Page 2 of 12
Re: Ferrari F2008 aero-mech development in 2008
Posted: 28 Mar 2008, 11:23
by axle
Am I blind or have they removed the lower gills for Malaysia?
And is the endplate a funny shape on the inside too?
Posted: 28 Mar 2008, 13:26
by Saribro
axle wrote:And is the endplate a funny shape on the inside too?
Yeah, some sort of groove below the wing, intriguing.
Posted: 28 Mar 2008, 15:15
by axle
Saribro wrote:axle wrote:And is the endplate a funny shape on the inside too?
Actually I didn't mean that as I can see that on the Oz wing too...I meant a couple of bumps further down.
Going back to that groove I'm guessing that's a vortex generator?? Am I right?
Posted: 28 Mar 2008, 15:22
by bar555
No , they are there , take a closer look . I can post a better picture if you like
Posted: 30 Mar 2008, 17:40
by bar555
Posted: 31 Mar 2008, 11:29
by elise787
Has anyone noticed the indentation or curve of the tub just behind the trailing edge of the fron wing and beneath the "mubadala" letters. I don't have a better photo other then this one:
http://www.motorsport.com/photos/f1/200 ... p-0595.jpg
Has anybody got a better photo of front of the tub when the nose cone is taken off? And has any other team done anything similar?
Posted: 31 Mar 2008, 11:53
by timbo
yes the lower part of the nose has kinds 'V' shape to it. Probably makes front wing more efficient. Same idea as the hole in the middle
that was talked so much here.
Posted: 31 Mar 2008, 14:09
by bar555
here are some pictures , the best i have till now
Posted: 01 Apr 2008, 22:20
by MichaelB
Hi all!
I have been hanging around for some time now and would like to thank you all for this wonderful source of information. =D>
In your last post bar555 I have seen something not previously discussed. Or I have missed it, sorry if i did. Look at the last picture (
http://f1.gpupdate.net/en/photolarge.ph ... 56&catID=9) provided by bar555. Under the chassis right behind the nosecone and in front of the splitter(?) , the one that divides the airflow around the bargeboards from the one to the radiators, it is "pi shaped", is a keel like structure with a bulb or teardrop below. It looks a little bit like the ones used for America's Cup yachts. See the picture here (
http://www.cnn.com/interactive/sailing/ ... m/boat.gif) for reference. You can also see it in these two pictures (
http://f1.gpupdate.net/en/photolarge.ph ... 24&catID=9 and
http://f1.gpupdate.net/en/photolarge.ph ... 56&catID=9) right behind the lower part of the x shaped support structure. Here are two more from different angles:
http://f1.gpupdate.net/en/photolarge.ph ... 15&catID=9 and
http://f1.gpupdate.net/en/photolarge.ph ... 27&catID=9. It can be hard to find depending on your screen setup. I had to zoom in and overbright and overcontrast them for a good view. Any ideas on what this structure does? Obviously to channel the airflow to the desired parts, but if anyone has more information on this how it works and if it is used by other cars please share.
Thank you
Michael
PS: Maybe it is nothing and just an illusion, but I can't link this to any other known (to me) structure.
Posted: 01 Apr 2008, 22:31
by bhall
It's ballast.
Posted: 01 Apr 2008, 22:37
by scarbs
ITs not ballast, its an optimess laser speed\slip angle sensor. Most teams run them on friday and in testing to aid set up.
Posted: 01 Apr 2008, 22:54
by JiMbO
it looks very small to be ballast?? even it it is lead...
Posted: 01 Apr 2008, 23:11
by bhall
I always thought it was a tungsten ballast. Live and learn.
Posted: 01 Apr 2008, 23:16
by GTO
scarbs wrote:ITs not ballast, its an optimess laser speed\slip angle sensor.
Pardon me scarbs, but in layman terms pls.
Sensing -car speed? Slip-angle of what?
Posted: 01 Apr 2008, 23:26
by Saribro
They're running it during qualifying too though (which would imply race too), so I'd assume there's at least a second function to it.
[EDIT]For the sake of clarity:
