The token system was created because of Mclaren’s PU change... In theory the chassis were going to be frozen into 2021... McLaren needed to make modifications to the chassis to accommodate it, in order for the other teams to allow the changes in a fairness spirit, the token system was put in place.Big Tea wrote:But what about everything they have to change to facilitate the engine change? can thy not be the things that would have been upgraded anyway?SmallSoldier wrote: ↑21 Sep 2020, 18:19Actually, Mclaren will have to use both tokens for the engine integration... They won’t have an additional token for other changes, while the rest of the teams will have those 2 tokens to make changes.the EDGE wrote: So many questions I forgot 1
Personally I don't believe the pu intergration will be an problem. The loss of the token is the real issue, for example others may choose to upgrade both front & rear suspension where McLaren would have to choose 1 or the other
That’s why it is stated that Mclaren are in a losing position against the other teams, because the 2 tokens used for the engine change can’t create a performance increase (Mclaren has to show that the changes to accommodate the new engine doesn’t create additional performance).
The new floor trialed was definitely in response to next years changes and maybe the latest fences too, but as they are still run on Carlos’ car with the current floor there must be a benefitgodlameroso wrote: ↑22 Sep 2020, 00:03The loss of the floor, diffuser fence height, and leading edge angle will mean the bargeboards will be more important.
Teams are already focusing on this area in preparation for next year. McLaren has introduced a lot of bargeboard parts lately as has Mercedes. This is not by accident.
Interesting to see when they introduce the new nose. The current lock-in for chassis design sets at the end of September. Yet the team has said it might be introduced only after Sochi. Perhaps mere testing approves the concept for future integration?_cerber1 wrote: ↑22 Sep 2020, 14:39“Even though we are past the halfway point of the season, we still have to focus on the task at hand and continue to work hard. The balance of resources between car upgrades, spare parts and next year’s car continues to be an exciting challenge in this compact season. We’ll be deploying some new updates in future races with the aim to improve the car.”
https://www.mclaren.com/racing/2020/rus ... ow-russia/
Maybe it means that at the end of September there will be a ban on work in a wind tunnel and CFD on these elements?
It’s been baffling me too. I think the rules are quite clear, after 30th Sep you can not change homologated parts without the use of tokens.
The nose is essentially the front impact structure though. Given the contrast between the two I doubt they share that aspect.the EDGE wrote: ↑23 Sep 2020, 10:07It’s been baffling me too. I think the rules are quite clear, after 30th Sep you can not change homologated parts without the use of tokens.
It’s worth noting that only the front impact structure is homologated, non-structural farings remain free to be updated as & when, so perhaps either the front impact structure remains unchanged and didn’t require a new crash test, or the front impact structure has already been changed and the old fairings have been integrated whilst development continues
I don’t think so...
https://www.fia.com/sites/default/files ... 6-19_1.pdfa number of components or assemblies will be homologated from a certain moment during the 2020 Championship, to be used for the rest of the 2020 Championship and for the 2021 Championship
But that rule doesn't preclude using older designs during the rest of the 2020 season.the EDGE wrote: ↑23 Sep 2020, 11:41I don’t think so...
In my opinion it does. You can only Homologate one specification and you must run it for the remainder of this year and all of next year.adrianjordan wrote: ↑23 Sep 2020, 13:00But that rule doesn't preclude using older designs during the rest of the 2020 season.the EDGE wrote: ↑23 Sep 2020, 11:41I don’t think so...
