Page 8 of 9
Re: Ferrari F60 aero-mech development in 2009
Posted: 13 Oct 2009, 21:19
by bar555
tadzio89 wrote:do u have bigger version of 4th image?
Posted: 19 Oct 2009, 19:45
by bar555
Posted: 20 Oct 2009, 19:20
by bar555
GEARBOX DETAILS - BELGIUM
Gearbox
Semiautomatic sequential electronically controlled gearbox - quick shift; 7 gears + Reverse
The F60 gearbox is cast in titanium , a novelty first introduced by Minardi team back in 2000 . There is an extra carbon fibre skin covering the titanium casting to increase stiffness .
1.Lower wishbone
2.Upper wishbone
3.Rotating dampers
4.Gearbox mountings on the engine
EXHAUSTS - BELGIUM
DIFFUSER - BELGIUM
FRONT BRAKES - BELGIUM
REAR BRAKES - BELGIUM
Posted: 21 Oct 2009, 00:19
by megz
Why don't they mount the brake calliper on the front moving the weight bias infintismally further forward?
Posted: 21 Oct 2009, 00:23
by czt
megz wrote:Why don't they mount the brake calliper on the front moving the weight bias infintismally further forward?
it would potentially interfere with the lower wishbone and brake duct, along with raising the CofG fractionally.
Posted: 21 Oct 2009, 00:34
by ESPImperium
They used to be there, but as czt said, they didnt make suspension geometry rignt and made the COG higher. And the low brake caliper thing was initally used by Red Bull with the RB3, it was something Adrin Newey found that would lower COG by arround 1% during acceleration and drastically more in braking. Also made it easier to ventilate as well, whitch means you can run with smaller thickness discs in theory, meaning up to .5-1kg can be saved in weight on brakes, thats alot of balast that can be played arround with even lower down.
Posted: 21 Oct 2009, 05:32
by shiggy
ESPImperium wrote:They used to be there, but as czt said, they didnt make suspension geometry rignt and made the COG higher. And the low brake caliper thing was initally used by Red Bull with the RB3, it was something Adrin Newey found that would lower COG by arround 1% during acceleration and drastically more in braking. Also made it easier to ventilate as well, whitch means you can run with smaller thickness discs in theory, meaning up to .5-1kg can be saved in weight on brakes, thats alot of balast that can be played arround with even lower down.
I thought the MP4/18 used bottom-mount calipers in 2003.
Posted: 23 Oct 2009, 01:41
by bar555
GP ITALY - MONZA
Undergone changes from Belgium
1.Front wing
2.Engine elongated slots
3.Asymmetric exhausts outlets
4.Rear brake ducts
5.Rear axle winglets
6.Rear wing
Fisichella replaced Badoer ( because of Badoer’s poor performance )
Posted: 24 Oct 2009, 15:36
by bar555
FRONT WING - ITALY
REAR WING - ITALY
The wing in Monza resembled a lot to the one used in Spa but it clearly had a much lower attack angle
Posted: 24 Oct 2009, 15:55
by ESPImperium
shiggy wrote:ESPImperium wrote:They used to be there, but as czt said, they didnt make suspension geometry rignt and made the COG higher. And the low brake caliper thing was initally used by Red Bull with the RB3, it was something Adrin Newey found that would lower COG by arround 1% during acceleration and drastically more in braking. Also made it easier to ventilate as well, whitch means you can run with smaller thickness discs in theory, meaning up to .5-1kg can be saved in weight on brakes, thats alot of balast that can be played arround with even lower down.
Designer??? Adrian Newey.
Posted: 24 Oct 2009, 16:29
by noname
ESPImperium wrote:Designer??? Adrian Newey.
"McLaren MP4/18 - MP4/19
Year designed: 2003
Year raced: 2004
Team: McLaren
Designer: Mike Coughlan & Adrian Newey & Neil Oatley"
http://www.f1technical.net/features/689
Posted: 25 Oct 2009, 04:09
by shiggy
ESPImperium wrote:shiggy wrote:ESPImperium wrote:They used to be there, but as czt said, they didnt make suspension geometry rignt and made the COG higher. And the low brake caliper thing was initally used by Red Bull with the RB3, it was something Adrin Newey found that would lower COG by arround 1% during acceleration and drastically more in braking. Also made it easier to ventilate as well, whitch means you can run with smaller thickness discs in theory, meaning up to .5-1kg can be saved in weight on brakes, thats alot of balast that can be played arround with even lower down.
Exactly. His RB designs are basically a continuation of his ideas for the MP4/18-19 (but we are getting OT)
Posted: 25 Oct 2009, 23:13
by Jaymz
Wow great stuff again bar555.
I used to hate Ferrari but now like them coz Kimi went there!
Posted: 26 Oct 2009, 05:52
by mike
Jaymz wrote:Wow great stuff again bar555.
sorry man...Kimi has left the building, taking 95% of F1 fans with him.
Posted: 26 Oct 2009, 22:21
by bar555
