the solenoid valve mount.
The battery was prepared by sticking the black number 4 sticker over the already black stripe on the battery unit. (For some ridiculous reason that I can't work out) :wtf:
Prior to sticking the sticker on.
And after sticking it on.
As you can all see that made a lot of difference to the model.
Stage 14: Fitting a rear tyre. Parts supplied with this stage are the rear wheel and wheel nuts x5.
The rear tyre supplied earlier was pushed onto the rear wheel, taking care to align the valve on the wheel with the "G" in Eagle. It's actually a right job getting the tyres on the wheels, lot's of fiddling and prying without scraping the black paint off.
The wheel nuts were also threaded in this stage by screwing them onto one of the axle shaft ends from the front brake assemblies. (Not pictured)
The remaining stickers from stage 13 were placed onto the radiator inlets, outlets and intercooler balance pipes.
That's it for this week folks.
Thanks for reading. As usual if there's anything you want to see in detail just let me know.
ajdavison2
Post by ajdavison2 » Sun Jun 16, 2019 8:11 pm
Hi everyone,
Back again for another update. Quite a few bits and pieces on this months as well as a trial of some of the decals. I'll also be doing a round up of where we are at the minute which I think i'll do every 5 issues.
So first up, stage 15. Assembling the left intercooler. Parts supplied with this stage were the left radiator mesh (top left), left intercooler top (top right), left radiator (bottom left) & left intercooler bottom (bottom right).
The magazine recommended the radiator and radiator mesh be inked as detailed previously, see below.
This stage also needed the left intercooler from stage 10, and the left intercooler balance pipe from stage 14.
The intercooler bottoms and tops were glued onto the intercooler with the balance pipe inbetween as seen below.
Stage 16: Assembling the left radiator housing. Parts supplied with this stage are the monocoque (exciting).
This stage also required the left radiator housing/stage 9, left radiator housing base/stage 9, left monocoque side panel/stage 9, battery/stage 13, left floor support/stage 13, left radiator inlet/stage 14, left radiator outlet/stage 14, left radiator/stage 15, left radiator mesh/stage 15.
First up the test fitting of the floor support in the radiator housing, this was pretty tricky to get lined up right with the correct projections in the right places and orientation. (This was dry tested for now)
Next up was the fitting of the floor support in conjunction with the radiator mesh. This presented the problem of creating a bend in the floor support which would absolutely not go away despite my best efforts to jig it around and also meant it would not stay in place without gluing. Anyway I managed to make them fit the best they could and get the parts glued. As you'll see soon, this actually didn't make much difference in the end. The bend is visible in the photos below.
Next up was the gluing of the battery to the radiator housing.
I forgot to photograph the following, but the radiator housing base was also glued to the radiator housing at this point.
Next was the assembly of the left radiator. The radiator inlet and outlet were both glued to the side of the left radiator.
Next up was the preparation of the left monocoque side panel and assembly to the monocoque. The paint was stripped and adhesive applied.
Stage 17: Assembly of the left radiator housing (continued). Parts supplied with this stage are the head panel (top left), monocoque endplate (top right), intercooler outside right (bottom left), intercooler inside right (bottom right). The magazine recommended inking the intercooler which is shown in in the photo below.
The radiator was glued to the radiator housing and temporarily secured with masking tape. As you can see from the last photo below, the bend in the floor support isn't really an issue or noticeable. Out of sight, out of mind.
And see below with the masking tape removed once the glue had dried.
Next the right intercooler outside and inside were glued together.
So that's that issue done. Now for the first 5 issue round up. Here's where the model is in it's current state of components.
And also, my first attempt at doing some of the decals. Oh my good god they are fiddly little so-and-sos. (For anyone that's not english, that essentially means that they're little sh*ts to put on basically). Overall my first try went quite well, apart from the "o" on the back of the rear wing. I really love how the decals just bring a sense of completeness and authenticity to the model.
I'll probably do the ones on the monocoque when I get a chance, but might wait until I've got more parts that need decals on them. I've also got issue 6 with me as well at the minute, so when I get round to doing that then you'll all be as up to date as I am with the model progress as currently my posts have been 1 issue behind what is in my possession. It is what it is.
