tok-tokkie
Post by tok-tokkie » Wed Apr 17, 2019 9:42 am
Congratulations.
( I noticed that that Boeing 1 man helicopter contest has announced the winner. Bit like a flying motorcycle. )
manolis
82
Post by manolis » Thu Apr 18, 2019 5:36 am
Thanks Tok-Tokkie.
You write:
"I noticed that that Boeing 1 man helicopter contest has announced the winner. Bit like a flying motorcycle."
It is not the final winner.
The final "Fly-Off" was initially scheduled for the September 2019, now it is postponed for the February of 2020. And, by then, who knows.
As far as I know, the so-far winners, ten for the Phase-I (20,000U$ each) and five for the Phase-II (50,000$ each), all are battery powered.
The existing battery technology cannot yet meet the initial rules of the BOEING-GoFly competition:
"Design and build a safe, quiet, ultra-compact, near-VTOL personal flying device capable of flying 20 miles while carrying a single person."
They already changed their own rules, which is not only unfair, it is illegal, too.
BOEING should be ashamed for it, as well as for the lack of transparency of their contest
By the way, the 20 miles is already a very short distance for a useful Flying Machine.
In any case, only the future will prove who is right and who is wrong.
Thanks
Manolis Pattakos
J.A.W.
83
Post by J.A.W. » Fri May 10, 2019 6:24 am
Well done Manolis for getting your engine realized in metal form.
If I might suggest, there is a fellow two-stroke ethusiast (in the EU) who might be interested in helping.
See the 2-stroke developments thread in the 'bucket racing' section of the Kiwi-biker forum.
& while on that subject, well done too, to fellow forum member here, 'Uniflow', who, by posting the
developments he's made - in this thread as well, has been able to show that KTM's claims of 'invention'
in their patent application for their 2T TPI system - were unsustainable, & duly disallowed, on this basis.
Dr Zachary Smith sez..
"Yes.. spare us your ridiculous remarks, you insensitive idiot!"
Pinger
Post by Pinger » Sun May 12, 2019 12:02 pm
Link????
(Tried to find it but couldn't and search facility denied without registration).
J.A.W.
83
Post by J.A.W. » Tue May 14, 2019 4:23 am
Magic word?
Your 'google fu' seems to be a bit weak, Pinger. Try this, if interested.
Go to 'Kiwi biker forum', then to the section on 'Competition' > 'Buckets' >'ESE's works engine tuner' thread.
Its a massive data-base for 2T stuff.
Pinger
Post by Pinger » Tue May 14, 2019 11:01 am
Thanks J.A.W. - found it now.
manolis
82
Post by manolis » Fri Jun 14, 2019 7:24 pm
Hello all.
"Lost Pattern" casting.
Thanks
Manolis Pattakos
tok-tokkie
Post by tok-tokkie » Sat Jun 15, 2019 10:42 am
The first post of the castings I did not appreciate that they were lost wax castings. I had expected you to cnc them out of billet aluminium - thinking that would be quicker for the pre production engines.
Now I appreciate what you have done. Made a master for the lost wax models so you can now economically & comparatively easily turn out more to order.
I have been really fascinated by this project.
manolis
82
Post by manolis » Tue Jun 18, 2019 4:40 am
Thanks Tok-Tokkie
You write:
"Made a master for the lost wax models so you can now economically & comparatively easily turn out more to order.
I have been really fascinated by this project."
The "master" is actually an STL (stereolithography) file (or a CAD drawing).
With a 3D-printer the STL file is "changed" to a plastic pattern (it takes a few hours, the cost is not significant).
The two OPRE Tilting engines standing on the chair (video, last post of mine) were made using such plastic patterns (from PLA), like that at the back of the two engines.
The pattern is surrounded by plaster.
The plaster is dried and then it is heated at ~400 degrees Celcious for a few hours.
The plastic pattern is burned leaving an empty space / "negative pattern" in the plaster, which is filled with melted aluminum alloy.
By the way, here
https://www.sfsa.org/tutorials/eng_block/GMBlock.pdf
is the "Lost Foam" casting process used for the manufacturing of aluminum engine blocks of GM.
The method / casting is a variation of the ancient "lost wax casting" wherein while the (wax) pattern is lost, the wax can be recycled and used for making the next patterns.
In the "Lost Foam casting" the pattern (and the material (i.e. the foam) the pattern is made of) is totally lost (burned).
Thanks
Manolis Pattakos
manolis
82
Post by manolis » Tue Aug 13, 2019 1:16 pm
Hello all.
Thanks
Manolis Pattakos
Hello all.
Here are the youtube videos of the above cast OPRE Tilting engines running on gasoline fuel:
and
Cast casing, cast pistons, cast connecting rods and tilting valves.
The aluminum pulley is quite lightweight and is for the manual cranking; i.e. there is no flywheel other than the synchronizing gearwheels and the balance webs (all secured on the crankshafts).
Thanks
Manolis Pattakos
tok-tokkie
Post by tok-tokkie » Tue Aug 13, 2019 5:14 pm
Lovely to see it running. Has a sound all of its own. Congratulations.
You say synchronizing gearwheels but I thought I saw a chain connection also. Am I correct? If so what is it for?
manolis
82
Post by manolis » Wed Aug 14, 2019 5:13 am
Thanks Tok-tokkie.
You write:
“but I thought I saw a chain connection also. Am I correct?”
There is no chain.
The reinforcing / strengthening beams / ribs between the crankshaft roller bearing “nests”:
can be confused with a chain:
The different sound comes, reasonably, from the different (more positive) gas exchange.
Quote from https://www.pattakon.com/tilting/pattak ... s_FLow.htm :
TUNING
The "tuning" depends more on the intake and transfer, than on the exhaust.
With the exhaust ports already opened, the transfer ports open and the scavenging begins.
The transfer ports open earlier than in a conventional 2-stroke. The pressure into the "scavenge pump" (sealed by the "back-side" of the piston whereon the tilting valve is still closed) allows such timing.
Later the tilting valve opens and the scavenging continues based on the inertia of the gas column formed along:
the open tilting-valve-port on the piston,
the space into the scavenge pump,
the transfer passageways,
the transfer ports,
the combustion chamber,
the exhaust ports,
and the exhaust.
Fresh charge from the "crankcase" (i.e. from the space inside the piston) feeds this "inertia" column, while the crankcase is fed from the intake, through the intake port, with fresh charge (air-fuel-oil mixture).
When the piston finally closes the transfer ports, the suction of air-fuel-oil-mixture from the intake continues due partly to the subpressure created into the scavenge pump space as the piston (with the tilting valve open) moves towards the TDC, and partly to the inertia of the gas column formed along:
the intake,
the intake port,
the crankcase,
the scavenge pump space,
and the scavenge passageways.
After the TDC the tilting valve closes and the air-fuel-oil-mixture trapped inside the "scavenge pump" is compressed waiting the transfer ports to open again by the piston.
And so on.
End of Quote
Thanks
Manolis Pattakos
