Page 13 of 16
Re: 2012 Stalled wings & F/ W ducts
Posted: 16 Apr 2012, 01:33
by bhall
WhiteBlue wrote:So what? It doesn't impact on my theory which could still be right.
I didn't address a theory; I addressed the concept. But I'll keep any theories in mind for the next time I run out of toilet paper. I'll print that bad boy out and give it its proper due. (Get it?)
Re: Red Bull RB8 Renault
Posted: 16 Apr 2012, 03:39
by WhiteBlue
hardingfv32 wrote:I question the quantity of flow into the DRS hole and the quality of this flow when it exits the front wing slot with the Mercedes design. We have photos of four parts, DRS hole, engine area duct, front bulkhead duct, and front wing slot. That is the only information we have about the system design. More than we usually get, but still seems a little weak for me.
So based on those details can you come up with a model that would allow you to put up figures? You say those design detail appear weak to you. Is that a gut feeling or are you guided by an educated guess what would be necessary in terms of cross sections and length?
A properly functioning DDRS system is wonderful idea.
There we would be agreed.
I would agree that the first to a design can make the most of it, but in this case I think they are restricted by physical constraints. I just do not feel they can get the flow required to generate a meaningful performance gain.
Again, I would prefer if you could substantiate your feeling by some figures. Isn't it strange that Merc have gone all the way to design and build it if it were not efficient? And why could they not do an amplification design with the scoop, that I proposed?
Just seems odd that a system that WE have know about since Oct 2011 is not found on any other cars. That would be plenty of time to get a chassis modified and tested before the start of the season.
I'm not so confident that we really knew the relevant detail of the system. In Oct 2011 there was much talk about a passive system that works without any activation. That was what Merc experimented a lot with on the rear wing before. There was also speculation that they had come up with a fluid switch which would detect the steering angle and select a medium, left and right channel for the air flow to the front wing. Even when the unmasking devices were first seen people thought they were related to stalling the rear wing rather than the front wing. I cannot remember that I had heard about the idea to do the drag reduction to both wings. The double diffusor was also something that came out of the left field unless you had had contact to those who had researched the idea.
Posted: 16 Apr 2012, 03:48
by WhiteBlue
bhallg2k wrote:I didn't address a theory; I addressed the concept. But I'll keep any theories in mind for the next time I run out of toilet paper. I'll print that bad boy out and give it its proper due. (Get it?)
It sounds like something rude and not like a contribution to the debate. If I'm wrong please enlighten me.
Posted: 16 Apr 2012, 04:06
by bhall
It was butt a clarification on the subject of my previous statements. There's no debate.
Posted: 16 Apr 2012, 04:16
by WhiteBlue
bhallg2k wrote:There's no debate.
I thought we had different interpretations of the function of the scoop. You dismissed my interpretation. If you are not interested to discuss your idea of the significance of the scoop that is also ok with me. I'm very confident that all aspects will get much discussed by the time we see more design solutions on track.
Posted: 16 Apr 2012, 07:48
by hardingfv32
WhiteBlue wrote:Again, I would prefer if you could substantiate your feeling by some figures.
I started a study on the DDRS but lost interest when the subject cooled on the form. Most of the posters seemed uninterested in applying figures to the subject. There are a lot of assumptions to be made that most on the forum would find difficult to accept.
I have a study with good flow information on the rear wing with a DRS flap. With that I could probably develop a number for the inbound flow and calculate an estimate of the flow losses in the duct going to the FW slot. That is when the real problems start. I have no idea how much downforce the FW generates, much less how much the wing element being blown generates. I have found nothing on the subject of a blown slot that stalls a wing. This would have no value to the aircraft industry. So I have no way to estimate what the effect of a stalling type air flow would have on the downforce numbers. Using studies on wing stalling, I do know that a stalled wing does not mean zero downforce. All of this assumes wings working in isolation which is an example of a assumption that must be made.
