Page 159 of 268
Posted: 31 Aug 2025, 23:38
by diffuser
eyelid wrote:
31 Aug 2025, 10:29
wuzak wrote:
31 Aug 2025, 09:16
eyelid wrote:
31 Aug 2025, 09:08
And that is just by pressing brake pedal on straigths under full throttle, so it's braking energy imho, not ICE charging the battery straightly.
No, the brake pedal won't be pushed when at full throttle.
There will be a braking effect.
At part throttle, the recovery will be the difference between what the ICE can deliver and the driver demands.
I see. That wasn't visible on the posted energy flow diagram what I quoted. This is now interesting. Any proper video explanation of all these? I guess the rules are way too complex when even hardcore fans has hard time following them.
F1 was never a simple sport. If you thought it was, that was just an illusion.
Posted: 01 Sep 2025, 06:27
by saviour stivala
In 2026 there will be no other form of harvesting allowed beyond regenerative braking, as the primery way energy is recovered is through the MGU-K which functions during braking and decelleration. The actual brakes, the braking hardware, stipulated as to have a stopping power of 2500 Nm of torque per wheel, without the use of other systems, such as the MGU-K, must be on the car, but there is freedom as to how they are used, the brakes might not be used at all, and only the MGU-K harvesting deceleration will be used, at least in most corners.
Posted: 01 Sep 2025, 08:46
by eyelid
Engine rules were simple to follow to this day - now even published official energy diagram is giving false information indicating some teams will brake the engine rules if charging up the battery via ICE. It's not allowed by published rules.
Edit
By Discussing with AI this really looks like that only way to charge battery is via MGU-K by terrible excuses and politics. By a car engineer point of view this looks like driver is trying to brake ICE and MGU-K by putting braking pressure under full throttle on same time on straights. (and even on tight curves according to some A. Newey)
What is going on at Formula 1 really....We may have a good laughs on next season. Even first tests are Top Secret because they know this is going to be a scandal but can't prevent it anymore.
Posted: 01 Sep 2025, 09:26
by DenBommer
eyelid wrote:
01 Sep 2025, 08:46
Edit
And would this be better if they had a front generator?
Posted: 01 Sep 2025, 09:34
by wuzak
eyelid wrote:
01 Sep 2025, 08:46
It is very clearly allowed by the published rules.
wuzak wrote:
28 Aug 2025, 11:07
C5.12.6 The driver maximum power demand must not be reduced at any greater than the rates defined below:
a. 50kW in any 1s period at Competitions where the FIA determines that the power limited distance exceeds 3500m. These Competitions and the vehicle fundamentals used for the calculation of the power limited distance may be found in the document FIA-F1-DOC-Cxxx.
b. 100kW in any 1s period at all other Competitions.
Furthermore, the total power reduction is limited to a maximum of 600kW and the resulting electrical DC power of the ERS-K must remain above −250kW.
Driver maximum power demand is when the driver is at full throttle.
The rule explicitly states that the MGUK output can be reduced to 0 (must be reduced above 290km/h) and then go into energy recover, up to 250kW. But only when the driver has maximum demand (full throttle).
There is another rule that adjusts fuel flow to control the amount of recovery by the MGUK.
Posted: 01 Sep 2025, 09:41
by wuzak
eyelid wrote:
31 Aug 2025, 10:29
wuzak wrote:
31 Aug 2025, 09:16
eyelid wrote:
31 Aug 2025, 09:08
The energy flow diagram only shows the maximum power to and from the battery to the MGUK, and the maximum energy that can be recovered in a lap.
Note that the energy that can be deployed in a lap is unlimited.
Also note that the maximum energy that can be recovered in a lap is the maximum possible, but will be lower for many circuits.
Also on the chart is the nominal battery capacity of 4MJ (maximum delta state of charge), and the storage capacity in the control electronics/MGUK of 1MJ.
Posted: 01 Sep 2025, 10:45
by mzso
wuzak wrote:
01 Sep 2025, 09:34
But it's still possible to recover at partial power demand isn't it? And off throttle?
Posted: 01 Sep 2025, 10:50
by Tommy Cookers
DenBommer wrote:
01 Sep 2025, 09:26
a front generator and a differential and some gears and 2 shafts
interconnection of the front wheels has been banned for many years
Posted: 01 Sep 2025, 11:02
by mzso
Tommy Cookers wrote:
01 Sep 2025, 10:50
DenBommer wrote:
01 Sep 2025, 09:26
a front generator and a differential and 2 shafts for driving the generator
any such interconnection of the front wheels has been banned for many years
I think the question implicitly asks: what if it was allowed? (The regs were proposed with front generation at first.)
Posted: 01 Sep 2025, 11:21
by DenBommer
mzso wrote:
01 Sep 2025, 11:02
01 Sep 2025, 10:50
DenBommer wrote:
01 Sep 2025, 09:26
Indeed, that’s my question, purely hypothetical. What if they had a front generator?
I know a front generator would add some extra weight, but look at how lightweight F1 brakes are compared with a normal street car. I believe they could make a very small, lightweight, compact front generator (using axial-flux technology).
Posted: 01 Sep 2025, 11:59
by eyelid
wuzak wrote:
01 Sep 2025, 09:34
I think this rule will slow these cars radically on straights then and wastes so much energy doing so. I know the aero-rules also changes to compensate that, but looks like 370kmh monza speeds are out of the question now and more like GP2 car straight speeds for now.
Is it dangerous to go brake energy harvesting at 290kmh only on rear axle? What about in wet conditions?
Posted: 01 Sep 2025, 15:32
by karana
eyelid wrote:
01 Sep 2025, 11:59
wuzak wrote:
01 Sep 2025, 09:34
The rule itself doesn't slow the cars, it actually prevents them from harvesting at 350kW and hence from slowing the cars too much. Harvesting at full and partial throttle is anyway something that can be done already with the current PUs.
With an assumed ICE power of 400kW, harvesting at 250kW will still mean a net power of 150KW. What's supposed to be dangerous about it?
Posted: 01 Sep 2025, 15:55
by saviour stivala
Energy harvesting at full and partial throttle is somthing that can be done at present through the MGU-H which will not be in use next year.
Posted: 01 Sep 2025, 16:06
by diffuser
DenBommer wrote:
01 Sep 2025, 09:26
eyelid wrote:
01 Sep 2025, 08:46
Edit
Front brake regeneration wasn't a F1/FIA choice. It was blocked by most of the current teams with the thinking it would give Audi too much of an advantage. Mercedes led that charge of blocking front brake regeneration.
Posted: 01 Sep 2025, 16:08
by diffuser
karana wrote:
01 Sep 2025, 15:32
eyelid wrote:
01 Sep 2025, 11:59
wuzak wrote:
01 Sep 2025, 09:34
Plus they have kind of a double drs with both front and rear wings.
