Page 11 of 16
Re: FOTA agrees to drop KERS from 2010
Posted: 03 Aug 2009, 20:51
by ISLAMATRON
xpensive wrote:As usual, you have a very polite way to xpress yourself.
An xtra 2000 Rpm would probably not be very far from another 80 Hp.
politeness is my calling card
these engines are not designed to get 2K more rpm, not since they were changed for the 18K rpm limit. even if they could it would shorten engine life dramatically. And it is nothing new or innovative... why the fight against new technology?
Posted: 03 Aug 2009, 20:56
by xpensive
Those engines were initially designed for 20k+, why I imagine they could do it again, for six seconds a lap.
If you would care to study some of the calculations made above on this thread, we could perhaps discuss your last question.
Posted: 04 Aug 2009, 01:07
by ISLAMATRON
tok-tokkie wrote:xpensive wrote:While knowingly running the risk of repeating myself into absurdity, it's something like that you need to make KERS viable.
A 700 kg car reducing its speed from 250 to 100 km/h, five times over one lap, is still only 7000 kJ of kinetic energy.
At the same time, an F1 car spends more than 500 kJ of wheel-energy per second when at full power.
One liter of gasoline holds 34 000 kJ and the car spends some 3.5 to 4 liters per lap.
In a way Mario Theissen was right on KERS, but you need to let the dogs out of their boxes.
Using those figures I get this:
KERS can get 7 000 kJ per lap
1 litre = 34 000 kJ
3,6 litre per lap
Engine efficiency 33%?
So the 7 000 kJ from KERS would replace 21 000 kJ from the fuel
So it will save 21/34 litres per lap = 0.61747
The race is 60 laps
So it will save 60 X 0.61747 litres = 37.06
Density of fuel about 0,737 kg per litre
So the weight saved is 37 x 0.737 = 27.269 kg
So a KERS car (without restricted use) would start off 27 kg lighter next year when there is to be no refueling. That would be a great advantage.
xpensive wrote:Those engines were initially designed for 20k+, why I imagine they could do it again, for six seconds a lap.
I have previously seen your anti-KERS mathematics xpensive and I have previously countered you saying that the idea is to get more energy using less fuel, anyone can dump more fuel into the engine, that is not a technical accomplishment. We have all agreed that unrestricted KERS is how they should have gone in the first place, and if that were the case I think everyone would have gone for flywheel based systems. But given the restrictions McLaren has proved that the battery was the best solution. albeit at 100K a pop, but they will make it back when they start putting it in their road cars, and it is reportedly going in the Mclaren road car as well.(not the same one, but a road going variant)
And also it would all compound itself, carrying less fuel onboard allows you to use less fuel again, so would the smaller brakes needed if all wheel KERS where allowed.
The 27kg calculated above would probly be closer to 30 kg since it does not take into account not carrying the initial 27 kg's... it is compounded... plus tire wear would improve since you have to accelerate, corner and brake with less weight.
Posted: 04 Aug 2009, 04:11
by flynfrog
but that would negate the publicity stunt that is KERS I believe Shu's last engine reved to 22k
KERS is a joke and will be on an ICE powered engine its adding unnecessary complexity and cost for little to no gain.
Fuel is cheap batteries are expensive.
Posted: 04 Aug 2009, 10:12
by xpensive
@ flynfrog:
I have really been trying to be polite and simply engineerish on this subject, but KERS is really a technical joke, as the energy recovery is pitiful when compared to cost and complexity.
And to make the energy-recovery more than pitiful, you would need to more or less get rid of the conventional brakes on all four wheels and add a TEN TIMES higher power-generation and storage capacity.
The complexity, weight and cost of such an arrangement we can only begin to imagine.
Posted: 04 Aug 2009, 11:47
by Richard
Hence an engineering challenge, and that adds richness/depth/breadth to the sport.
Posted: 04 Aug 2009, 12:25
by xpensive
I sincerely envy your level of technical optimism Richard, wished I had a fraction of that myself.
Posted: 04 Aug 2009, 13:13
by WhiteBlue
It would certainly be more rewarding to generate competitiveness from efficiency than to endlessly play around with different aero configurations and tyres with narrow operating windows. That is an artificial challenge that contribute nothing to the real world. Ideally F1 should embrace innovation that adresses the needs of the automobilists and not those of nerdy race tyre specialists and aerodynamicists.
Posted: 04 Aug 2009, 13:25
by xpensive
No argument there, but if you follow the avenue of road-relevant aerodynamic thinking, perhaps the entire idea of open-wheel racing could be questioned?
Posted: 04 Aug 2009, 14:16
by WhiteBlue
There are enough studies about that to substantiate the claim that F1 could cut the fuel consumption in half, remain open wheel and maintain or improve the spectacle. It just needs a bit of prodding which usually meets resistance by the likes of Ferrari and Co.
The refuelling ban is a step in the right direction. Full KERS and HERS development, fixed downforce and high efficiency engines are the things that are needed.
Posted: 04 Aug 2009, 14:32
by ISLAMATRON
Word
Posted: 04 Aug 2009, 17:39
by xpensive
Excel perhaps?
Posted: 04 Aug 2009, 19:20
by Richard
xpensive wrote:I sincerely envy your level of technical optimism Richard, wished I had a fraction of that myself.
To an engineer, the words "that's impossible!" sound like "can you can solve this for us?".
Posted: 04 Aug 2009, 19:53
by flynfrog
WhiteBlue wrote:There are enough studies about that to substantiate the claim that F1 could cut the fuel consumption in half, remain open wheel and maintain or improve the spectacle. It just needs a bit of prodding which usually meets resistance by the likes of Ferrari and Co.
actualy tweaking the aero is the pinical of optimizing for effecieny. They run as much DF as they can with the least amount of drag per engine output.
To me reving the engine a few hundered RPM is a much better solution then any kers system. The KERS systems are overly complex and expensive not to mention much worse for the enviroment then a few kilo of fuel. This applies to road and F1 so how is that for your road relavance. I am not opposed to the fuel ban but I dont expect anything ground breaking to come out of F1 its not the place. Lemans would be a better venue since it is an endurnace race not a sprint.
(typed without spellcheck take it easy one me)
Posted: 04 Aug 2009, 20:31
by flynfrog
richard_leeds wrote:xpensive wrote:I sincerely envy your level of technical optimism Richard, wished I had a fraction of that myself.
but we also have to deal with Termodynamics
And that bastard murphy
