Page 708 of 1331
Re: Honda Power Unit
Posted: 26 Aug 2017, 18:52
by Joseki
Fernando is too fast for the car
Posted: 26 Aug 2017, 19:09
by FvtecA
Joseki wrote: ↑26 Aug 2017, 18:46
According to Fabrega the problem was in the engine mappings: Fernando did Pouhon flat out that lap and the engine run out of hybrid boost.
Seems strange. Does that mean that the issue was never picked up during practice, or Q1? If so, why?
Posted: 26 Aug 2017, 19:23
by fellowhoodlums
FvtecA wrote: ↑26 Aug 2017, 19:09
Didn't run out. It just didn't deploy automatically. Pouhon was taken flat out and the engine map expected a throttle lift. There was no lift so it didn't know where it was on the track and didn't deploy.
https://www.motorsport.com/f1/news/alon ... en-945396/
Posted: 26 Aug 2017, 19:39
by FvtecA
fellowhoodlums wrote: ↑26 Aug 2017, 19:23
Hahahahaha. Honda needs a separate software tester whose job is "Everybody else tests the software for the engine. You test this for Fernando Alonso"
Posted: 26 Aug 2017, 20:04
by etusch
New lesson for Alonso: if you feel no deployment release throttle and then push it again
Posted: 26 Aug 2017, 20:28
by Dipesh1995
Seems strange that their deployment strategy is not based or at least assisted with GPS data as well as major throttle position.
Posted: 26 Aug 2017, 20:33
by Dimi
Is diff gps permitted by regulations?
Posted: 26 Aug 2017, 20:40
by McL-H
I find it a weird conclusion, as Fernando did the same in Q1 (taking Pouhon flat out) and the issue didn't occur then..
Posted: 26 Aug 2017, 21:00
by taperoo2k
McL-H wrote: ↑26 Aug 2017, 20:40
Andrew Benson (I know some might groan) has a bit more detail it seems. Software didn't pick up that Alonso had already gone through the corner so didn't deploy, so Alonso is too fast for the car and software it seems -
https://twitter.com/andrewbensonf1/stat ... 0293412864
Posted: 26 Aug 2017, 21:20
by NL_Fer
The shocking conclusion is, Honda still has no full deployment for a whole lap, the have to chose where to have deployment.
Posted: 26 Aug 2017, 21:23
by diffuser
Posted: 26 Aug 2017, 22:38
by Joseki
Dipesh1995 wrote: ↑26 Aug 2017, 20:28
It's forbidden by the rules for safety reasons.
Posted: 26 Aug 2017, 22:42
by Joseki
NL_Fer wrote: ↑26 Aug 2017, 21:20
I don't think that ANY team has full deployment for the whole lap, the battiers allows for 33.3 seconds of hybrid boost at max power, and even with some amount of energy recovered while braking by the MGU-K and some on the straights by the MGU-H (I actually doubt it's much considering that it's in the highest possible power output mode) Spa has very long sections at full throttle.
Posted: 26 Aug 2017, 23:57
by Squid
Is Hasegawa dumbing things down again? Because it would seem very weird if Honda only uses throttle input to determine where they are on track.
Posted: 27 Aug 2017, 04:00
by PlatinumZealot
This! Mostly throttle input.. there must be a better way to do this! Even a simple addition of a innertial navigations system would have helped i think.
