Re: why cant we have f1 downforce on road cars
Posted: 17 Nov 2015, 04:26
You are massively over-estimating the capabilities of active aerodynamics and suspension.
It's far from irrelevant. McLaren claims P1 generates 600kg of downforce. It would need 600% more to achieve equivalent performance to that of an F1 car due to its heavier weight, and an aero package capable of creating such prodigious downforce can't just be folded up and stowed away at the push of a button.Erunanethiel wrote:For those who says downforce increasing drag, it is irrelevant for cars like p1 since you dont have to have the spoiler etc up all the time, a push of a button solves that problem.
The answer is in the question itself: because it's a road car.Erunanethiel wrote:why cant we have f1 downforce on road cars
And what that prodigious downforce would achieve is getting people killed, driving faster than they should.bhall II wrote:It's far from irrelevant. McLaren claims P1 generates 600kg of downforce. It would need 600% more to achieve equivalent performance to that of an F1 car due to its heavier weight, and an aero package capable of creating such prodigious downforce can't just be folded up and stowed away at the push of a button.Erunanethiel wrote:For those who says downforce increasing drag, it is irrelevant for cars like p1 since you dont have to have the spoiler etc up all the time, a push of a button solves that problem.
Manhole covers don't weigh 100kg though...most are much less.mertol wrote:If a manhole cover has a radius of 40cm and weighs 100kg and a car with underbody area of 10m^2 passes over, it would need to generate more than 100*10/(pi*0.4^2)= 1989kg of downforce from the floor to lift it like in that movie "driven"
My bad but the force should be a lot bigger than the weight of the cover if you expect it to throw it in the air in the split second that the car spends over.Just_a_fan wrote:Manhole covers don't weigh 100kg though...most are much less.mertol wrote:If a manhole cover has a radius of 40cm and weighs 100kg and a car with underbody area of 10m^2 passes over, it would need to generate more than 100*10/(pi*0.4^2)= 1989kg of downforce from the floor to lift it like in that movie "driven"
This is 100% wrong and just plain stupid. Are you saying air doesn't exist until you go 60mph, and then poof, all the sudden it exists?PlatinumZealot wrote:Aerodynamic effects only kick in above 60 miles per hour or so.
I think what he is trying to say is that it doesn't become relevant until a certain speed. Road cars typically weight a few times what a formula SAE car weights, so the additional grip relative to the weight is a lot different. You'll need higher speeds in a road car to have the same effect.JMS11 wrote:This is 100% wrong and just plain stupid. Are you saying air doesn't exist until you go 60mph, and then poof, all the sudden it exists?PlatinumZealot wrote:Aerodynamic effects only kick in above 60 miles per hour or so.
Take a look at Formula SAE/Formula Student, or winged autocross classes like A-mod. Their operating speeds are mostly in the 30-60 mph range and aerodynamics have a huge effect on the performance of those cars.
Tell that to Berndmertol wrote:If a manhole cover has a radius of 40cm and weighs 100kg and a car with underbody area of 10m^2 passes over, it would need to generate more than 100*10/(pi*0.4^2)= 1989kg of downforce from the floor to lift it like in that movie "driven"
Phil wrote:The answer is in the question itself: because it's a road car.Erunanethiel wrote:why cant we have f1 downforce on road cars
What does it mean? Rather simple; Roads are very inconsistent. You have bumpy surfaces, smooth surfaces, different grip levels, different conditions from snow, ice to rain to outright dry. Everything from cold to hot asphalt. This ultimately leads that a road car requires a very wide operating window - opposed to anything track focused to even purpose specific like a F1 car.
It's the same daftness like the bike vs car topic; To argue that a bike is quicker on the roads when the bike is anything but equipped to handle high speeds on unpredictable bumpy surfaces on the very limit. Oops, did I really just open that can of worms?
So those wings and splitters on f40 and that clk dont work?Edax wrote:Tell that to Berndmertol wrote:If a manhole cover has a radius of 40cm and weighs 100kg and a car with underbody area of 10m^2 passes over, it would need to generate more than 100*10/(pi*0.4^2)= 1989kg of downforce from the floor to lift it like in that movie "driven"![]()
https://www.youtube.com/watch?v=yUMbiHNJkpk
But seriously. I have been wondering about it myself. Back in the eighties and nineties there were a lot of high performance cars on the road with big splitters and wings fitted from stock.
https://encrypted-tbn2.gstatic.com/imag ... 01AR8lk5sw
https://encrypted-tbn1.gstatic.com/imag ... wJRmmeRLNQ
I think the aerodynamically inclined gentlemen on this forum can point tons of reasons why most of these devices are not that effective but that is besides the point. The whole idea of having a supercar is the illusion that it can go fast, despite most of them spending their life revving at traffic lights or in gridlock.
And now the aero has disappeared. That does not make sense. Obviously a wing is needed for real performance as the track versions of these cars have them. So why settle for half the illusion; "my car is incredibly fast except when I have to go around a corner".
The only thing I can think of is that the regulators nowadays do not look kindly on devices which have the potential to convert pedestrians and cyclists to french fries.
