[MVRC] Mantium Virtual Racecar Challenge 2019 (Grand Prix Cars)
JJR
JJR
16
Re: [MVRC] Mantium Virtual Racecar Challenge 2019 (Grand Prix Cars)
UlleGulle wrote:
21 Nov 2019, 11:56
LVDH wrote:
21 Nov 2019, 09:58
JJR wrote:
21 Nov 2019, 09:46
Currently I ´m trying to reproduce F1 car from early 90 ´s and see how it compare to our cars. I will try post results next week.
That is awesome. My preference for our F1 rules would be these old 90s cars. However Richard convinced me that it would actually not be possible. The cars at the time did not look the way they looked because of rules but more because of manufacturing constraints, so replicating that would require very artificial rules. So if your create such a car you would make me super happy.
It would be interesting, as a theoretical exercise though, to see what a modern car built to those regulations would look like. Would it be wings everywhere, or a cleaner car? Would they run it super low, or high? Would rake be introduced?
Actually it will be close to 90 ´s . I will use airfoils for front and rear wing as they were in those days. Basic car will be Ferrari F93A with 3,5L V12 so big engine with cooler simulation.
machin
162
maunde wrote:
21 Nov 2019, 11:54
Thanks for (continuously) replying :)
If next year were to be GP style, would it be appropriate to assume that an identical car would get an identical time on the same track (2020 vs 2019)? Unless of course the track had a 'modified' layout :lol:
Yes, thanks Matteo for covering those questions which you answered well!
Depending on the ruleset we use next year (since this hasn't been finalised yet) I will modify the "base" car's mechanical settings in Virtual Stopwatch... that will probably mean that even if your car had the same aero coefficients then you will get a slightly different lap time. I strongly expect that the actual tracks will change next year anyway... maybe 1 or 2 will be re-used, but almost certainly with a different mechanical car set-up...
Normally I have tried to set the car/track models at the beginning of the season, but I struggled to do that this time.. certainly that's my aim next year.
Going back a couple of questions: Matteo was right that we only test at one air speed and calculate one COP... we then assume that the COP and aero coefficients are the same at all road speeds (note: that means the actual downforce and drag Virtual Stopwatch uses at each point on the track is proportional to speed squared). It is worth pointing out that when we started this competition many years ago (called KVRC back then) we actualy tested the cars at two speeds, and at two yaw angles, we then interpolated between those points to derive an aero-map. However, what we found was that the best car at 100mph with zero yaw, was also the best car at 180mph with some yaw angle; so the additional 3 CFD runs per car did not affect the result -they were unnecessary for our purposes, so now we only do one CFD run per car.
Sounds like you'll be involved next year?
jjn9128
769
JJR wrote:
21 Nov 2019, 12:38
UlleGulle wrote:
21 Nov 2019, 11:56
LVDH wrote:
21 Nov 2019, 09:58
A very common front wing mainplane profile at that time was the modified GA(W)-01/LS(01)-0417
https://m-selig.ae.illinois.edu/ads/coord/ls417mod.dat
#aerogandalf
LVDH
44
machin wrote:
21 Nov 2019, 14:48
maunde wrote:
21 Nov 2019, 11:54
The calendar itself is announced well before the season starts. While sometimes the actual date changed, the tracks never did. When developing for a track like Monaco, you simply have to go for max. downforce, while in Monza you will have to minimize drag and on other tracks find a good balance between the two. This things are clear, even when the VSW is not fully available to you.
maunde
machin wrote:
21 Nov 2019, 14:48
maunde wrote:
21 Nov 2019, 11:54
Thank you for clarifying, I certainly hope to be competing :D
A kiwi looking to fly like McLaren.
etsmc
Wow thanks for sharing your processes and other for sharing their details too.
I hope i can use some of this to improve my car, i have a feeling that a lot is in the floor like others.
variante
131
I tried to copy the color scale from Koldskaal for a direct comparison. It ended up not being exactly the same, but it gives an idea... I used the car from a "fast" simulation (i.e. lower downforce than official) and 1° rake.
And also:
and its infernal version:
Koldskaal
Very interesting. From what I can see we have pretty much come to the same solution, of extending the tea-tray portion of the floor template. It looks like you also get a bit of downforce from the vortex this creates. Where it seems like CAEdevice has gone a different route.
For reference the picture I shared was from a "MVRC" (not fast) simulation.
MVRC - Koldskaal, name: Christian
CAEdevice
45
Contact:
variante wrote:
22 Nov 2019, 14:01
https://i.imgur.com/0T98mZx.png
And also:
https://i.imgur.com/HmbVdPa.png
https://i.imgur.com/tOcYQ0H.png
Hi Variante, wich is the color set for the first image? Is it "near wall speed" representation? Is ti a Paraview pre-set?
I would like to share a similar image for a comparison.
variante
131
CAEdevice wrote:
22 Nov 2019, 15:29
A custom one
Or we could just use standard scales...
CAEdevice
45
Contact:
I am too lazy, so this is my car with the default preset:
Koldskaal
CAEdevice wrote:
22 Nov 2019, 15:29
variante wrote:
22 Nov 2019, 14:01
And also:
The one I used is called Rainbow Uniform in paraview 5.7.0 :)
edit: i didnt set out to make it overly complicated to make comparisons to mine, but it seems i might have done so anyway :D
jjn9128
769
What are the rules next year? Carrying on the same before adopting 2021 F1 the year after?
#aerogandalf
wb92
Here comes mine:
When normally (with LM MVRC) rules were revealed?
MVRC - WBRacing
variante
131
Ok, so:
Koldskaal wrote:
22 Nov 2019, 16:15
Ahhh...i'm using 5.4.1
jjn9128 wrote:
22 Nov 2019, 17:50
What do you think of 2021 rules applied to MVRC?
We talked a little about rules a few weeks ago. I said that i would probably adopt 2021 rules right away, so we could produce 2021 cars before anyone else and draw some attention to this challenge.
But it's not granted that such rules are simple enough or interesting enough or who knows what...
