Re: Honda Power Unit
Posted: 04 Apr 2018, 23:14
Going by the past record of fixes to this unit?
Don't hold your breath.
Surely limiting things like bore and stroke and v angle and crank throws etc... means the engineers have to spend a huge amount of time investigating tiny variations on things like rod ratio and wrist pin offset etc..? If it's a cost saving measure then it's a classic 'F1 cost saving' measure.Mudflap wrote: ↑04 Apr 2018, 21:58It is all for the sake of cost control. By constraining some of the important engine dimensions they are trying to stop manufacturers from splashing out on expensive DOEs.Revs84 wrote: ↑04 Apr 2018, 18:48What in my opinion is even more surprising is why they limit the bore. Wouldn't the possibility of playing around with bore and stroke lead to some interesting outcomes? It would allow a bit more freedom to manufacturers, rather than an exact same formula for all. This one-for-all approach is what annoys me the most in modern F1.
There's also the off-chance that a manufacturer might get it completely wrong and would need to invest time and money to recover, not unlike Honda.
My guess would be as good as yours but my hunch is design flaw.Mudflap wrote: ↑04 Apr 2018, 23:02Back to the current season:
Honda claimed to have upgraded the turbo/mguh. Considering they had about one week to inspect the failed components, redesign and manufacture new ones (most likely without any form of validation) what are the chances that the new bits turn out to be lemons too ?
Do we know if it is a repeat of the good old bearing issue from last year ?
Does that fact that they have pre-emptively changed Hartley's parts point to a design flaw or a manufacturing issue ?
"During the race in Australia, we had an issue with the MGU-H and turbocharger on Pierre’s car and this had the knock-on effect of also damaging the ICE (internal combustion engine.) Therefore, in Bahrain, Pierre will use a new ICE, MGU-H and turbocharger. The MGU-H and turbo have both been modified, in light of what we learned in the first race.Rodak wrote: ↑05 Apr 2018, 07:01Unfortunately http://en.hondaracingf1.com/races/2018/ ... -prix.html
To be honest, they actually might as well.AJI wrote: ↑05 Apr 2018, 07:10"During the race in Australia, we had an issue with the MGU-H and turbocharger on Pierre’s car and this had the knock-on effect of also damaging the ICE (internal combustion engine.) Therefore, in Bahrain, Pierre will use a new ICE, MGU-H and turbocharger. The MGU-H and turbo have both been modified, in light of what we learned in the first race.Rodak wrote: ↑05 Apr 2018, 07:01Unfortunately http://en.hondaracingf1.com/races/2018/ ... -prix.html
Given the problems we encountered in Melbourne, we have decided, as a precautionary measure, to also change the MGU-H and turbocharger on Brendon’s car, fitting the new modified components.
Replacing components for the second race is obviously a difficult decision and not ideal, given that the number of Power Units and ancillary components is now limited to just three per season, however we believe this is the right way forward and we will continue our development in order to ensure the same issue does not reoccur."
21 races, may as well use 42 PU's.
I couldn't agree more.f1316 wrote: ↑05 Apr 2018, 09:28To be honest, they actually might as well.
This entire season should be a pure R&D exercise - results should be completely irrelevant - as their only job is to create an engine capable of being good enough for Red Bull next year (so minimum as good as or better than the Renault).
If they try to make the engines last, limiting themselves to only two more iterations of design, are they really going to improve at a faster rate than the other manufacturers? Or can they instead find a competitive advantage by completely sacrificing a season, creating up to 20 new specifications across the year - even if it means just changing/experimenting with tiny details that would otherwise be prohibited - and just accepting that they’ll always have penalties. It would be worth it to have a properly competitive PU next year.
I don’t think they would go that extreme and I’m sure TR/the drivers wouldn’t be happy if they did, but there’s actually a lot of logic in it.
The average speed of last years winner was 197 kph.PlatinumZealot wrote: ↑05 Apr 2018, 02:56This track is power track. Hopefully they pull their pants up or they gonna get more sand in ther asses.
Also, if you’re in a TR, you’re not likely to start especially high up the grid anyway - especially with the current spec Honda in the back- so knowing you’re always starting at the back as opposed to sometimes/often starting at the back isn’t really a massive difference (this is the why being out of the McLaren limelight is good for Honda).AJI wrote: ↑05 Apr 2018, 10:45I couldn't agree more.f1316 wrote: ↑05 Apr 2018, 09:28To be honest, they actually might as well.
While my suggestion was extreme and provoked a neg (thanks for that whoever you are...) this is the only way Honda are going to make progress. If the engine freeze happens from 2019, and I can't see why it won't, Honda have only this year to get it together. Both drivers aren't top tier, they're not expecting to win races, so starting from the last position on the grid for every race isn't crazy if it means they can be free to develop. A solid result in Japan should be their main goal this year. A contract for supply from Red Bull is going to take a lot of work now if the deadline is May...
