Re: 2022 Aero Thread
Posted: 22 Dec 2021, 09:05
When Porsche do come back will they use the Pink Pig livery????
Who says it's loopholes, IMO a loophole is something thats clearly against the intentions of the regulations, but not technically illegal. Maybe they have just found an efficient way of using the regulations, kinda like the Mercedes cape, I wouldnt call that a loophole, but just a good idea. DAS, F-ducts, doubble diffusers were loopholes.
It depends on how you define an iteration. I know of a semi-famous engine performance author who claimed to have tested "8000 camshaft combinations" in a relatively short span. He sold is as camshaft changes, but most of it was lash-loops, which are changes, but they're kind of not.
This is true, but as James Allison said earlier this year, given how defined the regulations are you have to be very selective about how you filter what to test (as the obvious way is to ‘iterate the crap out of it’ - which is not possible with the aero-testing cap) the team that model most effectively using ‘hand-calcs’ and other modelling methods will have the most effective filter and, therefore, the most effective aero-testing program.Hoffman900 wrote: ↑23 Dec 2021, 20:34It depends on how you define an iteration. I know of a semi-famous engine performance author who claimed to have tested "8000 camshaft combinations" in a relatively short span. He sold is as camshaft changes, but most of it was lash-loops, which are changes, but they're kind of not.
Really these rule sets are going to reward teams that 1) are very efficient with their CFD and wind tunnel time 2) struggle the least with correlation.
The infrastructure Mercedes and RedBull have develop will put them ahead, imo. You can't unlearn efficiency in design and correlation problem solving, and those two are likely better at it than any other team.
Correct, so Binotto could be either trying to catch teams off guard by suggesting they are having issues or he is trying to pass issues off as a positive to an unquestioning media. It also could be a positive thing. Who knows at this point.This is true, but as James Allison said earlier this year, given how defined the regulations are you have to be very selective about how you filter what to test (as the obvious way is to ‘iterate the crap out of it’ - which is not possible with the aero-testing cap) the team that model most effectively using ‘hand-calcs’ and other modelling methods will have the most effective filter and, therefore, the most effective aero-testing program.
"Rake is likely to disappear as the cars will run low and flat." - Hm. This is quite the opposite to the opinions I saw on this forum.bauc wrote: ↑24 Dec 2021, 11:38Scrabs drawings
https://mobile.twitter.com/ScarbsTech/s ... 67/photo/1
mzso wrote: ↑24 Dec 2021, 12:31"Rake is likely to disappear as the cars will run low and flat." - Hm. This is quite the opposite to the opinions I saw on this forum.bauc wrote: ↑24 Dec 2021, 11:38Scrabs drawings
He also says "most downforce created from underfloor". Which makes me wonder, can't that result in the overhangs and wings and such length decreasing?
If they can make most of the downforce they want with the underbody, why make huge drag-generator wings?
And if you don't need much wings, why make long noses?
Newey has claimed the high rake philosophy is dead for 2022mzso wrote: ↑24 Dec 2021, 12:31"Rake is likely to disappear as the cars will run low and flat." - Hm. This is quite the opposite to the opinions I saw on this forum.bauc wrote: ↑24 Dec 2021, 11:38Scrabs drawings
Again, the rear wing is essenstial to reshape and lift and move away the dirty air of the car. And it needs to be reasonably powerful to do so.mzso wrote: ↑24 Dec 2021, 12:31"Rake is likely to disappear as the cars will run low and flat." - Hm. This is quite the opposite to the opinions I saw on this forum.bauc wrote: ↑24 Dec 2021, 11:38Scrabs drawings
I’m fairly sure that they could accomplish all of this with a smaller rear wing (in fact, any team that really maximises what is achievable with the floor will be able to trim the rear wing - and also the front wing - accordingly), do the rules stipulate a minimum size for plan area and elements for the front wing??Blackout wrote: ↑24 Dec 2021, 14:44Again, the rear wing is essenstial to reshape and lift and move away the dirty air of the car. And it needs to be reasonably powerful to do so.mzso wrote: ↑24 Dec 2021, 12:31"Rake is likely to disappear as the cars will run low and flat." - Hm. This is quite the opposite to the opinions I saw on this forum.bauc wrote: ↑24 Dec 2021, 11:38Scrabs drawings
Without rear wing, the dirty air would remain low, near the track, and disturb the following car.
And to counterbalance the rear wing that sits on the rear end of the car, a front wing is needed.
