Page 176 of 178
Re: Will Electric Vehicles Be Viable? When?
Posted: 09 Jan 2022, 13:47
by Jolle
Stu wrote:
09 Jan 2022, 13:32
Jolle wrote:
09 Jan 2022, 12:28
Stu wrote:
09 Jan 2022, 11:23
There is a very good reason for that, but it is political so we cannot talk about it.
Aside from political, it’s also impossible not to implement something like that.
Let’s say, in 2050 all the commuters have their electric company car, they all get home at around six-ish and plug in their cars. The overcapacity needed for that first hour would be so big, that you’ll need extra powerplants just to cope with that short recharge every day.
When I was at uni, the power would go down every morning around half past eight.. turned out, all the teachers were turning on their Senseo machines to make themselves a cup of coffee…
As far as the UK requirement goes it becomes political because domestic solar generation cannot be used, by law. Only a matter of time before Excise Duty (at above domestic rate) is applied to EV charging at home. Sneaky.
But that is political…..
I'm not denying the political element (or the commercial/tax possibilities). But you must agree that with this new addition to the power grid, a new way of thinking how to use it must be made. We just have to be critical how. The good way would be (in my opinion) to have the opportunity to use cars as a buffer, so the grid is less dependent of (very polluting) coal and gas turbines and a way to get power of the grid when it's cheap etc etc.
Posted: 09 Jan 2022, 15:13
by Stu
Totally agree with that, the big solution is to require new homes to be built with PV solar, Axial wind and (if/where possible) ground-source thermal in combination with battery storage (and the EV should extend that capacity when plugged in). Existing homeowners should be ‘encouraged’ to add the same. In the long run it becomes a far more cost-effective method of expanding the grid (which is a mammoth undertaking) while at the same time encouraging homeowners to be efficient with their power consumption (prioritise needs over wants).
Just my opinion (and one that I have held for a long time).
Posted: 09 Jan 2022, 23:07
by Greg Locock
The problem is that you are using your hugely expensive car battery to prop up the grid, whereas a proper grid battery costs around 1/3 of a car battery per unit of storage. So the EV owner is subsidising the grid.
Posted: 09 Jan 2022, 23:26
by Jolle
Greg Locock wrote:
09 Jan 2022, 23:07
There are different scenarios of course. One is a very dynamic one, where you can rent out the storage in your car as a damper for the grid. This is probably what you are referring to and for a lot of people not ideal. But, for another scenario you plug in your car in at 6, knowing you want it charged at seven in the morning and the system is charging it with overcapacity of the grid. With enough cars on the grid, this should be more then enough.
A third scenario is that your car is your personal storage damper, especially when you don’t use it often. You can run your house from it and buy in power when it’s cheapest (or use your solar panels.
In a few years time discarded car batteries are probably also will be put in use for this on scale. The Amsterdam Arena already has something like this in place for concerts, where they have a ton of old leaf batteries providing the peak amps for basdrum hits. Energy suppliers charge a lot for peak power..
Posted: 10 Jan 2022, 00:10
by Big Tea
Jolle wrote:
09 Jan 2022, 23:26
Greg Locock wrote:
09 Jan 2022, 23:07
There is also the 'discount' option You allow us to take power from you at the 'going rate' and when you recharge you get off peak (say) 1.2 -1.4 units for each taken depending on when you want them.
Posted: 10 Jan 2022, 00:55
by djos
Here in Australia, virtual power plants are growing in popularity - I've ordered a Tesla PW2 and signed on as part of AGL's Victorian VPP which gave me a small discount on the cost of the battery and a few other perks.
Part of the agreement is that they won't take more than 20% of my storage capacity per day so I don't have to worry about them draining it and leaving me with no stored power.
Posted: 10 Jan 2022, 13:50
by Zynerji
djos wrote:
10 Jan 2022, 00:55
Watching the Australian gov right now would make me terrified of putting any trust in them. 20% today quickly becomes 100% due to a declared "emergency"...😬
Posted: 10 Jan 2022, 22:44
by djos
The one I joined is a private vpp, there are State gov run vpp’s but not in Victoria where I live.
The fed gov has been MIA ever since Scotty from Marketing took over. In his own words, “I don’t hold a hose mate”. Sums up his entire Tenure.
Posted: 14 Jan 2022, 08:28
by Andres125sx
djos wrote:
10 Jan 2022, 00:55
Interesting, what was the discount?
I´ve been searching for alternatives to use a EV battery as a home storage too, I tought there was some car wich made it possible, but can´t find any now so maybe I´m wrong. That was after doing a search for recycled EV batteries, but the only site I found sell those batteries at a higher price than a brand new liion battery for home ](*,)
There´s a two way charger to use any EV as a home battery wich is the best idea I can think about, but the price is so high (>20k€) it´s absurd
With this prices I´m going to give up and install only some few PV panels without any battery
Posted: 14 Jan 2022, 08:45
by djos
I can’t recall the specifics, but the total installed cost was $12k AUD. It was only about $1k off but considering how hard they are to get ATM, I’m hair with that price.
Posted: 15 Jan 2022, 09:23
by djos
Interesting, looks like city buses using hydrogen are 6x more expensive than pure BEV buses.
Posted: 15 Jan 2022, 09:35
by Greg Locock
Yes it does at the moment. CSIRO and various other parties are getting fairly excited about pV+water=H2, and are claiming $2 per kg as a target. Then they have to move it from the outback to wherever it is going to be used. As I've said before converting it to methane or ammonia seems to me to be the best approach for distribution.
There are a long list of problems to be solved, not least exactly how much extra it will cost to get water that is pure enough to start with.
Posted: 15 Jan 2022, 09:56
by djos
In this case it was city buses, I do think that for long haul trucking, bus and rail transport, hydrogen makes sense. Should be interesting to watch this develop.
Posted: 15 Jan 2022, 11:17
by Stu
djos wrote:
15 Jan 2022, 09:56
Mercedes have been working on this for years, they had prototype Fuel Cell buses in operation over 20 years ago, back then they had a quoted ‘price’ of £1 million.
Posted: 15 Jan 2022, 11:54
by djos
Stu wrote:
15 Jan 2022, 11:17
djos wrote:
15 Jan 2022, 09:56
It’s not the upfront cost that is the issue in this video, it’s the ongoing costs of FCV buses are 6x those of BEV buses.