So it is a problem with many unknowns for us that I have little motivation in solving at this time.
Brian
Posted: 16 Apr 2012, 10:39
by WhiteBlue
hardingfv32 wrote: I have no way to estimate what the effect of a stalling type air flow would have on the downforce numbers. Using studies on wing stalling, I do know that a stalled wing does not mean zero downforce. All of this assumes wings working in isolation which is an example of a assumption that must be made.
Brian
Fair enough. I don't think the rear wing and the tubes are the problem for estimating numbers either. So in the absence of computational models we should simply keep an open mind for any possible design configuration and not dismiss any out of hand.
Here is what Horner had to say about a Red Bull DDRS:
I think there's been a lot said and a lot of fuss about it. They've optimised and capitalised on it so inevitably now we'll all pursue our own solutions. I think first of all, like any component, it has to earn a place on the car as a package. It's not a given that on everybody's car it's bolt-on lap time.
The main point here is that Horner thinks it is effective for Mercedes. Perhaps that is a first point we can all agree on.
Posted: 16 Apr 2012, 18:11
by WhiteBlue
Lotus technical director James Allison on Formula1.com
We are at the point of making estimates of how big the gain might be and assessing the difficulty in actually realising that gain. It’s anyone’s guess how powerful any existing system is, but that’s not the issue; it’s how powerful we think we can make any system which we can develop now we know how the rules can be interpreted. There are systems like Mercedes has, but the interpretation allows other permutations too. So it could be an interesting time for developments in this area.
So I take it as a given that all competitors down to Lotus will have a similar system. By the end of the year all point scoring teams could have it.
I think this will be an issue for all season.
Posted: 16 Apr 2012, 19:27
by hardingfv32
WhiteBlue wrote:Lotus technical director James Allison on Formula1.com
We are at the point of making estimates of how big the gain might be and assessing the difficulty in actually realizing that gain. It’s anyone’s guess how powerful any existing system is, but that’s not the issue; it’s how powerful we think we can make any system which we can develop now we know how the rules can be interpreted. There are systems like Mercedes has, but the interpretation allows other permutations too. So it could be an interesting time for developments in this area.
No, it is not a given. Allison clearly indicates that they have come to the conclusion there is a net benefit from the DDRS. They are not going to do a system that has no benefit.
What I fine odd about his statement:
Why would they still be evaluating the benefits of such a system? Seems like very poor team management to wait until you loose a protest/ruling to start developing this system. While we have no information to make such a judgement, the teams have their cars accurately modeled in CFD and can do such evaluation with easy. Their solution should have been waiting for the fabrication go ahead at this point in time. I question wether they will actually pursue the DDRS theme.
Brian
Posted: 16 Apr 2012, 23:13
by WhiteBlue
hardingfv32 wrote:What I fine odd about his statement:
Why would they still be evaluating the benefits of such a system? Seems like very poor team management to wait until you loose a protest/ruling to start developing this system. While we have no information to make such a judgement, the teams have their cars accurately modeled in CFD and can do such evaluation with easy. Their solution should have been waiting for the fabrication go ahead at this point in time. I question whether they will actually pursue the DDRS theme.
DDRS has implementation issues as we know. If you do it the way Mercedes have done it you have to re homologate the tub which would appear to be a problem. At minimum it will absorb substantial resources. In the worst case it could be prohibited by the RRA. There was one more positive report the last week end by Marc Surer that re homologation is prohibited. In that case you can only cross the tub externally which would make the solution aerodynamically compromising.
Posted: 17 Apr 2012, 01:04
by e30ernest
hardingfv32 wrote:Why would they still be evaluating the benefits of such a system? Seems like very poor team management to wait until you loose a protest/ruling to start developing this system. While we have no information to make such a judgement, the teams have their cars accurately modeled in CFD and can do such evaluation with easy. Their solution should have been waiting for the fabrication go ahead at this point in time. I question wether they will actually pursue the DDRS theme.
