Page 20 of 29
Re: My F1 car - LegendaryM
Posted: 21 Apr 2010, 18:22
by LegendaryM
Posted: 22 Apr 2010, 05:02
by wrcsti
You should change your sidepods to have higher rears. The current ones look like they could cause some lift.
Posted: 23 Apr 2010, 19:22
by LegendaryM
Some updates:
A completely new upper deck on the front wing:
it is designed to produce more downforce and to create a greater area of low pressure near the endplates, to further help in directing air from the upper surface of the main plane through the endplates and around the outside of the front wheels
A brand new engine cover, the previous one was more of an interim solution. Also I have changed the rear wing to have 2 support pillars instead of one central one.
Posted: 24 Apr 2010, 13:57
by LegendaryM
not an update, just something which has been on the car for a while but because of its position is very hard to see in full detail:
The beam wing (the lower rear wing element) on my car has a blown slot fed from both the central 150mm and outside the endplates. As only 1 cross section is normally allowed here, blowing allows the wing to be put at a much higher angle of attack, helping the diffuser
Posted: 19 May 2010, 20:28
by WorboysGP
LegendaryM, this car is outstanding. I run a FOG Formula 1 Team on Piczo (
www.f1game.piczo.com) my website is (
www.wmotorsport.piczo.com) im looking for a 3D CAD designer for my race team and i think you will be perfect.
all you have to do i come up with ideas put them into a 3D CAD model and then send it to me while i make a similer idea with the FOG Rule Template. Any Questions please email me at
[email protected].
Thanks,
Posted: 22 May 2010, 23:19
by LegendaryM
Posted: 22 May 2010, 23:25
by LegendaryM
Posted: 23 May 2010, 00:00
by wesley123
Lovely upgrade mate, i am certainly gonna get some inspiration by this!
Thoguh(as always) I have a few ideas. In front of the diffuser most teams add an hole, to seal the rear wheel. Might check it out, i am going to implement such an idea, also what i have on my car(and what i will retain for 2011) is the part in front of the rear wheels, it is similair to you flick up, but it is multiple parts, bent up to the end thus allowing more 'regular' air in fornt of it. Also i am going to add such an duct in front of the flip ups and i will use it on other parts too, just to draw air udner the floor.
Also i am thinking of an way to actually still be able to use some sort of double decker, but i didnt came up yet with an idea.
Really Great upgrade!
Posted: 28 May 2010, 01:23
by hopless17
AMAZING CAR WOULD YOU U LIKE TO TEACH ME HOW TO DESIGN A GREAT CAR LIKE THAT IVE TRIED TO DESIGN ONE CAR BUT I DIDN4T FINISH IT PLEASE HELP ME
Posted: 28 May 2010, 07:39
by raceman
@LegendaryM
since you started posting your car designs, I started to hate and envy you!
very good car you have designed mate, gr8 work. =D>
Posted: 29 May 2010, 18:26
by LegendaryM
wesley123 wrote:Lovely upgrade mate, i am certainly gonna get some inspiration by this!
I planned to add one, and here it is:
I've also moved the exhaust to the side so that some of the hot gases go through the hole and under the floor.
I have also designed a new diffuser (this one doesnt have the endplates coming down to the floor like the rb5) to work better with the floor cutouts
I have had to remove the shark fin as according to autosport shark fins connecting to the rear wings are being banned for 2011
Also, i have gone back to more conventional front wing pylons as the previous splayed design was illegal. I have also increased the angle of attack of the front wing.
Posted: 30 Jul 2010, 20:28
by Joao
LegendaryM wrote:
Howdy!
I and a few friends of mine, are planning to actually build an F1 car.
We do not have the money to use carbon fibber...
But yet again, we plan to use fiber glass arround a frame chassis.
We plan to use rapid prototyping to build most of the parts.
And i was wondering if you authorized us to build one of your cars....
We needed you to provide us with a few sections... more like slices in order to build the mould...
By the way, good job.
Posted: 31 Jul 2010, 10:18
by LegendaryM
Joao wrote:
Howdy!
I'd be happy to send you the 3d model of the car. What format would you prefer?
An update:
1. A new cascade element, which bends down to direct air away from the front wheels, similar to mclaren's second endplate.
2. the camera housings have been moved to behind the front wing supports.
3. I have added a shield infront of the front wheel rim, similar to the F10
4. I have added mercedes style vanes
5. I have added an airbox winglet, which can be quite large due to the thin rollover structure
6. I have added a fence along the side of the floor to reduce the amount of air going from the top to under the floor.
7. I have tightened the rear bodywork
8. I have added an exhaust blown diffuser by moving the exhausts backwards and adding some vanes. Here is a better picutre (i have hidden the rear wing and rear suspension
Posted: 31 Jul 2010, 12:47
by wesley123
wow, as always an lovely update mate!
Though i can say that 6 wont work, with your idea of air flowing to the underbody, this simply creates an much less effective underbody which is much more sensitive to crosswinds and pitch/yaw.
Let me explain, you have winds from the side(like in silverstone for example), alot of this that would go over the floor would now flow under that, you create effectively flow that is in an way other direction then you want to have it, flow that goes down the length of the car. What this does is simply jsut choke the underbody and stall the diffuser, which is completely not what you want.
Overall, with your new update the car is simply impressive, i was having the same idea with the rear diffuser, by creating such an part you can create an bigger low pressure zone allowing beter evacuation of underbody air.
Posted: 31 Jul 2010, 13:28
by LegendaryM
wesley123 wrote:wow, as always an lovely update mate!
yeah i see.
