Page 9 of 17
Re: 2011 Endurance news
Posted: 11 Mar 2011, 17:13
by RacingManiac
http://www.mulsannescorner.com/newsmarch11.html
Also I was mistaken that this has the wide front tires....
Posted: 11 Mar 2011, 18:50
by Pandamasque
Posted: 13 Mar 2011, 00:52
by Pandamasque
Honda ARX-01d (LMP2) RML
HPD ARX-01e (LMP1) Highcroft Racing
Posted: 14 Mar 2011, 22:37
by Pandamasque
While the turbocharged Honda LMP2 car is seriously down on top speed, the ARX-01e looks on par with Audi R15+- right out of the box!
Posted: 14 Mar 2011, 22:48
by wesley123
well the LMP2 isnt actually running in the correct configuration, too large diveplanes, high gurney on the back.
The e on the other hand is looking pretty good and i am really looking forward to see it perform its first race
Posted: 15 Mar 2011, 00:11
by dumrick
The ARX-01e was shaken down at Sebring in a Le Mans aero configuration, hence possibly also the high top speeds. Highcroft will be adding more adequate downforce before the race.
Posted: 17 Mar 2011, 01:33
by RacingManiac
So far the 2 test day at Sebring the 01e was the fastest petrol car. Fastest lap is just over .5 sec slower than the 908.
SpeedTV has some pics of the tests so far, the 908 looks very different under the skin vs the old car....the rear damper looks interesting...
http://photos.speedtv.com/gallery/ALMS% ... oeas894ev0
Any idea what that is?
Posted: 17 Mar 2011, 05:20
by Pandamasque
It also failed the scrutineering. 5mm wider than allowed. Sandpaper to the rescue.
Posted: 17 Mar 2011, 07:30
by Formula None
Panoz Abruzze
Posted: 17 Mar 2011, 07:59
by Formula None
RacingManiac wrote: SpeedTV has some pics of the tests so far, the 908 looks very different under the skin vs the old car....the rear damper looks interesting...
Rotary dampers?
Peugeot 908 front torsion bar:
Rear & gearbox detail w/ lifting ram:
New Aston looking better here:
Posted: 17 Mar 2011, 08:11
by Formula None
ARX-01e
Posted: 17 Mar 2011, 08:18
by Formula None
New Honda turbo V6, looks like its running a log manifold and not equal length headers (shape of things to come for F1 2013?). Turbine right next to the pistons, intercooler close by, short intake piping... Pretty compact for a turbo.
Edit: Large pic:
Posted: 17 Mar 2011, 08:46
by Formula None
Check out the reverse swan mounts on the Robertson Ford GT. Haven't seen this before, hopefully this is some small team innovation we're seeing. This is probably even better than the forward mounted swan necks, yeah? Completely eliminates any upstream influence on the wing. Only a portion at the rear of the wing underside would be affected rather than all of it being in the wake. The big benefit would be in yaw, the shadow of the supports being behind the wing. Maybe even aiding evacuation of the low pressure side as the support foils stall? Great idea, anyway.
Posted: 17 Mar 2011, 08:59
by creedbratton
I'm amazed at how short the exhaust manifolds are on that Honda engine
Posted: 17 Mar 2011, 11:43
by lolzi
That Panoz Abruzze might very well be the worst-looking car I've ever come across. Are they making a road version of it, like with the Esperante?
