Red Bull RB16
Re: Red Bull RB16
Comparison between the new bargeboard upgrades of 2nd Barcelona test, 1st test and Mercedes W11
dandfx
dandfx
Re: Red Bull RB16
I'm not an aero expert but comparing the two above it seems the newer design pushes more air outboard and upwards. Would this update make more down force (just the elements themselves, not flow on effects) and much more outwash? I'm quite curious about how much outwash teams are creating for their benefit after the front wing regulation change.
basti313
basti313
47
Re: Red Bull RB16
I do not think the direction is different, this would invalidate all data from the first test. RedBull usually shows up with an easy version at the first test, not much fins and details and refines this until the start of the season. The slotted boards in my point of view are a refined version to mainly reduce drag.
Re: Red Bull RB16
The slotted board will obviously change flow direction - one only has to look at it to see it will send flow upwards. Remember the flow hitting that board will be moving from inside to outside as well as from car front to car back. So the flaps will produce a number of similar vortices. Similar vortices combine to produce a large effect which is what they'll be trying to achieve. This whole area is about setting up the flow to limit movement under the floor's edge. Roll up a strong vortex and run it along the top of the floor edge and you can reduce the movement of air from above the floor to under the floor - the so-called "sealing of the floor".
Re: Red Bull RB16
It enchances a Vortex. Pretty much like a twirl. It doesn't cause a bulk upward motion as you would think by looking at it.
Near the floor the vortex curls outboard... This helps maintain that one. My theory at least!
Re: Red Bull RB16
wowgr8
wowgr8
Re: Red Bull RB16
Is the RB16 the only car on the grid not running the POU offset? If it is running it, does anyone have good pictures?
SiLo
84
Re: Red Bull RB16
wowgr8 wrote:
Fri Mar 20, 2020 8:14 am
It is, I'm sure there are images of it further back in the thread.
Felipe Baby!
Re: Red Bull RB16
bill shoe
bill shoe
250
Re: Red Bull RB16
What is "POU"? If I know that then I'll probably be able to figure out what "POU offset" is.
EDIT: POU = Pushrod On Upright. POU offset = pushrod's bottom point is inboard of Upright's steer axis.
Re: Red Bull RB16
bill shoe wrote:
Mon Mar 23, 2020 10:06 pm
Pushrod On Upright.
The new fangled offset POU is where they have a big brackety thingy pointing inboard which the pushrod then attaches to.
Re: Red Bull RB16
That gap between the lower and second lowest plane is a nice way to speed up airflow to that serrated part of the tea-tray. Little details like this is what lead me to believe this car is a winner, shame we have to wait another month or two.
Godius
213
Re: Red Bull RB16
Re: Red Bull RB16
godlameroso wrote:
Fri Apr 10, 2020 6:42 pm
https://i.postimg.cc/9FxxDjgz/13-rb16-headon.jpg
The air going through there won't get to the tea tray.
bill shoe
bill shoe
250
Re: Red Bull RB16
A technical post about aero! Right or wrong it's lovely! Like the flowers coming out in spring...
