Posted: 26 Dec 2014, 13:34
Hello Riff_raff.
You write:
"Seriously, only three moving parts? Have you actually considered just how you will assemble the counter-rotating, geared crank system? Or what will you do if more than one pair of pistons is required? The overhung crankpin will also present some problems."
The basic mechanism is used, among others, in the PatRoVa 4-stroke rotary valve prototype engine:
presented at http://www.pattakon.com/pattakonPatRoVa.htm
(see the youtube video at https://www.youtube.com/watch?v=6Q-EGdeS0ws )
It comprises only three moving parts and it runs reliably.
It was also used in a few harmonic engines like:
shown at http://www.pattakon.com/pattakonPPE.htm#harmonic
Quote from http://www.pattakon.com/pattakonEduc.htm about the harmonic prototype of the photos (75mm bore, 80mm stroke, 9,000rpm):
“An internal combustion engine having pure sinusoidal motion of its pistons. The balancing of the single cylinder prototype is so perfect that it can stand free on the ground operating from idling to top revs (24 m/sec mean piston speed) without any tend to leave its place.”
Here is a simple four-cylinder 2-stroke even firing :
having four moving parts in total.
Thanks
Manolis Pattakos
You write:
Thanks
Manolis Pattakos
