Page 2 of 4
Re: Cottrell's F1 Car [Model] TC2
Posted: 24 Feb 2013, 20:36
by amouzouris
CottrellGP wrote:
amouzouris wrote:I find the heart shaped central hot air outlet very interesting. What is the reason for that?
There is no real reason why, im no aero expert but i wanted the outlet to blow the monkey seat which is quite high up, at the same time i wanted the bottom of the outlet to be as tight as possible so it would blow the center of the beam wing and also let air from the side pods hit the center of the beam wing, so this was the shape i came up with. It might not work but i find the solution the best up to now.
well, I would advice you to not blow the monkey seat with the hot air outlet.
IIRC the car is not simulated fully (as in if the car will burn itself on the first lap) so you can decrease the size of the outlet, which I would advice you to do
Posted: 25 Feb 2013, 00:00
by CottrellGP
I didn't realize the air would be so hot coming out of the hot air outlet, well thanks for that information ill change the design and post some pictures, cheers
Posted: 25 Feb 2013, 00:17
by wesley123
That isnt the main problem. The main problem is that the air quality of this air is crap, I dont see why you'd want that anywhere near your downforce generating parts.
But yes, as amouzouris says, since cooling isnt simulated you are better off making smaller exits/different exits
Posted: 25 Feb 2013, 00:46
by N12ck
wesley123 wrote:That isnt the main problem. The main problem is that the air quality of this air is crap, I dont see why you'd want that anywhere near your downforce generating parts.
there is regulations for the sizing of the outlets
Posted: 25 Feb 2013, 00:49
by CottrellGP
I know there is
Posted: 25 Feb 2013, 00:54
by wesley123
Ah well, I'd asume you can "spread" them much like regular F1 cars do. So not smaller actually, just "reallocating them" lol.
Posted: 25 Feb 2013, 01:33
by N12ck
yes, 8)
Posted: 25 Feb 2013, 08:20
by MIKEY_!
there can be an advantage to aiming the cooling exits at the beam wing etc using the Meredith effect, however air is usually quite turbulent after going over the radiators so can cause more drag. Turbulent air can stick to a surface better than laminar flow which allows higher AoA for wings in this area and presumably more downforce. Of course since none of that stuff is simulated its a bit irrelevant but still good to know.
Posted: 25 Feb 2013, 14:05
by wesley123
There is no advantage, it is dirty air. The air is of crap quality and cant do much than to screw things up.
Teams try to exit the air into nothing and that isnt without reason.
Posted: 25 Feb 2013, 23:23
by MIKEY_!
nope, most aim it straight at the beam wing and monkey seat. If they wanted to get it away from bodywork they could let it out the top of the sidepods as others do. I seem to recall renault even placed their exits on the floor ahead of the diffuser in 2011
Posted: 25 Feb 2013, 23:34
by wesley123
Doesnt mean it is helpful. They aim it there to make the rear bodywork tighter. Renault back then exited a little out of there to get the slope on the sidepod.
I cant even see why you'd want turbulent, dirty air over your wings or anywhere near that. Teams have always tried to get the exits out of the way of wings or other bodywork. Have you ever seen it get aimed at the beamwing? I have always seen downsloping sidepods to get it out of the way for the beamwing.
http://scarbsf1.com/blog1/2011/03/11/renault-r31-cooling-solution-and-diffuser-performance/ wrote: In Renaults case, the airflow running along the floor does not flow directly over the top surface of the diffuser, as these wide vents are in the way. Some people have suggested the teams are directing the heated airflow from within the sidepods out of these vents and over the diffuser for greater aerodynamic effect. However the reality is different, the air coming out of these vents will be of low energy, having passed through the various cooler matrices. Thus its effect in aiding the diffuser is much reduced.
Posted: 06 Mar 2013, 01:05
by CottrellGP
Just a couple of small updates, the front bulkhead has been raised 25mm and the nose has slightly changed. Also the sidepod intakes are a small as the regs state and the rear cooling exit has been shrunk to the minimum it can be. I am still trying to keep this car very simple but effective. I am not going to put all these fancy parts on it.
Posted: 20 Mar 2013, 20:26
by CottrellGP
Thought i would do a Coanda style exhaust just to see what it would look like, yes i know it not great but it was a test, i have refined a few more parts, Diffuser, New front wing on the way, Floor, Rear wing, Tighter sidepods at rear and nose cone changes. :)
(Wont be the final diffuser) :P
Posted: 21 Mar 2013, 04:20
by MIKEY_!
coanda exhaust look pretty good to me, just remove the rear face of the bulges so they function as cooling exits (and remove the central exit you have already) and they would be fine, I believe it would be similar to one version of Ferrari's exhausts from last year
Posted: 27 Mar 2013, 12:40
by astracrazy
why have you gone with coanda exhausts when they aren't simulated? its gonna results in a negative effect on your car as you won't have the benefits of the exhaust...
