Page 90 of 270
Posted: 26 Aug 2022, 01:37
by djos
That looks very cool, however I can't imagine 800w nominal output being very useful for much of anything. It needs some serious development to be practical.
Posted: 26 Aug 2022, 05:22
by wuzak
Big Tea wrote:
25 Aug 2022, 23:15
mzso wrote:
25 Aug 2022, 22:42
Cold Fussion wrote:
19 Aug 2022, 21:06
The problem is the volumetric density is appalling. Hydrogen at 750 bar is ~42kg/m3, so if they need roughly 110kg of fuel to complete a race now, they would need roughly 34kg of hydrogen for a fuel cell with a 60% efficiency vs a 50% efficiency PU currently, which means you need a roughly 800L tank of hydrogen to complete the race, which would be a packaging nightmare.
Well, yeah. But it's workable. I'm more skeptical about safety viability. A 750 bar tank bursting would be quite an explosion.
The latest generation of Space vehicles use Methane, mostly because of the density difference with Hydrogen, plus the amount of cooling needed, and pressure. Is it likely any F1 teams would look at it? (produced by solar so 'green')
You mean SpaceX uses methane?
SLS uses liquid hydrogen for the main stage and solid rocket boosters.
I would think the main reason to use Methane is cost.
Posted: 26 Aug 2022, 05:24
by wuzak
Tommy Cookers wrote:
25 Aug 2022, 16:16
my (first 2) suggestions above - can someone explain what would stop them working ?
Race fuel allowance?
Posted: 26 Aug 2022, 12:01
by Big Tea
wuzak wrote:
26 Aug 2022, 05:22
Big Tea wrote:
25 Aug 2022, 23:15
mzso wrote:
25 Aug 2022, 22:42
Its mostly due to long term wanting to produce fuel from atmosphere (mars) and sun power, but partly because of much less weight and bulk of the tanks needed. Also stores at -160 odd
It produces less power, but takes up less room and weight, as would be needed on a car
Posted: 26 Aug 2022, 13:27
by Cold Fussion
Methane also burns much cleaner than RP1, useful considering the multiple use nature of engines.
Posted: 26 Aug 2022, 14:07
by Just_a_fan
wuzak wrote:
26 Aug 2022, 05:22
SLS uses rehashed Space Shuttle main engines (RS-25) which means they have to use liquid H2. NASA are paying something around $100m per engine which is a lot of money - $400m per flight - to just throw away but then each launch costs something like $2bn. Very old-school thinking, sadly, but they are using the usual suspects like Boeing who just always charge a fortune and just do the "same old same old".
Posted: 26 Aug 2022, 17:04
by Big Tea
Just_a_fan wrote:
26 Aug 2022, 14:07
wuzak wrote:
26 Aug 2022, 05:22
The Blue origin RB4 engine also uses it and there are a couple of other companies intending to use RB4
Edit
OOps, I've done it again :oops:
Posted: 27 Aug 2022, 01:02
by gruntguru
25 Aug 2022, 14:32
. . . . In principle couldn't a 'throttle' reduce air drawn by the compressor without causing the usual 'throttling' loss of power ?
. . . where possible the "throttle" would reduce output to the wheels by loading the guk and charging the es. This would have the benefit of eliminating lag - the turbo is at full boost with ice charging es at 350 kW. Application of full throttle could increase output to the tyres by 700 kW without any change in ice output.
I think this is sort of what you were getting at.
Posted: 27 Aug 2022, 09:35
by wuzak
gruntguru wrote:
27 Aug 2022, 01:02
25 Aug 2022, 14:32
How much will the race fuel restriction impact that?
Remembering that the race fuel will be something like 70% of the energy that is used now.
And the engine is tied to the rear wheels, and potential engine power is controlled by the fuel flow, which is restrcited below 10,500rpm depending on rpm. Not sure what rpm would produce 350kW.
And if that system can be used, recall that the storage is only 4MJ. or 11.7s at 350kW. So long straights, like Spa, will have a lot less power available than now.
