Page 2 of 3
Re: F1 Race on the Moon
Posted: 13 Mar 2012, 00:13
by flynfrog
Sombrero wrote:Bernie would be glad : another GP venue with no atmosphere...
I nominate this post for post of the year
Posted: 13 Mar 2012, 00:21
by Jersey Tom
Clip a kerb in a low speed corner and... away you go.
Posted: 13 Mar 2012, 00:51
by PlatinumZealot
Performance would be slower. Less gravity but the same mass to take around the corners. Fuel slosh would be different too.
Posted: 13 Mar 2012, 11:59
by throwaway1
If for some magical reason, this race were to happen right now, when we are still using piston engines, I am guessing the engine balance would be a bit off as well.
Also, the track could probably easily incorporate a loop the loop, which would be pretty cool.
Posted: 13 Mar 2012, 12:48
by angusf1t
I considered this a few years ago myself, and the answer is that it would be impossible for a number of reasons, all to do with the lack of air.
Without air, the engine would not be able to cool itself, and would overheat.
Also, from my memory of thermodynamics, heat engines require a temperature difference between two substances in order to work. I can't see what the lower temperature substance would be on the moon.
Thirdly, F1 engines need a source oxygen, which again is absent.
To make it work you'd need to either use battery-powered cars cooled by radiation only, or run the event in an artificial atmosphere.
If that happened, everything would be the same except the cars would have much less grip, and lower rolling resistance for any given tyre.
Posted: 13 Mar 2012, 14:00
by throwaway1
^No offense, but did almost no one read the original post in its entirety?
I specifically said, sealed off environment, with air(oxygen+ nitrogen + all the rest) pressurized at 1 atm.
Posted: 13 Mar 2012, 14:12
by Richard
Gravity on the moon is 16% of earth, so cars would have total downforce of aero + 0.16 gravity.
What's the current ratio of aero downforce to gravity downforce? 4:1 perhaps at top speed? Say 1:1 on a slow corner?
So the total moon downforce = 4.16/5 = 83% of current downforce at top speed, and 1.16/2 = 58% on a slow corner.
The result would be increased wing AoA to provide grip on slow corners, hence slower top speed.
Posted: 14 Mar 2012, 11:03
by angusf1t
Whoops, missed that bit. Basically as above then. ^
At very low speed (or in the absence of downforce for whatever reason), bumps would pose problems, as would crests. If a car flipped (eg Webber 2010) it would stay airborne much longer and further, too.
Posted: 14 Mar 2012, 11:38
by raymondu999
If I were Bernie I'd incorporate a gap-jump in the lap then
Posted: 14 Mar 2012, 11:43
by Lancelot28
The moon people are notorious tightwads. They'd never pay Bernie's fee.
Posted: 14 Mar 2012, 11:44
by Richard
angusf1t wrote:If a car flipped (eg Webber 2010) it would stay airborne much longer and further, too.
Good point. That would actually be safer for the driver. The aero drag would be the same so the car would slow down more before impact on the ground. It could be a problem for spectators though.
Not sure gravel traps would work, the cars would skim over the top.
Posted: 16 Mar 2012, 03:38
by riff_raff
Since there are at least two different wheeled vehicles still on the surface of the moon, a lunar GP race might be possible. There is the Apollo Lunar Rover which needs a driver, and the Soviet Lunokhod which is unmanned. Both have electric AWD drivetrains.
Getting new cars to the lunar surface for a race would be quite expensive. A moon shot currently would cost about $200,000 per pound of payload, or more than $300 million for an F1 car.
Posted: 21 Mar 2012, 16:19
by ParanoiD
I think I saw it on the advertisement of Total company during a GrandPrix at Star Sports.
Posted: 28 Oct 2014, 11:02
by rohit1594
The Champagne spray would go much farther as well!
Posted: 30 Oct 2014, 14:13
by Blob
firstly, long time reader, first time poster here. Got bored and had 5 min so I thought I would register and post on this for a bit of fun. o/
Several things I would expect to change, assuming normal everything (aero,temps,humidity,tarmac) but just 1/6th gravity.
1: Rolling starts, because have fun getting traction from a normal start hehe. Imagine the power of a F1 car, but in a car that only has a mass of 110-120kg as that on earth will have the same amount of weight and hence similar traction.
2: Higher speed tracks in general, to avoid almost stop start chicanes.
3:More aggressive cars in general (in terms of looking for more DF, ofc with more drag)
4: Possibly softer tyres, depends on how well the mixture of the above work for avoiding/helping with major traction zones from low speed.
(oh and @ rohit, go AOE2!! lol)
