Re: TERS : Thermal Energy Recovery System
Posted: 19 Mar 2014, 11:30
@ she
as one who has also questioned the fashion for the buzzword 'heat'
in my steam-age way I reposted yesterday at 2030 on p420 of the Formula One 1.6 thread earlier references to exhaust recovery
particularly the position by Wright that their recovery cost no crankshaft power, this a hot topic in that thread
they sold 14000 such engines
there is also a reference etc to energy balance for these engines
regarding impediment to exhaust flow
to avoid the losses you mention, all piston engines necessarily create other losses in 'blowdown' (choked) from around 7 bar
ie much of use is lost in the exhaust before any recovery turbine
1940s work by the NACA showed (compounded) efficiency highest at high mean exhaust pressure, due to less KE loss in blowdown ?
(also around 5-6 Aug 2013 I posted in the above thread including a link to this (NACA 822) and commented on NACA 1602)
this operation, even into actual backpressure, is relevant to current F1
(of course for most aviation propulsion applications exhaust can be better used in other ways)
F1 mgu-h units are 80 kW or more, most of their output would be used real-time (near-continuous mgu-k motoring), not stored