Posted: 27 Aug 2022, 11:40
by Red Rock Mutley
wuzak wrote:
27 Aug 2022, 09:35
Think more in terms of per lap energy budget. The ES permits greater flexibility in the timing of the conversion between fuel energy and mechanical energy. Doing things like improve drivability is an important part of maximising the ruleset to improve lap time
wuzak wrote:
27 Aug 2022, 09:35
2 points there -
Firstly, the 4MJ is the delta between ES minimum and maximum for the session, it's not a per lap limit. Even when used all in one go, the ES can be refilled during the remainder of the lap, and used again in that lap. There is a per lap input limit, 9MJ but no limit on the output.
Secondly, the 350kW is not a single define value. It is a function of car speed and tapers above 300kph (essentially long straights)
2026 PU Regs
5.4.6 The electrical DC power of the ERS-K may not exceed 350kW.
5.4.7 Additionally, the electrical DC power of the ERS-K used to propel the car may not exceed: • P(kW)=1850-5* car speed (kph) when the car speed is below 340kph
• 150kW when the car speed is equal to or above 340kph
5.4.8 The difference between the maximum and the minimum state of charge of the ES may not exceed 4MJ at any time the car is on the track.
5.4.9 The energy harvested by the ERS-K in each lap must not exceed 9MJ.
This limit applies to the energy going out of the CU-K and going into the ES.
5.4.10 The maximum mechanical torque of the MGU-K may not exceed 500Nm. The torque will be referenced to the crankshaft speed and a fixed efficiency correction of 0.97 will be used to monitor the maximum MGU-K mechanical torque.
Posted: 27 Aug 2022, 13:43
by wuzak
Red Rock Mutley wrote:
27 Aug 2022, 11:40
wuzak wrote:
27 Aug 2022, 09:35
2 points there -
Right, but the battery capacity is 4MJ.
Means you can only deploy a maximum of 4MJ without recharging. Which is 11.7s at 350kW.
Or 23.4s at 175kW.
But I would think that 350kW would be used at the exit of the corner.
Posted: 27 Aug 2022, 14:03
by mzso
djos wrote:
26 Aug 2022, 01:32
On their own, sure, but you ignore all the ancillary equipment needed to make a viable FCEV.
Again, you're generic without providing any basis. You need a tank, a fuell cell, and a small amount of battery, power electronics which all EVs have.
Posted: 27 Aug 2022, 14:15
by djos
mzso wrote:
27 Aug 2022, 14:03
djos wrote:
26 Aug 2022, 01:32
And BEV’s don’t need the 2 largest, hardest to package items. Seriously mate, go have a look at the specs of the latest FC tech.
Eg Toyota’s latest Mirai uses the latest polymer electrolyte fuel cell with a power output of 114 kW and 330 cells. It has a Volume power density of 3 kW per litre.
That means the 114 kW fuel cell takes up around 38 litres of volume! To get 500 kW of power output, you’d need around 160 litres of fuel cells. And that doesn’t include the tanks or battery etc.
There is simply no scenario where you could make a decent F1 race car with the current tech. Even an LMP car would be grossly uncompetitive and they likely have room for more powerful FC stacks etc.
Posted: 27 Aug 2022, 14:18
by mzso
wuzak wrote:
27 Aug 2022, 09:35
Did the 100kg allowance stay the same I don't remember reading that information.
Posted: 27 Aug 2022, 14:27
by mzso
djos wrote:
27 Aug 2022, 14:15
First, you generalize something about fuel cells based on the plainest dumbest hydrogen fuel cell tech.
Then you provide some data, that actually is contrary to your point. 160 liters is not a huge volume, it could be spread around an F1 car. Hell F1 cars had bladders in the 80s that were around 160 liters larger than now...
The actual problem would be the hydrogen tanks.
But yet again: fuel cells doesn't just mean hydrogen. More suitable to F1 would be SOFCs or other direct carbon fuel cells. With a more practical fuel.
