Page 10 of 11
Re: 2014 aero regs revert to 2012 regs
Posted: 23 Jun 2013, 11:14
by OffdutyRockstar
Apologies if there have been subsequent topics on the 2014 aero regulations but can I just say, after scouring the internet for some clarity and intelligent debate on the subject this is resolutely the only thing I have seen which fits that description.
Thank you to all contributors for succeeding where the FIA didn't!
=D>
Apart from mclaren_mircea.
Posted: 23 Jun 2013, 12:05
by WhiteBlue
Just to summarize the discussion the FiA was referring to a plan for a massive change from a flat and stepped floor towards tunnels. That one is not going to happen. But there are other detailed changes that in total bring a relatively new aerodynamic configuration.
- low noses
- narrower front wings
- different side pots
- different engine length, height and width
- different air intake rules and forced induction
- different exhaust rules, position and single end pipe
- no monkey seat
- no beam wing
- new tyre construction with different deformation
The sum of those things amount to the biggest aero change since many years. So the publication of the FiA is a bit misleading although it has some truth in it regarding the change of floor concept that is not going to happen.
Posted: 23 Jun 2013, 14:24
by matt21
whiteblue wrote:
[*]no monkey seat
To me it seems as the still can fit a monkey seat. I didn't find something ruling it out.
Posted: 23 Jun 2013, 17:15
by Huntresa
matt21 wrote:whiteblue wrote:
[*]no monkey seat
Yeah Monkey Seats will be avaible but not structured to fit onto the beam wing.
Posted: 23 Jun 2013, 17:16
by Huntresa
WhiteBlue wrote:Just to summarize the discussion the FiA was referring to a plan for a massive change from a flat and stepped floor towards tunnels. That one is not going to happen. But there are other detailed changes that in total bring a relatively new aerodynamic configuration.
- low noses
- no monkey seat
- no beam wing
Also i think they reverted to having 2 exit pipes on the exhaust but exit will be where we have monkey seat today pretty much and no real way to not have it there.
This one was linked in the other thread bout 2014,
http://somersf1.blogspot.se/2013/01/201 ... anges.html
Posted: 23 Jun 2013, 19:37
by WhiteBlue
matt21 wrote:whiteblue wrote:[*]no monkey seat
There is no body work allowed between 150 and 750 mm vertically as Huntresa's source points out nicely in graphics. This is in contrast to 400mm-730mm today. Where do you think the monkey seat should go?
Posted: 23 Jun 2013, 20:40
by turbof1
WhiteBlue wrote:matt21 wrote:whiteblue wrote:[*]no monkey seat
I think the 15cm on the baseline is an exception.
Posted: 23 Jun 2013, 20:45
by WhiteBlue
And where do you suppose to have your diffusor?
Posted: 23 Jun 2013, 20:53
by Huntresa
WhiteBlue wrote:And where do you suppose to have your diffusor?
You still have the mdidle centimeters free even without beamwing, so you could put a monkey seat on the crash structures top level, if its workable to attach like that.
Posted: 23 Jun 2013, 21:36
by Cuky
Huntresa wrote:Also i think they reverted to having 2 exit pipes on the exhaust but exit will be where we have monkey seat today pretty much and no real way to not have it there.
Well, there will still be 2 banks of 3 exhaust pipes exiting the engine, but they both will be connecting to turbo which will have one exhaust pipe exiting it. So, that is basically one exhaust pipe that exits the car in the middle above gearbox
Posted: 23 Jun 2013, 23:11
by WhiteBlue
Huntresa wrote:WhiteBlue wrote:And where do you suppose to have your diffusor?
In this image you see that there is no way you can have a monkey seat under the rules. The central green exclusion zone is gone. All the space between the diffusor and the rear wing has to be free of body work. No loop hole.
Posted: 23 Jun 2013, 23:59
by Saribro
WhiteBlue wrote:The central green exclusion zone is gone.
Are you sure? With the beam wing gone, where would they mount the rear wing?
It seems unlikely to me that the rear wing downforce is to be carried by the outer edge of the floor before being transfered to the gearbox casing. I'm also concerned about lateral rigidity of that construction. Someone apparently also asked for 2 exhaust outlets, which seem pointless unless you don't want to pipe it over your nice central rear wing mount.
Guess I'll have to catch up on the regulations again some time.
Posted: 24 Jun 2013, 00:56
by rjsa
The green (free) area is exactly the place for the monkey seat. I don't get the discussion here.
Posted: 24 Jun 2013, 00:58
by Absolutelee
I think you misread that WB. He said the green zone will still be free and may lead to the reappearance of rear wing supports, since the beam wing was structural too.
Posted: 24 Jun 2013, 01:02
by rjsa
No, I'm pretty sure the discussion is misguided. The center green area is fair game, teams can do what they want there. The discussion above assumes that the vertical exclusion areas crosses the central section, what it does not.
