The petrol engine was derived from a 3.8 L standard V8 modified with automatic cylinder shut-off that temporarily shut down four chambers, resulting in the fuel consumption figure for the Euromix driving cycle being reduced to just 9.3 liters per 100 kilometers.
T diesel version had a 3.3-litre six-cylinder diesel engine with twin turbochargers, and managed a fuel consumption of 7.5 liters per 100 kilometers at a speed of 120 kmh
the third version that was the most pioneering: a gas-turbine engine which brought several benefits, including low-pollutant combustion, low weight, compact dimensions, favorable torque characteristics and the elimination of water cooling.
The concept was still considered novel when it was used in the Jaguar C-X75 of 2010 – a testament to how forward-thinking the early-1980s Mercedes engineering department was.
CART cars of that era all had pretty cool era. This is 1998s Penske PC27
CART cars always looked great and the racing was awesome - I hope Tony George dies a horrible painful death for his role in destroying American open wheel racing!
Re: Most pec...bizarre aerodynamics thread.
Posted: 10 May 2015, 05:13
by wesley123
SuperGT always is interesting.
Posted: 14 May 2015, 08:44
by J.A.W.
Is that the Lexus DTM equivalent?
Posted: 15 May 2015, 02:32
by gixxer_drew
Yes, it is.
Posted: 07 Oct 2015, 22:59
by wesley123
Bumping with a pic of the DTM diffuser.
Never would have imagined the throat to be that wide.
Posted: 08 Oct 2015, 21:52
by variante
wesley123 wrote:Bumping with a pic of the DTM diffuser.
Great shot! That diffuser reminds me of something...
Posted: 08 Oct 2015, 22:55
by machin
Yeah, that is a good photo! Would be interesting to see a better one of the front too...
Posted: 09 Oct 2015, 00:29
by RicME85
Aye did think it was pretty similar
Posted: 09 Oct 2015, 04:05
by hpras
Technically.... since it starts well before the rear axle, wouldn't that be called a ground effect tunnel?
Posted: 09 Oct 2015, 08:14
by machin
Well technically a diffuser is simply a section of geometry with an expanding cross section that is used for pressure recovery of the flow. This fluid separator has a diffuser for example:
So whether you call that underfloor configuration "ground effect tunnels" or not, its still the diffuser section that Variante was talking about.
