Re: To learn and share about dampers / shock absorbers
Posted: 29 Nov 2010, 18:50
Thanks for the info Belatti.
Sorry,
I think we had a slight miscommunication, I did mean to only warm up the gas canister, so that you could see the change from the gas pressure, without the effect of the change in oil viscosity.
But, it´s no big deal. I think, you understand what a change in gaspressure does to your damper graph.
My little "model" calculated the increase of gas pressure to 237 psi, using a starting pressure of 205 psi, but I had to make a guess about your oil volume.
Nevertheless, it shows, that my numbers are not totally "on the moon".
I will post the last part of my "gas spring story" a little bit later.
I agree with Dave about the "valve chuckle", one possible reason could be the piston shape you use.
If it is a standard Penske lin-deg piston, then the linear side has a very large sealing area.
if you compare it with the dig. side or with an lin.-lin.- high flow piston
if permitted by the rules, you could try a modification
going from this
to something like this
reducing the sealing area and thereby the possible cappilar effects of the oil.
The modified piston is also less likely to "stuck-open" when you have condamination inside your oil. As a particle traveling with the oil has less possibility to be traped between the shim and the sealing surface of the piston.
one another note, you could try to turn the second shim (the one on top of the sealing shim) around, or deburring the outer edges of the shim a bit.
Sometimes, this helps
Sorry,
going from this
