Will Electric Vehicles Be Viable? When?
izzy
Re: Will Electric Vehicles Be Viable? When?
Post by izzy » Mon Aug 12, 2019 7:25 pm
Jolle wrote:
Mon Aug 12, 2019 7:18 pm
Indeed, it would be nice that that area could be open to atract more partners like A123, Excide, Samsung and LG into the F1.
yes absolutely and make the cars a bit lighter too, that everyone knows is an issue with the hybrids. I read somewhere that energy density with lithium-ion batteries has doubled since 2014, but they're still minimum 20kg in F1
Brake Horse Power
Post by Brake Horse Power » Mon Aug 12, 2019 8:13 pm
Agreed, a bit late maybe but I suppose they need to let go most regulations on battery design. Only the input output energy to be a maximum amount same as now. The development will especially rise in supercapacitors which I think is a much needed technology to evolve further.
Andres125sx
307
Post by Andres125sx » Tue Aug 13, 2019 9:10 am
FE batteries have doubled the capacity while increasing the weight just a bit, so they're not spec batteries with no development. But I agree it will be much better once they're free to develop
Probably they're afraid that would cause too big differences in performance, as batteries are a decisive factor in the power any electric setup can provide, and right now there's so much margin to improve it's very plausible someone could make a huge step forward and whip the floor with their rivals, what would be very harmful for FE right now
izzy
Post by izzy » Tue Aug 13, 2019 9:56 am
Yes fair point, just for me personally i can't be bothered with the FE crashfest as it is so it would add some interest, as long as they had to reveal their technology. And as long as they couldn't patent it, so everyone could copy.
That would really be awesome afaic
loner
26
Post by loner » Tue Aug 13, 2019 10:55 am
izzy wrote:
Mon Aug 12, 2019 7:16 pm
loner wrote:
Mon Aug 12, 2019 6:47 pm
Automotive supplier tests immersion-cooled batteries for EVs
The technology, called immersion cooling relies on coating the batteries with dielectric cooling gel, called MIVOLT, used as electrical insulation in other applications.
If it's successful, the technology could prolong battery life in electric cars and accept higher current rates while charging without overheating them, and potentially bring charge times down closer to the time it takes to refill a gas tank.
The i-CoBat immersion cooling project aims to reduce the size and cost of cooling systems to allow automakers to build denser battery packs without increasing the heat buildup.
https://www.greencarreports.com/news/11 ... es-for-evs
Thanks. Battery technology has so much momentum now doesn't it. I wish F1 and FE would encourage it by allowing more freedom to develop the ES, instead of the weight restrictions and spec supply
well Ricardo is the supplier perhaps Mclaren is involved as well they have some very advanced electric knowledge...
para bellum.
izzy
Post by izzy » Tue Aug 13, 2019 2:36 pm
yes I noticed Ricardo and I'm sure they're pretty good, especially at the start of the season. But the batteries don't get developed, that we get told about, because they have to be 20kg in F1 and they're all the same in FE. It could be so much more interesting. I mean probably F1 teams are interested in immersion cooling with gel, that sounds ideal, it'd be nice if they had to tell us and if they could do lighter batteries. And it's not as if Mercedes, Fiat, Renault and Honda can't afford a little development war about it, or just be allowed to use what they're probably doing already
Ferry
Post by Ferry » Wed Aug 14, 2019 10:59 pm
henry wrote:
Mon Aug 12, 2019 3:40 pm
Do they have much snow in Norway?
Yes we have! And ice. And mountains. And lots of EVs. I find the electric driveline far superior in low grip conditions. I've been driving for 30 years under these conditions, different cars, gasoline, diesel, RWD, FWD, AWD. Especially with wet snow there is a rather big advantage being able to go super slow uphill. Compacting the snow under the tires slowly without wheelspin. With traditional cars I most times had to back down all the way to a flatter part of the road to be able to get going again. With the EV I can often back just a few meters and then try again. It's far smoother torque delivery. And the traction control and stability control is super quick to react.
izzy
Post by izzy » Thu Aug 15, 2019 6:07 pm
Apparently the UK now has more charging points than petrol stations
Bit of a fiddle probably counting individual chargers vs whole petrol stations, but still it shows momentum is building
Brake Horse Power
Post by Brake Horse Power » Thu Aug 15, 2019 8:30 pm
Wanted to post this in the UK car thread but since it's now closed for a while it might be appropriate here..
Greg Locock
164
Post by Greg Locock » Sun Aug 18, 2019 12:43 am
For long distance journeys you need 1 charger for every 15 EVs, as a rule of thumb.