That's it for this week everyone, thanks for reading. As usual if there's anything you'd like to see more detail of just let me know.
Cannonballer
Post by Cannonballer » Mon Jun 17, 2019 5:51 am
Nice work! I look forward to the next update.
Wazari wrote: There's a saying in Japan, He might be higher than testicles on a giraffe...........
ajdavison2
Post by ajdavison2 » Sat Jul 13, 2019 6:05 pm
Hi everyone!
After a busy few weeks away at the Austrian GP I'm finally getting round to posting this months updates. I'll be doing issue 6 today, and I also have issue 7 with me as well which I'll start this weekend probably, maybe aiming to post that after tomorrows race.
Anyway away we go with issue 6. Much of this issue is just repeating other issues, so there's not a great deal to show.
Stage 18: Assembly of the right radiator housing. Parts supplied with this issue are: Right radiator housing base (left), right radiator housing (right) & right monocoque side panel (bottom).
Required from previous stages are:
- Solenoid valve unit (stage 13)
- Right radiator inlet (stage 14)
- Right radiator outlet (stage 14)
- Monocoque (stage 16)
- Right intercooler (stage 17)
First up the solenoid valve was glued to radiator housing.
Next up the right intercooler, radiator outlet and inlet were all prepared by scraping the relevant paint off. Pictured below on the inlet and outlet pipes.
Next was the the preparation of the monocoque and right side panel. The panel was dry fitted and then marked around.
Then the paint in the marked area was scraped away on the panel and the monocoque before the panel was glued to the monocoque.
Stage 19: Assembly of the right intercooler. Parts supplied with this stage were the right radiator mesh (top left), right radiator (bottom left), right intercooler top (top right) & right intercooler bottom (bottom right).
Parts required from previous stages were:
- Right floor support (stage 13)
- Right radiator inlet, outlet, housing & housing base (stage 18)
Before doing anything else the right radiator mesh and radiator were both inked.
The assembly for this stage was more or less the same as the left radiator housing from my previous post so I won't duplicate the photos here. However what I noticed was that I had the same problem with the floor support having a bend in it. This just seems to be the way the model is built, and I lack the tools to enlarge the hole in the mesh. It also doesn't make any difference as you can't tell it's bent when assembled.
This stage went as far as gluing the radiator mesh, floor support & radiator housing base together. For whatever reason this stage didn't include the assembly of the radiator and right intercooler onto the radiator housing. If I was being cynical it would be because it prolongs the subscription and the ££££.
Stage 20 up next. This stage covered the assembly of the turbo inlet ducts. Parts supplied with this stage were the left turbocharger air intake outside (top left), left turbocharger air intake inside (middle left), right turbocharger air intake outside (top right), right turbocharger air intake inside (middle right), turbocharger air intake adapters x 2 (bottom).
- Right intercooler balance pipe (stage 14)
- Right intercooler (stage 18)
- Right intercooler top and bottom (stage 19)
The turbo inlet ducts outsides and insides were simply glued together.
Followed by the gluing of the air intake adapters.
Right intercooler was assembled as per stage 15 on my previous post.
That's it for now. Thanks for reading. As usual if there's anything in particular people want to see let me know. I'm also keen on your feedback on how I'm formatting these posts. I'm trying to make it as clear as possible in terms of referencing previous issues etc, but if anyone has any suggestions for improvements let me know!
Will try and get back on tomorrow with issue 7. :D
ajdavison2
Post by ajdavison2 » Sun Jul 21, 2019 9:08 pm
Hi guys,
Back again with issue 7.
First up is stage 21: Assembling the front suspension 1. Parts supplied with this issue were the monocoque inner rear plate front (top left), the monocoque inner rear plate rear (top right), The front left shock absorber cap (middle left),
front shock spring (middle right), front left shock absorber (bottom left), front left shock absorber end (bottom middle), stabiliser link (bottom right).
Parts needed from previous issues were:
Radiator housing assembly, radiator and right intercooler (stage 19)
First up, assembly of the monocoque inner rear plate. The 2 halves were glued together, and then screws were inserted into each of the 10 holes.