Brian
I read an interview from one of the team principals last night regarding the matter (I can't remember if it was Horner or someone else). He basically said, the system had to earn its place in the car as a package, only then could they start thinking about doing wind tunnel or CFD tests on it. Their CFD and wind tunnel tests are pretty limited, and they are very careful where to spend that time on.
Posted: 17 Apr 2012, 01:21
by ESPImperium
I recon after the lessons learnt from 2010, most teams wont persue a DDRS system, id recon that one or two teams will copy it. Red Bull in 2010 spent €10m on their wireing loom upgrades accross the season for their F-Duct, and only €1.2m on development of the actual system itself. Fabrication costs of the F-Duct per car were a rumored €140k per car and Red Bull only fabricated 7 of them in total as their system was strong enough to begin with due to them having a good enough hole in the chassis to rout thru.
Whitch is the main area of the DDRS that is key, it is a cheap system in F1 terms, it only costs about €600k to develop and the same to get 4 ducting systems made, but developemt of the wiring loom is gonna cost as you will loose data channels to start with and as many team have just got about 30% more than the last day testing open, thet wont loose that now since things are so close this year. They say that a tenth of a second in F1 costs €1m development, the 0.5 of a second (For Mercedes) that the DDRS gives you will be a no brainer for some teams lower down.
Id recon that the teams that will try and get the system on will be Sauber and posibly Williams and probably by Ferrari as they need all the laptime they can find. The rest i think will battle on without, whitch will be either the right or wrong decision.
One thing is for sure, if it isnt protested, Mercedes will have such an advantage at Monza, Spa and Canada. One story said DDRS was worth .5 on a normal track, it would be worth up to 3 times more on those tracks gearing dependant.
Posted: 17 Apr 2012, 01:57
by hardingfv32
WhiteBlue wrote: If you do it the way Mercedes have done it you have to re homologate the tub which would appear to be a problem.
So then we need a system that is located forward in the chassis. I am not going to restrict the design to an interaction with the DRS system. We can know do better.
How about using the steering shaft/column as a barrel valve. Say a 2-3" OD steering column that has slots in it to provide the 'turn or straight' air control that we desire. The FIA protest ruling seems to open the book to some very interesting 'secondary use' applications.
This just addresses the flow control at this point.
Opinions?
Posted: 17 Apr 2012, 02:16
by WhiteBlue
ESPImperium wrote:Whitch is the main area of the DDRS that is key, it is a cheap system in F1 terms, it only costs about €600k to develop and the same to get 4 ducting systems made, but developemt of the wiring loom is gonna cost as you will loose data channels to start with and as many team have just got about 30% more than the last day testing open, thet wont loose that now since things are so close this year.
I think you cannot necessarily compare F-duct and DDRS in terms of cost for the wiring loom. The F-duct must have used additional I/Os to cause that effect on the wiring loom. The Mercedes style DDRS should not really need additional I/Os. Perhaps I'm overlooking something. Please comment!
This just addresses the flow control at this point. Opinions?
A passive system would not be a problem IMO. The system that leaches control from the steering would be different to the known DDRS. The DRS has a dedicated signal that is activating the drag reduction of the rear wing. To have it activating the front wing as well does not change the objective of drag reduction. It is still in the envelope of the intended use.
The purpose of steering input is to drive the car around the corner. If you piggy back another function onto the steering system you would open up the dedication of the steering signal to the activation of an aerodynamic device. I do not see the same functionality and dedication in the two systems and I am afraid the FiA would also object.
Posted: 17 Apr 2012, 03:29
by jamsbong
One thing I wonder about stalling both front and rear wings or Double-DRS.
Won't the changed in air-flow from the front wing affect the underbody airflow?
If so, then the car could loose a lot of downforce as the underbody is responsible for over 50% of the downforce.
Also, I wonder if the front wing F-duct is passively active? If so, then it would be fast even without DRS activated.