Next up was the assembly of the front left shock absorber, spring and cap. First up the spring was slid onto the shock absorber shaft.
Next the shock absorber cap was screwed onto the shaft.
Following this the shock absorber end was stripped of paint on the protrusion and glued to the shock absorber. (it's supposed to be at an angle relative to the horizontal, this proved a little difficult as the projection isn't shaped correctly to enable it to slot in snugly.)
Next up was the assembly of the right radiator an radiator housing, this was done in the same way as stages 16 and 17, so as usual I won't rehash the same details. The fully assembled right radiator housing, radiator and intercooler are pictured below.
Up next is stage 22: Assembly of the front suspension 2. Parts supplied with this issue were the monocoque inner rear plate (top left), the front right shock absorber cap (middle left), the front shock spring, the front right shock absorber (bottom left), the front right shock absorber end (bottom middle) and the stabiliser link (bottom right). (Also another mini screwdriver, redundant as I use my own set of precision screwdrivers)
Parts required with this stage were the monocoque assembly from stage 18.
The front right shock absorber, spring, cap and end were all assembled in the same way as the left one. So this has not been pictured.
Next up was the gluing of the inner rear plate to the monocoque. The paint was stripped from the relevant areas and the plate was glued into the monocoque.
At this point the magazine also recommended inking the shock absorbers and the stabiliser links.
Next up stage 23: Assembly of the cockpit. Parts supplied with this issue were the monocoque bottom plate rear (left), cockpit housing (bottom middle), cockpit housing front plate (top middle), shift panel (2nd from the right, bottom), gear lever (rightmost bottom), balance lever linkage (rightmost top), and in the sprue was the balance lever A (top), and the balance lever B (bottom). I haven't mentioned this previously as it seemed superfluous but most of these issues have been supplied with screws. This particular issue was missing a set of 5 screws. Whilst this hasn't been a problem yet as I done the assembly with glue instead, I have had another issue sent out so I will assembly it correctly with screws and keep the glued one as a spare.
First up the balance parts A and B were carefully trimmed from the sprue and any flashing removed from them. Quite fiddly as they're tiny so I'm happy I did this without damaging them at all.
The first part of this stage was to temporarily assemble the cockpit parts in order to mark the area on the housing where the cockpit housing front plate is fixed. I haven't pictured this step as it doesn't add anything to the model. The permanent assembly is pictured however. So skipping ahead the gear lever was attached to the shift panel. The paint was first cleaned off the gear lever and the lever was glued into place, from the underside of the panel.
Next up the balance lever A and B were glued together. Really fiddly little bit, but again I managed with some tweezers and more patience than I would usually have.
The completed balance lever sub assembly was then glued to the cockpit housing.
Followed by the gluing of the balance lever linkage to the cockpit housing.
Next up the assembly of the cockpit. First up the cockpit housing was *SUPPOSED* to be screwed to the bottom plate. This is where I have deviated from the magazine until I get the replacement parts and have superglued the cockpit housing to the base.
Following this the shift panel and cockpit housing front plate were both glued to the cockpit assembly. (Again the shift panel should've been screwed from the bottom and glued to the cockpit housing, but it's been glued from all sides.)
And that's it for this week guys and girls. As of now you're all as up to date as I am. I won't bother posting an update when I get the replacement parts fro this stage as it'll only be very minor differences that you can't see anyway unless you're looking at it from underneath. As usual if there's anything you'd like to see in more detail just hit me up!
Thanks for reading,
Alex
Rodak
Post by Rodak » Mon Jul 22, 2019 12:08 am
Nice work! My first thought on seeing the problem you had with the radiator and support fit up was that you got sent the opposite radiator to requirements; they sent right instead of left then left instead of right. The support hole is not symmetrical for height and it looks like a mirror image would have fit up just fine.
I'm amazed at the detail of this model.
ajdavison2
Post by ajdavison2 » Mon Jul 22, 2019 9:28 am
Hmm that's a good point that I hadn't previously considered. Too late now as they're all assembled, and the bends aren't visible. But if I come across the same situation in a future issue with a right/left component not fitting I'll wait until I have both sides and try fitting both. Thanks for the idea.
